are you haveing the same errors in the log as I had? I havent got the time to tinker with this at the moment but I can try to reopen the ticket and point them here if you give some logs
seems I cant re-open them if someone else closed them
After I reset my roomba to factory default I couldnāt reproduce the problem anymore. So itās hard to troubleshoot at the moment. I donāt get the error with the wrong flags:
def _internal_on_disconnect()
So I am a bit stuck. Maybe the error will come back. So I suggest do a factory reset. Hope it helps
my problem is that I dont know how to run commands in docker, I have reset my roomba to factory defaults and added it in the app and now I cant get the password from it again since it probably has changed after the reset. I tried to install the ssh addon but when I try to run:
docker exec -it homeassistant python -c 'import roombapy.entry_points; roombapy.entry_points.password()' 192.168.1.73
it only gives me: bash: docker: command not found
I used this one https://github.com/NickWaterton/Roomba980-Python
I created virtualenv and installed required libs and runned the roomba command. This one worked better than the library used in home-assistant.
