Use template for entity_id (in automation trigger)
Same setup as above, just a different trigger: with Time Pattern trigger, the check is done every second → so there is no one minute lag → the reaction is instant :slight_smile:
alias: test_toggles
description: ""
  - platform: time_pattern
    seconds: "*"
  - condition: template
    value_template: |-
        states
        | selectattr(
          'entity_id',
          'match',
          '^(input_boolean).test_toggle_*'
        | selectattr('state', 'eq', 'on')
        | list
        | count
        states('input_number.test_toggles_being_on_count')
        | int(0)
  - service: notify.persistent_notification
    metadata: {}
      message: |-
        test_toggles_being_on_count changed from {{
          | int(0)
        }}  to  {{
          states
          | selectattr(
            'entity_id',
            'match',
          | list
          | count
    metadata: {}
      value: |-
          states
          | selectattr(
            'entity_id',
            'match',
          | list
          | count
          | float(0.0)
      entity_id: input_number.test_toggles_being_on_count
