Using trycloudflare.com for remote access to home assistant
I guess that is the Issue here:
https://github.com/home-assistant/core/pull/51839
https://community.home-assistant.io/t/update-broke-apache-reverse-proxy/321448/10?
Thank you! That was indeed the problem. Working again now.
I am trying to wrap my head around the Idea having the URL as a sensor, first Issue is, where is the log file?
ok, update. The log output is the one from the docker container.
So this works to look at the log:
docker logs xxx_try_cloudflare
first Idea was to run this trough node red, but i get a
error:127
which means, to my understanding that node red does not have the rights to execute this commandā€¦
any other ideas?
I used the trycloudflare for a almost a year now, but 3 days ago the application add-on stopped.
I unistalled the add-on but itā€™s not possible to reinstall anymore. Someone have a solution for that?
Tried to install the addon but got this error.
"Failed to install add-on
The command ā€˜/bin/ash -o pipefail -c go get github.com/cloudflare/cloudflared/cmd/cloudflaredā€™ returned a non-zero code: 1"
Iā€™m still new here so unsure what to do next.
Is there a way to access SAMBA shares remotely using the Cloudfare Addon?
Iā€™ve been using the Cloudflared add-on for probably less than a year. Iā€™ve had a paid [mydomain].com for over a decade and Iā€™m accessing HA successfully through https://ha.[mydomain].com.
The only trouble is, my www.[mydomain].com website no longer works. It doesnā€™t direct to the web server where my (admittedly terrible) website is. Itā€™s not crucial that itā€™s up & running, but it would be nice to have it work again. This is outside the scope of the add-on, but I was hoping someone could give me some ideas about how to configure Cloudflare to allow access/redirect to my site.
EDIT: Nevermindā€¦ I set up a Page Rule in my Cloudflare account. It only took a couple of minutes. I donā€™t know why I skipped it when I first set this upā€¦
