I’m having lots of problems with icloud3 which seems to be causing my Pi to hang then I guess the watchdog catches it and reboots it.
Whilst the (wonderful) developer is investigating, I disabled the integration and now Home Assistant just seems to be in a restart loop, my log is growing a megabyte a minute and is filled with:
I DO have SSH access which is working and is quick. Anything I can do?! Thanks
2024-03-11 10:47:55.610 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 637, in async_trigger
and not self._cond_func(variables)
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 1014, in if_action
if check(hass, variables) is False:
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 179, in wrapper
result = condition(hass, variables)
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 787, in template_if
return async_template(hass, value_template, variables)
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 767, in async_template
info = value_template.async_render_to_info(variables, parse_result=False)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 687, in async_render_to_info
assert self.hass and _render_info.get() is None
AssertionError
2024-03-11 10:47:55.617 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.623 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.629 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.635 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.641 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.648 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.654 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.661 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
AssertionError
2024-03-11 10:47:55.667 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
