I sympathise Tim, having spent the last few nights up until 5 am trying to a) get a Waveshare 7.5" ePaper display to anything at all b) get a Waveshare 2.9" display to do what I want with ESPHome.
It would be great if HA/ESPHome could get the project to the stage you suggest i.e. a drag and drop Dashboard that one can configure visually.
The project seems a long way from that, right now. For example, there isnāt a proper layout engine, it seems, to do things like wrap text, align items, pad space between them etc - things that are easy in HTML/CSS.
The main problem, for me, is that a cycle of configuration change to test regularly takes 5 minutes due to the āCompileā step. It would need to be 5 seconds to really get creative. Ideally, thereād be an online sandbox where one might test ādisplay lambdasā and see the result without having to get it working in C on oneās own display.
That said, what one can achieve with this remains impressive. Hereās what Iāve got so far!
Thatās the live Bitcoin price, coming in via a sensor on HA. The graph is generated by a Google Sheet, from live data updated daily (CSV import), making a chart which Google Sheets publishes to a URL, which my ESPHome device YAML imports via āonline_imageā. This is powered by a $2 ESP32-C3 from AliExpress. (The graph data is currently imaginary).
Cool, right?
If youāre stuck, I hope you can find the help to keep going!
Best wishes and hereās my config if it helps anyone:
substitutions:
device_name: bitcoin-price-290in
logger:
level: DEBUG # Set logging level (DEBUG for verbose output)
baud_rate: 115200 # Set the baud rate for logging output
esphome:
on_boot:
priority: 200.0
then:
- component.update: adam_epaper1
- wait_until:
condition:
lambda: 'return id(data_updated) == true;'
# Wait a bit longer so all the items are received
- delay: 5s
- logger.log: "Initial sensor data received: Refreshing display..."
- lambda: 'id(initial_data_received) = true;'
- script.execute: update_screen
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
- platform: esphome
password: "redacted"
button:
- platform: shutdown
name: "Bitcoin - Shutdown"
- platform: restart
name: "Bitcoin - Restart"
name: "Bitcoin - Refresh Screen"
entity_category: config
on_press:
captive_portal:
# Global variables for detecting if the display needs to be refreshed. (Thanks @paviro!)
globals:
- id: data_updated
type: bool
restore_value: no
initial_value: 'false'
- id: initial_data_received
type: bool
restore_value: no
- id: recorded_display_refresh
type: int
restore_value: yes
initial_value: '0'
- id: bitcoin_price_formatted
type: std::string
restore_value: no
initial_value: '""'
# Script for updating screen - Refresh display and publish refresh count and time. (Thanks @paviro!)
script:
- id: update_screen
then:
- logger.log: "Executing update_screen script"
- lambda: 'id(data_updated) = false;'
- lambda: 'id(recorded_display_refresh) += 1;'
- lambda: 'id(display_last_update).publish_state(id(homeassistant_time).now().timestamp);'
- logger.log: "Screen updated and refresh count published"
# Check whether the display needs to be refreshed, once per minute
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: /1
then:
# - if:
# condition:
# lambda: 'return id(data_updated) == true;'
# then:
# - logger.log: "Sensor data updated: refreshing display..."
# - script.execute: update_screen
# else:
# - logger.log: "No sensors updated - skipping display refresh."
wifi:
ssid: !secret wifi_ssid
fast_connect: true
on_connect:
- logger.log: "WiFi connected, updating bitcoin graph..."
- component.update: bitcoin_graph
# Add the sensor from Home Assistant
entity_id: sensor.exchange_rate_1_btc
on_value:
then:
- lambda: |-
id(data_updated) = true;
int price = static_cast<int>(id(bitcoin_price).state);
std::string price_str = std::to_string(price);
int insert_position = price_str.length() - 3;
while (insert_position > 0) {
price_str.insert(insert_position, ",");
insert_position -= 3;
id(bitcoin_price_formatted) = price_str;
# Create sensors for monitoring device remotely.
name: "adam1 - Display Last Update"
device_class: timestamp
entity_category: "diagnostic"
name: "adam1 - Recorded Display Refresh"
accuracy_decimals: 0
unit_of_measurement: "Refreshes"
state_class: "total_increasing"
lambda: 'return id(recorded_display_refresh);'
- platform: wifi_signal
name: "adam1 - WiFi Signal Strength"
unit_of_measurement: "dBm"
update_interval: 60s
# image:
# - file: "images/mini-test.png"
# id: bitcoin_graph
# type: BINARY
# Enable HTTP Request component
http_request:
useragent: esphome/1.0 # Optional: Set a custom user agent
online_image:
- id: bitcoin_graph
url: "http://homeassistant.local:8123/local/mini-test.png"
# url: "https://docs.google.com/spreadsheets/d/e/2PACX-1vSUFF1Koi0kin1iIK9kEShIjQ-gSFL2s2QvDCHzids5KC3sRgT8i0-oTRnWJXBekX9f8A2o47yUVrCs/pubchart?oid=183940170&format=image"
format: png
# type: RGBA
update_interval: 5min # Fetch a new image every 24 hours >> 5 min for testing
# resize: 296x128 # Resize the image
on_download_finished:
- logger.log: "Finished (downloading): Bitcoin graph online_image on_download_finished"
on_error:
- logger.log: "Error: Bitcoin graph online_image on_error"
font:
- file:
type: gfonts
family: Montserrat
weight: 400
extras: # Add dollar symbol $
- file: "gfonts://Montserrat"
glyphs: [$]
- file:
type: gfonts
family: Montserrat
weight: 400
glyphs: [$]
- file:
type: gfonts
family: Montserrat
weight: 400
- file: 'fonts/materialdesignicons-webfont.ttf'
glyphs:
# WiFi
- "\U000F0928" # mdi-wifi-strength-4
- "\U000F0925" # mdi-wifi-strength-3
- "\U000F0922" # mdi-wifi-strength-2
- "\U000F091F" # mdi-wifi-strength-1
- "\U000F092B" # mdi-wifi-strength-alert-outline
# Define colors
# These look the wrong way around but it's because HA works on both LCD and ePaper displays.
# On the ePaper display, white means no colour (000000). Black means max colour (FFFFFF).
# See https://github.com/esphome/issues/issues/3132
color:
- id: colour_white
hex: "000000"
- id: colour_black
hex: "FFFFFF"
spi:
clk_pin: 4 # SCK (SPI Clock) / SCL / CLK on the board - Yellow / YellowHAT
mosi_pin: 6 # MOSI (SPI Data Input) / SDA / DIN on the board - Blue / BlueHAT
display:
- platform: waveshare_epaper
model: 2.90inV2
cs_pin: 7 # CS (Chip Select) - Orange
dc_pin: 1 # D/C (Data/Command) - Green
busy_pin: 3 # BUSY (Busy signal) - Purple
reset_pin: 2 # RES (Reset) - White
reset_duration: 2ms
rotation: 270
full_update_every: 1
update_interval: never
lambda: |-
ESP_LOGI("display", ">>> DISPLAY UPDATE <<<");
if (isnan(id(bitcoin_price).state)) {
// Awaiting data
it.printf(148, 65, id(font_title), id(colour_black), TextAlign::BASELINE_CENTER, "Awaiting data...");
else {
ESP_LOGD("display", "Writing Bitgoin graph");
if (id(bitcoin_graph) != nullptr) {
ESP_LOGD("display", "Displaying Bitcoin graph image.");
// Fix inverted image: https://github.com/esphome/feature-requests/issues/1463
it.image(0, 0, id(bitcoin_graph), COLOR_OFF, COLOR_ON);
} else {
ESP_LOGD("display", "Bitcoin graph image not ready.");
// Draw blanking rectangle behind Bitcoin price
it.filled_rectangle(35, it.get_height()-20-35, 245, 35, id(colour_white));
// Draw main text with formatted price
ESP_LOGD("bitcoin_price", "Displaying bitcoin price: $%.0f", id(bitcoin_price).state);
ESP_LOGD("bitcoin_price", "Formatted Bitcoin price: %s", id(bitcoin_price_formatted).c_str());
it.printf(it.get_width() / 2, it.get_height()-20, id(font_title), id(colour_black), TextAlign::BOTTOM_CENTER, "Bitcoin: $%s", id(bitcoin_price_formatted).c_str());
/* FOOTER */
it.strftime(it.get_width()-11, it.get_height()-10, id(font_footer), id(colour_black), TextAlign::BASELINE_RIGHT, "Updated %H:%M %d%b%y", id(homeassistant_time).now());
// Draw WiFi signal strength
if(id(wifisignal).has_state()) {
const char* wifi_icon;
const char* wifi_log;
if (id(wifisignal).state >= -50) {
wifi_icon = "\U000F0928"; // Excellent
wifi_log = "Excellent";
} else if (id(wifisignal).state >= -60) {
wifi_icon = "\U000F0925"; // Good
wifi_log = "Good";
} else if (id(wifisignal).state >= -75) {
wifi_icon = "\U000F0922"; // Fair
wifi_log = "Fair";
} else if (id(wifisignal).state >= -100) {
wifi_icon = "\U000F091F"; // Weak
wifi_log = "Weak";
} else {
wifi_icon = "\U000F092B"; // Very weak
wifi_log = "Very weak";
it.print(it.get_width(), it.get_height()-10, id(font_mdi), id(colour_black), TextAlign::BOTTOM_RIGHT, wifi_icon);
ESP_LOGI("WiFi", wifi_log);
