yes those ## are not in my code, how it was copied over, apparently it doesn’t like spaces, but it’s working now! How do i get the data over if i have a leak? that is part of the json, but it only reads the meter reading
Weidly if i change the time to 24 hours in minutes, it will work for 10-15 mintes but then error out, if i change the time interval to 10 m it doesn’t work at all…
Looks like PG&E will allow you to use zigbee devices if you register your MAC…
I’ve got a nortek HUSBZB-1, and if I can figure out the MAC address, hopefully I can register it with PG&E to stream my data!
Anyone know how to find the MAC address of a usb radio?
No, you’ve got to log into your account then in your billing page you should see a “stream my data” section you can click on that will take you to the registration…
It’s not very intuitive but it’s there…
I got everything up and running and was able to read my water meter because the frequency was printed on the side of the box… My gas and electric meters I assume are wireless as they are scanned by a car that drives by occasionally… but i have no idea what their frequencies are at (or if the signals are encrypted). I can’t find good suggestions on how to scan all frequencies to figure out where it’s sitting… any suggestions?
anyone from on, ca was able to setup this ? i checked my water meter brand is napolean which is not in list. can’t figure out what my gas and electricity brand is.
I am in US, California, We have PG&E, does that work with them??? I just order the NESDR, Will be here un a couple days, I need to know how can I get the info I need for it. Thanks!!!
