I’m concerned about this as well, I redirect / reject all packets trying to access any kind of dns outside my local network unless they originate from router1. I’m using latest HA installed in python virtual environment on a raspberry pi 3b+ and the command ha is non-existent. How would I go about checking the dns settings in this kind of installation?
Apologies if the issue does not apply to “manual” install, although hardcoding dns (especially google dns) is a bad practice regardless imho.
Depending on your router, you can redirect DNS queries to the server of your choice. On my USG, I have this NAT rule that silently redirects traffic to any outside DNS server (running on 53) to its internal relay of my OpenDNS servers.
I don’t remember the specifics but the way I installed Home Assistant prevented from being able to SSH into the device. I spent far too much time trying to get around it and got nowhere.
If it is HA trying to get around my DNS blocking by going directly to the IP of a Public DNS Server that’s a problem, because I am going out of my way to make that as close to impossible as I can. Google set a bad precedent others are following with this.
When you say you can’t SSH in, do you mean to the actual machine or to HA? Because it looks like you have supervisor running so if you install either the official SSH add-on or the community one you should be able to SSH into HA.
Assuming you can get one of those add-ons installed, try running the command ha dns info. That should tell you the DNS servers that HA is using. If you don’t like what you see you can change it by doing this:
ha dns options --servers dns://IP_ADDRESS
ha dns restart
[EDIT] I haven’t tried it but if for some reason SSH absolutely isn’t an option, all the HA CLI matches up with a REST interface. So there should be a way to make calls into supervisor’s REST API and take the same actions. Would just require a bit more digging
Glad to see some noise about this again. My DNS config is pointing to my internal DNS server (confirmed via ha dns info and DNS server log activity), but something is reaching out to Cloudflare DNS servers via TLS, even on a clean install.
I’m sure it isn’t malicious, but would love to know which component isn’t honoring my DNS settings.
So what is generating those packets? Something on the machine homeassistant.lan, but the logs don’t reveal what program is actually generating the packets.
FYI, just checked every container for this, and besides the multicast container reaching out to some Kubernetes Ingress endpoint (which is yet another issue I need to check out - https://205.234.31.120/), I didn’t see any references to 853 or 1.0.0.1 in /etc and netstat.
I finally spent some time digging into this, and I think I’ve figured it out. It looks like the hassio-dns container, running CoreDNS and the coredns-fallback plugin is forwarding all types of failing DNS lookups to Cloudflare:
So as expected, it isn’t malicious, but I’m very much against this behavior. If I have custom DNS servers defined, that means I want to stay in control of my DNS. The whole point of Home Assistant is to protect our privacy and not depend on the cloud, right?
On to digging into the multicast/kubernetes phoning home behavior. I’ll start a new thread if I find anything.
If you want any traction on this I suggest you post an issue on github… Speaking generally, the devs do not respond to issues like this on the forum. Good luck
Since I’ve started actively filtering DOT & DOH on my internal network I’ve noticed that “suddenly” my HA installation tried to reach Cloudflare continiously on a constant basis about 350 DOT “calls” per 5 minutes. This is constant over several hours of operation.
Running the latest core-2021.4.2 & supervisor-2021.04.0
Should definately be addressed. I do not want any to perform any lookups without my consent.
