if your problem is that you get messages too often, you have various scenarios to change that:
change the triggering entities
change the criteria for the calculation of temps (main template)
change the conditions under which the main template should further be limited
the latter could be:
frequency: change the time between messages
rule out too small changes: change the difference delta to be larger than simply any change at all (like now)
rule out attribute changes to trigger the automation (my set of 3 )
@Mariusthvdb, thanks for help i really appreciate it.
My goal is getting messages only when temperature enter new interval.
This is already done in my first message in this topic. And works exactly like i need. But it require one automation for each temperature sensor. 10 sensors - 10 identical automation. If I decide to change something in automation i need to change it in 10 places. Configuration is ugly.
That’s why I thinked there is better way - templating identical sensor automation. On first though idea with conditions was good. But as the result I must fight multiple unneeded notification.
Second variant working with multiple entities - platform: numeric_state. Only problem - below/above doesn’t accept values from variables or states.
Ok. I think I’ll open a feature request for accepting values from other entities in below/above option.
The reason you’re ‘fighting’ multiple notifications is because of the way you created the condition … which effectively does nothing and accepts any value.
You’ve already described the kind of condition you need:
You want a condition that checks if the temperature crosses one of the two thresholds (temp_low or temp_high). That means it must check if the value’s previous state (trigger.from_state.state) to its current state (trigger.to_state.state) crossed a threshold.
There are two thresholds creating three ranges:
1 | 2 | 3
low high
We are only interested when the value crosses a threshold into a different range:
Entering range 1: to_state < low and from_state >= low
Entering range 2: to_state >= low and from_state < low
Entering range 2: to_state <= high and from_state > high
Entering range 3: to_state > high and from_state <= high
Alternately, this version which uses a single Template Condition and is far more legible:
condition:
- condition: template
value_template: >
{% set to_state = trigger.to_state.state|float %}
{% set from_state = trigger.from_state.state|float %}
{% set low = states('input_number.outdoor_temperature_low')|float %}
{% set high = states('input_number.outdoor_temperature_high')|float %}
{{ (to_state < low and from_state >= low) or
(to_state >= low and from_state < low) or
(to_state <= high and from_state > high) or
(to_state > high and from_state <= high) }}
I forgot I can compare to/from state with temperature margins I have configured.
That’s much better.
It’s very compact
easy to read
no bad notification when I change temperature margins as temperature sensors doen’t change its state.
I have added unavailable state in template. Hasn’t powered off a sensor to check, but manually setting sensor status to unavailable works like it should.
# Notify outdoor temperature sensors changes
- alias: "Notify Outdoor Temperature"
initial_state: on
- platform: state
entity_id:
- sensor.outside_temperature
condition:
value_template: >
(to_state > high and from_state <= high) or
(to_state == unavailable) }}
- service: notify.hedgehog57
data_template:
message: >-
{% set emoji = "sensor."+trigger.to_state.entity_id.split('.')[-1]+"_emoji" -%}
{{ states(emoji) }} {{ trigger.to_state.name }}: {{ trigger.to_state.state }}{{ state_attr(trigger.to_state.entity_id, 'unit_of_measurement') }}
@Mariusthvdb, thanks You too. I still don’t understand why I will have too many messages. ATM i will receive a message when margins are passed for 0.1 degree. It’s acceptable. I will not receive new messages about this sensor until it will pass margin in other direction. Many messages will be generated if temperature will slightly change around a margin.
As I understand You propose to notify only when state pass margin for more than 1 degree, right? Good Idea. In case of flood messages I will add Your code to automation.
About FR I was told earlier. For this automation it is not needed, You’re right. But it’s strange that from/to can use templates but below/above can not.
Now I need to check all my automations with this new knowledge about conditions.
Thanks to all! Hope it was interesting and instructive not only for me.
Glad to hear that it works for you and you like it.
Please mark my post as the Solution so that other users, with a similar question, can easily find the answer. Only you, the author of this topic, can mark the Solution. It will automatically appears as a link under your first post, thereby making it easier for others to find it (and a checkmark will appear next to the topic’s title). Thanks.
