Using ESPhome to build a water flow rate meter
@donparlor you are most welcome. If you look elsewhere in this thread, I also described how you can use Home Assistant to log the total volume of water per day/week/month/year, which is very useful for long term record keeping, if you are into that sort of data analysis.
I would like to join @Pensee in asking to see your YAML if you don’t mind; it is always very interesting to me to see how other people solve problems. I learn most that way.
Hello Stéphane,
There is a lot of coding behind this, i’ll try to write it all down.
  • Instant water debit (in ESPHome)
  - platform: pulse_counter
    pin:
      number: 4
      mode:
        input: true
        pullup: true
    unit_of_measurement: 'L/min'
    accuracy_decimals: 2
    name: "Débit d'eau instantané"
    update_interval: 5s
    filters:
      - lambda: return (x / 396); # 396 = 6,6 * 60
  • Total volume in cubic meters (in ESPHome)
  - platform: integration
    name: "Eau total en M3"
    unit_of_measurement: 'm³'
    sensor: water_usage
    time_unit: min
    filters:
        - lambda: return (x / 1000);
  • Total volume in liters (in ESPHome)
    name: "Utilisation d'eau total"
    unit_of_measurement: 'L'
     sensor: water_usage
     time_unit: min
  • Duration of the last water usage (in configuration.yaml)
    sensors:
        duree_ecoulement_eau_principale:
          friendly_name: Durée d'écoulement de l'eau principale
          unit_of_measurement: "sec"
          value_template: >
            {% set t = this.state if states('input_boolean.eau_principale_on_off') == 'off' else now().timestamp() - states.input_boolean.eau_principale_on_off.last_changed.timestamp() %}
            {{ t | round(2, 'common') }}
  • Volume of the last water usage (in configuration.yaml)
    sensors:
        volume_derniere_utilisation:
          friendly_name: Volume d'eau utilisé
          value_template: >
            {{ (states('sensor.utilisation_d_eau_total') | float - states('input_number.volume_de_depart_debit') | float) | round(2, 'common') }}
  • Cost of the last shower (in configuration.yaml)
    sensors:
        cout_de_la_derniere_douche:
          friendly_name: Coût de la dernière douche
          unit_of_measurement: '$'
          value_template: >
            {{ (states('sensor.volume_derniere_utilisation') | float * 0.01 | float) | round(2, 'common') }}
As you can see, there are some input booleans to calculate some values. If you have more questions, let me know.
@donparlor
Thank you so much for that,you save me great amount of time.
hi
what is this? cant find this sensor in your code(
this is switch for pump or something else?
This is a boolean that is triggered by a template sensor with an automation:
Here is the boolean:
Here is the template sensor in configuration.yaml
template:
  - sensor:
    - name: Durée de la dernière douche
      state:  >
        {% set current_liters = states('sensor.debit_d_eau_instantane') | float(0) %}
        {% if current_liters  > 0 %}
          {{ this.state | float(0) + current_liters  if this.state is defined else 0 }}
        {% else %}
          off
        {% endif %}
And here is the automation that triggers the boolean:
alias: Douche / Eau principale (ON/OFF)
description: ""
  - platform: state
    entity_id:
      - sensor.duree_de_la_derniere_douche
  - platform: state
    entity_id:
    to: "off"
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
            data: {}
              entity_id: input_boolean.eau_principale_on_off
      - conditions:
        sequence:
          - service: input_boolean.turn_off
            data: {}
    default: []
mode: single
I should also mention that to calculate the volume of the last water usage, I also created an input_number value that is triggered when water flow is detected
Here the input_number:
Before creating the automation storing the initial volume of water when flow is detected, you need to create a binary_sensor that will be used to trigger that action of storing the initial value.
Here is the code for the binary sensor named binary_sensor.debit_d_eau_on_off (in configuration.yaml)
template:
  - binary_sensor:
    - name: Débit d'eau (ON/OFF)
      state: "{{ states('sensor.debit_d_eau_instantane') | float(0) > 0 }}"
Here is the automation storing the initial value when water flow is detected:
alias: Douche / Définir le volume de départ
description: ""
  - platform: state
    entity_id:
      - binary_sensor.debit_d_eau_on_off
    to: "on"
condition: []
  - service: input_number.set_value
      value: "{{ states('sensor.utilisation_d_eau_total') }}"
      entity_id: input_number.volume_de_depart_debit
mode: single
I got a problem getting this to work! What is it I do wrong. I had to cut up my config file with mqtt changed this last update so I used !include_dir_merge_list.
This i did for the template sensors too in this example, but now the sensors are not being seen in HA what I have or done is this!?
in configuration i put: template: !include_dir_merge_list templates/
I made a directory named “templates” in my config dir
then I grabbed donparlor his examples :slight_smile: only way for me to get things running>>>>
for instance.
template:
  - sensor:
      state:  >
        {% else %}
          off
        {% endif %}
and i made a yaml file in my templates dir named “water verbruik laatst”
then I rewrote the code to get no errors into this
-   name: waterverbruik per keer
    unique_id: '8775758200'
    state:  >
        {% set current_liters = states('sensor.waterverbruik_in_liters') | float(0) %}
        {% else %}
          off
        {% endif %}
But that was it, in my states I do not find the sensors back, HA does not see them. SO please where did I make the error, what do I not see?!
Hello, I am a French beginner, I found your interface very interesting.
I lack knowledge but I am continually learning.
I hope you can help me because I can’t find a solution despite the time spent.
“Durée de la dernière utilisation” remains deactivated.
I think I’m not using the right sensor.
1
The first three sensors below are not visible in HA, why?
# Loads default set of integrations. Do not remove.
default_config:
        value_template: >
        value_template: >
        value_template: >
    Durée de la dernière douche:
      state:  >
        {% else %}
          off
        {% endif %}
Also here is my code in automation.
### automation eau principale
  - alias: Douche / Eau principale (ON/OFF)
    description: "Douche /eau principale (ON/OFF)"
      - platform: state
        entity_id:
      - platform: state
        entity_id:
        to: "off"
    condition: []
      - choose:
          - conditions:
            sequence:
                data: {}
          - conditions:
            sequence:
                data: {}
        default: []
    mode: single
### automation volume de départ
  - alias: Douche / Définir le volume de départ
    description: "Douche / Définir le volume de départ"
      - platform: state
        entity_id:
        to: "on"
    condition: []
    mode: single
I hope not to bother asking for this help. I am blocked by my knowledge. Thanks a lot.
Hello Patrice!
Congratulation for reaching this far re-creating this setup. We could continue un French from here but I’ll keep it in english for the community. In this post I said I created an Input_Number: Using ESPhome to build a water flow rate meter - #166 by donparlor
This boolean tells Home Assistant that water flow is ON or OFF. If you need help creating an Input Boolean, look at this tutorial: Input Boolean - Home Assistant
Durée de la dernière utilisation (Duration of the last water usage) refers to that boolean so it can calculate time properly. Let me know if you created that boolean, I’ll dig further into your code after you answered. I need some sleep here, it’s 2h52 AM! :sweat_smile:
Hello Vincent. I am happy to have a return from you, I hope the night was good :innocent: , and it is normal to continue our exchanges in English for the community. :relaxed:
I have created both inputs. Maybe they are misconfigured ?
For the input_number, I don’t have the same configuration possibilities.
Thank you again for your help.
Hello, sorry to ask, but I’m still interested if you have any idea regarding my problem. Thanks
Hello Patrice,
Sorry for the delay, very busy this week. I think I forgot to mention about a binary sensor in my YAML file that I didn’t mention. This template binary sensor triggers the automation which input volume, its name is binary_sensor.debit_d_eau_on_off. This is probably why sensor.duree_de_la_derniere_douche with friendly name Durée de la dernière utilisation (Duration of the last water usage) is not working.
template:
  - binary_sensor:
After creating that binary_sensor, make sure to double-check the automation storing the initial value when water flow is detected:
description: ""
  - platform: state
    entity_id:
    to: "on"
condition: []
mode: single
Let me know if that works for you.
Good luck!
PS: I will add this binary_sensor to my post above so there is not missing anything.
Hello, no worries, thank you for taking the time to answer me today.
I added the binary_sensor.
I have the information that appears but only indicates the enabled/disabled state.
I don’t have the time that appears.
Here is a screenshot.
What do you think ? Thanks a lot.
Hi you, What kind of sensor are you using? if i use YFS201 how will the configuration change? can i see your wiring diagram? Thank you very much.
The value being displayed at Durée de la dernière utilisation (Duration of the last water usage) comes from sensor.duree_ecoulement_eau_principale
    sensors:
          value_template: >
You are displaying Débit d’eau (ON/OFF).
Try to change the sensor from where this value is displayed.
I simply use a NPT YF-B5 sensor
But basically, this setup can work with most if not any flow sensor. The only thing that change is the first sensor in ESPHome that calculate the rotation of the flow sensor.
    pin:
      number: 4
      mode:
        input: true
        pullup: true
    update_interval: 5s
    filters:
It’s just a matter of adjusting the lambda to your flow sensor:
filters:
YF-B5 is:
396 = 6,6 * 60
For YF-S201, the flow rate pulse characteristics goes as follow: Frequency (Hz) = 7.5 * Flow rate (L/min)
So the lambda should be
filters:
      - lambda: return (x / 450); # 450 = 7,5 * 60
Then you first sensor in ESPHome will be:
    pin:
      number: 4 #Change according to the pin where you connected your flow sensor on ESP32 board
      mode:
        input: true
        pullup: true
    name: "Débit d'eau instantané" #Choose name according to your display language
    update_interval: 5s
    filters:
Hello, I wanted to put this sensor, but it does not appear.
I don’t understand if I made a mistake. Thank you
And if you go in your Development tools tab, can you find it?
Look what I can see when I search for it:
Curiously, there is nothing with “duree_ec….”
And very basic question but I must ask: Did you restart your HA after adding those lines in your configuration.yaml ?
