that’ll work, fyi always post logs when something doesn’t work. Saying “doesn’t work” is the least helpful comment to a person helping you.
Ok, does states(‘input_text.crypto_name’) have text in it?
Yes
crypto_name:
max: 10
initial: 1inch
I add a initial so it have always a text
Then those errors should only be there on startup but after the actual state is received it should work
Everything is working now.
Even I add 220 sensors for each crypto. HA doesn’t care about that amount.
The REST Sensor have a timeout for 30 seconds so it won’t stop whole restart HA.
All template sensors are loading correct without timeout errors in the log.
Now search for a way to select them and show them in Lovelace. Want a 3 columns with 3 rows each.
thought about input_text entities where I enter the crypto name and them it will show up or something.
