Nope, when i use hass in macos python3 under brew it works, has something to do with docker i think
…I’ve just remembered I had to change the port to get it working. In my homekit.yaml file I set port: 51829
Maybe try that, or a different port?
Tried that, how do you do this with traefik?
This is a dated topic, but I looked around and didnt find a clear solution. After a bit of digging it looks like the solution here is two fold:
Open (publish) port 51827 in HA container (or, as it turns out, any port as its configurable on either side)
Publish (advertise) HA’s HAP (“Homekit Accessory Protocol”) service (port 51827) to mDNS
The latter can be accomplished in a couple of different ways depending on the host system. In my case its a Synology NAS which doesnt come with avahi-pubilsh installed.
One (somewhat hacky in this scenario) way to announce a service to mDNS is to configure it in /etc/avahi/services.
I named mine as homeassistant.service and populated as follows:
root@nas:~# cat /etc/avahi/services/homeassistant.service
<service-group>
<name>Home Assistant Bridge</name>
<service>
<type>_hap._tcp</type>
<port>51827</port>
<txt-record>md=HA Bridge</txt-record> <!-- friendly name -->
<!-- the following appear to be mandatory -->
<txt-record>pv=1.0</txt-record> <!-- HAP version -->
<txt-record>id=00:11:22:33:44:55</txt-record> <!-- MAC (from `.homekit.state`) -->
<txt-record>c#=2</txt-record> <!-- config version -->
<!-- the following appear to be optional -->
<txt-record>s#=1</txt-record> <!-- accessory state -->
<txt-record>ff=0</txt-record> <!-- unimportant -->
<txt-record>ci=2</txt-record> <!-- accessory category (2=bridge) -->
<txt-record>sf=1</txt-record> <!-- 0=not paired, 1=paired -->
<txt-record>sh=UaTxqQ==</txt-record> <!-- setup hash (used for pairing) -->
</service>
</service-group>
MAC address should be the same that was provided to HomeKit at pairing. It is stored in .homekit.state located in HA configuration folder. At least in my version of Home Assistant. I believe older versions keep it elsewhere, should be easy to find.
Config version (c#) is an integer, also stored in .homekit.state however the value in the service descriptor for c# doesnt appear to have to match whatever is in .homekit.state.
Setup hash (sh) is used for pairing with new accessories. I omitted it, as well as the rest of optional TXT records.
For completeness here’s my rather unremarkable docker-compose.yaml:
version: '3.2'
networks:
homeassistant:
external: true
services:
homeassistant:
container_name: home-assistant
image: homeassistant/home-assistant
restart: always
volumes:
- ./config:/config
- /etc/localtime:/etc/localtime:ro
devices:
- /dev/ttyACM0:/dev/ttyACM0
ports:
- 51827:51827
networks:
- homeassistant
Hope this helps.
Thank you so much. I was looking around for days and trying different things found in various posts but yours worked perfect for me. Now I got my stuff working with home kit. Thanks again.
Hey first of all thank you for this info. I still have a few questions. After configuring the HomeKit component to use safe mode, I was able to pair it within the home.app, but I’ve got issues to populate accessories within the latter. The HomeKit integration seems to work after inspecting the logs. So here are my questions:
You’re not running the container in host mode, right (that’s what I see at least in your compose file)?
Did you have to configure anything else for the accessories to show up?
Correct.
Not in the context of this topic of getting mDNS to work with services inside docker containers.
So… digressing off topic here.
There are two issues with getting homekit accessories to show up (that i’ve encountered).
One, the need to postpone homekit start until after zwave network has initialized. Which can take as long as 5-10 minutes. Even longer.
I use this automation to start homekit:
- id: homekit-start
alias: 'Start HomeKit'
initial_state: true
- platform: event
event_type: zwave.network_ready
- platform: event
event_type: zwave.network_complete
- service: homekit.start
The second issue is to do with filtering (including) accessory entities. Thats done as part of homekit: config key:
homekit:
auto_start: False
filter:
include_entities:
- climate.thermostat
- sensor.thermostat_temperature
- switch.outside_floodlight_switch
Note that here auto_start is set to False. This is because homekit service is expected to start by automation shown above.
Lastly, this is an old hack, for all I know, this has been fixed in recent version(s) of HA.
mhhh I definitely have trouble with it running reliable. I suspect that I miss iptable rules since the bridge is seen and the hass HomeKit logs don’t look off at all.
The avahi service you posted is meant to be run on the host, right?
Thanks for sharing though. I’ll definitely tinker with it!
edit: may I ask how you configured your external network?
yes avahi service is configured on the host, that is, on the synology nas box.
as for network configuration if you mean docker network, there’s a ui in synology docker app that allows creation of external networks, i’m sure its not much more than a facade to docker network create. in fact, here:
root@nas:~# docker network ls
NETWORK ID NAME DRIVER SCOPE
e239xxxxxxxx homeassistant bridge local
57efxxxxxxxx ingress bridge local
Hi @rzen! You are such a big help in this and I have the feeling I almost got it working for me.
Can you show how you configure your homekit component in configuration.yaml?
I am on the latest Home Assistant version, have everything running in Docker behind a NGINX reverse proxy. I want to avoid having network_mode: host at all cost.
With the homeassistant.service I managed to get the bridge published, however, I cannot connect to it from Home.app. It seems, that I somehow need to get from the docker-ip (172.xxx) to the host-ip (192.168.1.8). Any ideas? How did you solve that part?
Thanks again!
my homekit config is very straightforward:
homekit:
port: 51827
auto_start: False
filter:
include_entities:
- sensor.thermostat_humidity
- ...all entities for homekit listed here...
this is my complete docker-compose.yaml for HA (except for Host:xxx which is used to ingress traffic for HA via traefik):
version: '3.2'
networks:
homeassistant:
external: true
services:
homeassistant:
restart: always
volumes:
- ./config:/config
devices:
- /dev/ttyACM1:/dev/ttyACM1
ports:
- 8123:8123
- 51827:51827
networks:
- homeassistant
labels:
traefik.port: '8123'
traefik.frontend.rule: Host:xxx
Hi, thanks for the info, 3 questions
Are you running avahi native or in docker?
Wat is your avahi config?
What ip do you fill in the config yaml under advertise_ip, from the os, docker or hass container?
I’m using native avahi that came pre-installed on my Synology nas.
$ cat /etc/avahi/avahi-daemon.conf
# This file is part of avahi.
# avahi is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as
# published by the Free Software Foundation; either version 2 of the
# License, or (at your option) any later version.
# avahi is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
# or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public
# License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with avahi; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307
# USA.
# See avahi-daemon.conf(5) for more information on this configuration
# file!
[server]
loglevel=0
#host-name=foo
#domain-name=local
#browse-domains=0pointer.de, zeroconf.org
use-ipv4=yes
use-ipv6=yes
#allow-interfaces=eth0
#deny-interfaces=eth1
#check-response-ttl=no
#use-iff-running=no
#enable-dbus=yes
#disallow-other-stacks=no
#allow-point-to-point=no
#cache-entries-max=4096
#clients-max=4096
#objects-per-client-max=1024
#entries-per-entry-group-max=32
ratelimit-interval-usec=1000000
ratelimit-burst=1000
aliases-conf=/var/tmp/nginx/avahi-aliases.conf
[wide-area]
enable-wide-area=yes
[publish]
#disable-publishing=no
#disable-user-service-publishing=no
#add-service-cookie=no
#publish-addresses=yes
#publish-hinfo=yes
#publish-workstation=yes
#publish-domain=yes
#publish-dns-servers=192.168.50.1, 192.168.50.2
#publish-resolv-conf-dns-servers=yes
#publish-aaaa-on-ipv4=yes
#publish-a-on-ipv6=no
[reflector]
#enable-reflector=no
#reflect-ipv=no
[rlimits]
#rlimit-as=
#rlimit-core=0
rlimit-data=4194304
#rlimit-fsize=0
rlimit-nofile=768
rlimit-stack=4194304
rlimit-nproc=3
[synology]
resolve-raop=yes
resolve-airplay=yes
resolve-airport=yes
This is a service descriptor for HA:
$ cat /etc/avahi/services/homeassistant.service
<service-group>
<service>
<port>51827</port>
</service>
</service-group>
In this configuration advertise_ip isn’t necessary. You can see my homekit config above in its entirety.
Best of luck!
Thank you @rzen for all the tips! I finally got mine working!
For anyone on Raspberry Pi using Docker, here are additional pointers:
- Don’t forget to clear out
.homekit.state - I followed @rzen’s instructions but needed to update the MAC (
id) on the host’s avahi service after home-assistant started
Thanks for the help.
On Mac os i used this command to get mDNS to work correctly.
dns-sd -R Homeassistant _hap._tcp local 51827 md=”HA Bridge” pv=1.0 c#=2 id=00:11:22:33:44:55 s#=1 sf=1 ci=2 ff=0 sh=UaTxqQ==
MAC-adress, as mentioned by others, should be the same as in .homekit.state
It works link a charm! You just save my day. ![]()
Now I am having trouble adding HomeKit controller devices to HA.
Does anyone have HA running in Docker and HomeKit accessories (ecobee in my case) paired with HA?
Thanks, this command is working for me
Question, is ik posible to use dns-sd as deamon or something that runs automatic on the background?
edit:
For now I made an automator program that runs with the startup of macOS.
Just wanted to drop in here and post my solution. I’ve spent a lot of time getting a simple solution worked out, given the amount of time spent I feel that I must share.
Issue:
Running in network_mode: host would allow me to control my Ecobee3 Lite thermostat. This seems to use things related to mDNS, multicast, Bonjour, Homekit; I may be slightly wrong about that part.
How to pinpoint if you have the same issue:
- With Home Assistant running with network_mode: host, run:
docker exec [your home assistant docker container id here] python3 -m netdisco
- With Home Assistant running WITHOUT network_mode: host, run:
If #1 returns results but #2 does not, then you have the same situation as me and the solution below will probably work!
(side note: netdisco is documented here: https://www.home-assistant.io/integrations/homekit_controller/#home-assistant-cannot-discover-my-device)
Solution:
Add a container that repeats mDNS traffic from one network interface to another network interface. In my case I ran
docker exec [your home assistant docker container id here] ifconfig
and found that my Home Assistant container had a ip address of 192.168.80.7. To determine what network interface that’s on, I ran route -n and then found the 80 subnet (192.168.80.0) in the Destination column and then grabbed the interface name from the Iface column. I did the same for my host; find 0.0.0.0 and then grabbed the interface name from Iface.
Once you have the two network interface names, you can run a container to repeat mDNS between the two network interfaces.
Here’s a docker-compose example:
version: '3.8'
services:
home-assistant:
ports:
- 8123:8123
mdns-repeater:
image: angelnu/mdns_repeater
network_mode: host
environment:
- hostNIC=enp4s0
- dockerNIC=br-de87821a94e9
Also, here’s a link to my solution: https://github.com/TonyBrobston/tbro-server/blob/e3ff788e81c68848e20a5d325fe5c2e2484bf65d/home-automation/docker-compose.yml#L34-L40
I personally felt this was the best way to handle this problem, I feel like running network_mode: host on my Home Assistant container is opening up a bunch of things unbeknownst to me. I prefer to open only exactly as much as necessary. I realize that the mdns-repeater in my solution is running in network_mode: host, however I assume (probably a bad assumption) that the mdns-repeater isn’t doing anything more than repeating mDNS. I may look further into that repo later to be sure.
Hope this helps someone else!
Hey @TonyB . Appreciate you posting this. I really hope you are on Mac? because this solution may be just what I’m looking for.
Edit: NVM. #2 Does return results for me
