Hi there,
Is it possible to configure hassio to send Z-Wave events to my AWS device shadow using MQTT.
Best Regards,
Andy
Hi there,
Best Regards,
Andy
I have been running into problems with this as well and I just uploaded a new forum topic here: 'Service mqtt.publish not found' when attempting to use AWS as MQTT broker
Have you been able to get this working?
Check out the following tutorial:
The one main change I made was that instead of defining a certificate within my Hassio system in the configuration.yaml file, allow Hassio to generate the cert automatically. This is done by defining the certificate as auto (see picture below).
