That’s what I was trying to replicate from dev states…perfect thx
You’re welcome!
If you believe my suggestion fulfills your Feature Request, please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions (or Feature Requests).
For more information about the Solution tag, refer to guideline 21 in the FAQ.
Yeah, I don’t remember the exacts, but the simple forward way didn’t work (reliably) for some reason back then.
I use a mix of external NFC readers (ESP-Home) and the build in the phone one, i always had so scan twice or three times before the template switch would update if i scanned from a different device then the last one.
anyway, good to hear the straight forward way now works.
You can name/rename tags under the config → tag tab
then the cogwheel at the end:
other than being more recognizable than the codes this doesn’t make it a usable entity…
For the last_scanned part see excellent suggestions in this thread.
You would have to create some template sensors
Yeah definitely will mark post
Have one little issue I can’t resolve is getting time format
(month, day, year hour : min) only.
Nothing seems to work, I hate to keep bugging you over this. But sometimes that little stuff gets me.
Hey thanks for all your help… I guess walking away helped!!! got to work
Again, thanks for all your hard work.
For some reason I don’t see the solved check box
No worries. I thought you were the author of this topic. Only the topic’s author can mark a post with the Solution tag.
OH yeah that’s right .lol
You’re awesome appreciate the hell out of it
If anyone wants to see… this is end results
Apothecary Card
This should get you where you need to go
input-boolean
vitamins_taken:
icon: mdi:pill-multiple
# icon: mdi:pill
# Automations
## Meds ##
- alias: med1_Med
description: 'Daily'
- platform: tag
tag_id: 88b98f79-c6d8-4bd7-bd1d-d74d4368ca75
entity_id: input_boolean.med1_taken
## Resets ##
- alias: Reset med1
- platform: time
at: "00:00:01"
- service: input_boolean.turn_off
# Template
## NFC_Scraping ##
- trigger:
- platform: event
event_type: tag_scanned
- name: NFC_LastTag_Scanned
state: '{{ trigger.event.data.tag_id }}'
- name: NFC_LastTime_Scanned
state: '{{ trigger.event.time_fired }}'
## Date ##
- trigger:
- platform: tag
- name: NFC_med1_Date
state: "{{ as_timestamp(states('sensor.date_time_iso')) | timestamp_custom('%a %B %-d, %I:%M %p') }}"
icon: "mdi:calendar-clock"
Thank you much @123 Taras so apreci!!
If you’re interested, you can replace this:
with this:
{{ now().strftime('%a %B %-d, %I:%M %p') }}
Retried that string and works this time… I guess it was my formatting before
thanks makes it simpler!
