Ok, I have implemented the valve to my water line coming to the house. The only issue i have now, is to show it correctly in home assistant and getting it working correctly with ESPHOME.
I got only the toggle option working, but as i turn it on the toggle will switch to on and then off. But the valve is still close.
Any ideas? i tried the switch.turn.on option and the toggle in home assistant will do the same, but the relay will stay on. But as i click the toggle to turn off the relay, nothing happends to the relay and stays on.
switch:
platform: gpio
pin: GPIO05 #D1
restore_mode: ALWAYS_OFF -
platform: template
name: Water Valve Control
icon: mdi:valve-closed
turn_on_action:- switch.toggle: relay
turn_off_action: - switch.toggle: relay
