Use of zwave / set_config_parameter in home assistant
Docs were incorrect. They have been updated now to be correct.
Payload should look like:
  "node_id": 42,
  "parameter": 5,
  "value": 2
Notice that none of the keys are strings either. The backend will coerce anything to int but just to be safe i’d suggest making everything int from the get go.
OK great thanks, I’ll test this tonight and let you know.
Cheers!
Seems to work great - thanks! Results below for the two PIR sensors I have now set to 2 minutes:
Fibaro PIR Sensor Config set to 2 minutes:
“node_id”: 38,
“parameter”: 6,
“value”: 120
Log file:
2016-10-24 18:01:18.487 Info, Node038, Value::Set - COMMAND_CLASS_CONFIGURATION - Motion alarm cancellation delay - 6 - 1 - 120
2016-10-24 18:01:18.488 Info, Node038, Configuration::Set - Parameter=6, Value=120 Size=2
2016-10-24 18:01:18.488 Detail,
2016-10-24 18:01:18.488 Detail, Node038, Queuing (WakeUp) ConfigurationCmd_Set (Node=38): 0x01, 0x0d, 0x00, 0x13, 0x26, 0x06, 0x70, 0x04, 0x06, 0x02, 0x00, 0x78, 0x25, 0xb7, 0x5b
2016-10-24 18:01:18.488 Detail, Node038, Queuing (WakeUp) ConfigurationCmd_Get (Node=38): 0x01, 0x0a, 0x00, 0x13, 0x26, 0x03, 0x70, 0x05, 0x06, 0x25, 0xb8, 0x2d
Aeotec ZW074 Multisensor Gen5 set to 2 minutes:
“node_id”: 61,
“parameter”: 3,
“value”: 120
log file:
2016-10-24 18:11:12.434 Info, Node061, Value::Set - COMMAND_CLASS_CONFIGURATION - On time - 3 - 1 - 120
2016-10-24 18:11:12.434 Info, Node061, Configuration::Set - Parameter=3, Value=120 Size=2
2016-10-24 18:11:12.434 Detail,
2016-10-24 18:11:12.434 Detail, Node061, Queuing (WakeUp) ConfigurationCmd_Set (Node=61): 0x01, 0x0d, 0x00, 0x13, 0x3d, 0x06, 0x70, 0x04, 0x03, 0x02, 0x00, 0x78, 0x25, 0xd3, 0x21
2016-10-24 18:11:12.434 Detail, Node061, Queuing (WakeUp) ConfigurationCmd_Get (Node=61): 0x01, 0x0a, 0x00, 0x13, 0x3d, 0x03, 0x70, 0x05, 0x03, 0x25, 0xd4, 0x5f
Cheers!
UPDATE: This is really neat! I just setup an Aeon Labs Minimote (just used “add node”) and then changed it to be a scene controller purely in HA by setting Parameter FA (250 in dec), Value 1 via:
“node_id”: 81,
“parameter”: 250,
“value”: 1
Before this I had to mess around stopping / starting OZWCP / Add then also use zensys-tools to set a custom parameter. No more! :slight_smile:
Nice! How would you do this in an automation? I have a Aeon labs Sirene that has multiple sounds and this would be nice to use to change the sounds.
@mark.carline Hi Mark, Did you have a chance to look at my question? Would love to know this. Thx
A quick look at the manual shows you need to change parameter 37 and value1 with 0 through 5 as settings. 0 is no change so 1 through 5 would change the sound. You can also change volume by using value2 and numbers 0 through 5 with 0 being no change.
@zarthan thanks for this but I probably was not clear. I mean; How do I use this setting (example below) of a parameter (or parameters) in an automation?
"node_id": 81,
"parameter": 250,
"value": 1
I would suggest you try
“node_id”: 81,
“parameter”: 37,
“value1”: 2
Changing the node ID to match yours and making value1 somewhere between 0 and 5, again 0 being no change.
just copy the information and paste it into the services /zwave/set_config_parameter under “Service Data” and then click the Call Service button.
Sorry. You want it in an automation. I have no idea how you would do this.
@Tyfoon Something you might want to take into consideration, as you contemplate automating a siren sound change. If the siren is a warning sound, what might happen if something went wrong during a change, rendering the siren silent?
Fallback, but it’d work - Create a bash script and use cURL to access the API call. You’ll have to create a script for each version of the sound you’d like.
Good suggestion! I guess this is with the command line switch? Did not use this yet.
shell_command
I have an automation like this:
- alias: Set Doorbell Volume to 1
    - platform: state
      entity_id: input_select.doorbell_volume
      to: '1 - Quietest'
    service: zwave.set_config_parameter
    data_template: {
      "node_id": 20,
      "parameter": 8,
      "value": 1
- alias: Set Doorbell Volume to 2
    - platform: state
      to: '2'
    data_template: {
      "node_id": 20,
      "parameter": 8,
      "value": 2
This is how I am setting default parameters for my ZW056 Doorbell from the HA webpage using an input select. Works great, but this is a plug in device and unsure how responsive any battery powered device would be.
Hope it helps!
@lordsiris Very nice! Thanks you! My Siren is a ZW-089 from the same brand (also plugin) so should work similar. Still in the original packaging, this is a good reason to test it.
I encountered the problem at the start of this thread. haas was crashing when I set parameter 5 to a value of 2 on a Multisensor 6. The issue seems to be that openzwave configures parameter as a list, not a byte. A patch to your zwcfg along these lines will fix it:
<                               <Value type="byte" genre="config" instance="1" index="5" label="Command Options" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="2" value="2">
>                               <Value type="list" genre="config" instance="1" index="5" label="Command Options" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="2" vindex="0" size="1">
@Tyfoon Did you get the Aeon Siren to work with different sounds in an automation?
I am considering buying it to use as both an alarm and a doorbell so the multiple sounds would be ideal.
@skptic Actually never tested this. Just use it as a siren (very loud by the way) with one sound and did not get around implementing the other stuff.
I think I am nearly there with the set_config_parameter in the Aeotec Siren.
In theory it should work as described here but I seem to be stuck with something on the HA side of things.
