Using the results of a simple GPS Rest call?
There was an error in my value template. I had "{{ value_jason.0.log }}" instead of "{{ value_json.0.log }}". I have corrected this above.
yeah, but its not the value template, if i just use ā€œokā€ there, and use attributes, i get sale error
dont think the null is causing it , i have seen others with null too before in json
i would test it , but how can i remove those null values before parsing it?
No the value template can’t be used.
Not sure about the replacement. I’m just saying that is the only thing I can think of.
Except trying it in Node red, since you will be able to parse and manipulate the values before it entering HA there.
dont have nodered either :slight_smile:
i tried another one, without any null values, gives me same error??
  - platform: rest
    resource: http://365gps.com/n365_utime.php?imei=123456789&sec=60&hw=apk
    headers:
      Content-Type: application/json
    scan_interval: 300
    value_template: "OK"
    json_attributes:
       - result
2021-12-06 12:17:53 WARNING (MainThread) [homeassistant.components.rest.sensor] REST result could not be parsed as JSON
you can test the command too if you want :
curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_utime.php?imei=123456&sec=60&hw=apk"
just pasted a fake IMEI number, but gives results
As expected, there is a bad character in the string.
But Node red can parse it when you remove that character.
What is the bad character? Can it be removed with the sensor? Don’t have nosered
Don’t know what it is but it’s the first character.
It’s one horrible click to install.
it seems there’s a bug in your device. If you don’t want to use node red, you can use the rest integration.
rest:
  - resource: http://server/n365_ilist.php?hw=iOS&imei=IMEI&pw=PASSWORD
    scan_interval: 300
   - name: Google
     value_template: "{{ (value[1:] | from_json)[0].google }}"
   - name: Logs
     value_template: "{{ (value[1:] | from_json)[0].log[3:] | as_datetime }}"
     device_class: timestamp
   - name: Gps
     value_template: "{{ (value[1:] | from_json)[0].gps.split(',')[5:7] | join(', ') }}"
this creates 3 sensors. 2 with gps cords, 1 timestamp.
Thank you ! This works.
FYI the timestamp one will have a warning in 2021.12 that will get fixed sometime in the future and you can safely ignore it
nice!!
@john2014 , now we have the coordinates, how can we build a device tracker from it? to show on map?
btw, i also now have extra commands, like remote on/off / reboot / shutdown / fnd on/off / enabe trackign / playback history / …
gonna make some shell commands from it, so i can use them in HA
if interested …
we are thinking the same thing :). Already looking at this post How to create a custom device tracker (from GPS coordinates)? - Configuration - Home Assistant Community (home-assistant.io) but not that familair on this. Will need to read about this a bit more.
ok, gonna read about it , stuff for tomorrow
anyway, if you already have it pls paste
below are the commands i took from the android app, for me the most imortant ones…
gps365_get_status: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_ilist.php?hw=apk&imei=111111111123456&pw=123456"
gps365_remote_shutdown: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_req.php?imei=111111111123456&req=49&hw=apk"
gps365_remote_reboot: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_req.php?imei=111111111123456&req=48&hw=apk"
gps365_remote_off: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_sav.php?imei=111111111123456&msg=01010000000001000000000000"
gps365_remote_on: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_sav.php?imei=111111111123456&msg=01000000000001000000000000"
gps365_interval_600: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_utime.php?imei=111111111123456&sec=600&hw=apk"
gps365_interval_60: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_utime.php?imei=111111111123456&sec=60&hw=apk"
gps365_sleep: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_utime.php?imei=111111111123456&sec=65535&hw=apk"
gps365_get_location: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_loc.php?imei=111111111123456&t=1&hw=apk"
gps365_find_on: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_find.php?status=1&imei=111111111123456&hw=apk"
gps365_find_off: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_find.php?status=0&imei=111111111123456&hw=apk"
gps365_playback: curl -X GET -H "Content-type: application/json" -H "Accept: application/json" "http://365gps.com/n365_route.php?imei=111111111123456&sd=2021-11-21+23%3A00%3A00&ed=2021-11-22+22%3A59%3A00"
Use the device_tracker.see in an automation to make a device tracker.
- alias: My GPS automation
  mode: parallel
  - platform: state
    entity_id:
    - sensor.google
    - sensor.gps
  variables:
    coords: >
      {{ trigger.to_state.state.split(',') | list if trigger is not none and trigger.to_state is defined else none }}
  condition:
  - condition: template
    value_template: "{{ coords | length == 2 }}"
  - service: device_tracker.see
      dev_id: "{{ trigger.to_state.entity_id.replace('.','_') }}"
      gps: "{{ coords }}"
I think I got it.
I changed the solution of petro a bit to have seperate sensors for lon and lat
    scan_interval: 300
    - name: Google
    - name: Logs
    - name: GpsLON
      value_template: "{{ (value[1:] | from_json)[0].gps.split(',')[5] }}"
    - name: GpsLAT
      value_template: "{{ (value[1:] | from_json)[0].gps.split(',')[6] }}"
Then create an automation
  - platform: state
    entity_id: sensor.gpslat, sensor.gpslon
    data_template:
      dev_id: cargps
      gps:
        - '{{ states(''sensor.gpslat'') }}'
        - '{{ states(''sensor.gpslon'') }}'
This will create an entity cargps
Which you should be able to use on the map card
Thnx @petro as always!! Thnx @john2014 for sharing!!
One correction it should be
    - name: GpsLAT
    - name: GpsLON
I had mixed up the LON and LAT
I am seeing my car now on a map on my dashboard.
Maybe also usefull to include battery in the device tracker?
