Using bluetooth to rember parking location
I case you want a different approach this is what I’ve been using.
It creates a device tracker to show the vehicle location on the HA map instead of sending a notification of the location. But you can combine this with yours if you want both.
First you need to create a device tracker in your known_devices.yaml (create that file in your config directory if it doesn’t exist):
toyota_tacoma:
  icon:
  picture: /local/tacoma.jpg
  track: true
then create a variable to save the GPS location. I use the custom integration hass-variables for this but you might be able to use your existing location sensor:
  tacoma_location_saved:
    value: 'unknown'
    attributes:
      latitude: ''
      longitude: ''
    restore: true
then you can use the following to update everything:
- alias: Set Tacoma Location
    - platform: state
      entity_id: sensor.my_mobile_app_bluetooth_connection
    - platform: state
      entity_id: person.me
      to: 'home'
    choose:
      - conditions:
          - "{{ trigger.entity_id == 'sensor.my_mobile_app_bluetooth_connection' }}"
          - "{{ '84:DD:20:62:AA:AA (TOYOTA Tacoma)' in trigger.from_state.attributes.connected_paired_devices }}"
          - "{{ '84:DD:20:62:AA:AA (TOYOTA Tacoma)' not in trigger.to_state.attributes.connected_paired_devices }}"
          - service: device_tracker.see
              dev_id: toyota_tacoma
              location_name: "{{ states('device_tracker.my_mobile_app') }}"
              gps:
                - "{{ state_attr('device_tracker.my_mobile_app', 'latitude') }}"
                - "{{ state_attr('device_tracker.my_mobile_app', 'longitude') }}"
          - delay:
              seconds: 10
          - service: variable.set_variable
              variable: tacoma_location_saved
              value: "{{ states('device_tracker.toyota_tacoma') }}"
              attributes:
                latitude: "{{ state_attr('device_tracker.toyota_tacoma', 'latitude') }}"
                longitude: "{{ state_attr('device_tracker.toyota_tacoma', 'longitude') }}"
      - conditions:
          - "{{trigger.entity_id == 'person.me'}}"
              location_name: home
              gps: [41.00000, -85.000000]
          - delay:
              seconds: 10
              attributes:
- alias: Restore Tacoma Location After Restart
    - platform: homeassistant
      event: start
    - delay:
        minutes: 1
        location_name: "{{ states('variable.tacoma_location_saved') }}"
        gps:
          - "{{ state_attr('variable.tacoma_location_saved', 'latitude') }}"
          - "{{ state_attr('variable.tacoma_location_saved', 'longitude') }}"
it’s a bit more involved but it gives you a marker on the map and it survives HA restarts.
