Sure, here it is:
[{"id":"a4f9ef2c.1a6f4","type":"tab","label":"Roberta","disabled":false,"info":""},{"id":"647da47e.a4c59c","type":"server-state-changed","z":"a4f9ef2c.1a6f4","name":"Ready?","server":"820ae6a6.7f40a8","version":3,"entityidfilter":"vacuum.xiaomi_vacuum_cleaner","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"returning","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":500,"wires":[["bb25ba41.f60398","481c4173.60da"],[]]},{"id":"bb25ba41.f60398","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"timed off","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"automation","service":"turn_off","entityId":"automation.takaritas_utemezese","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":300,"y":480,"wires":[[]]},{"id":"8bae9caa.622b8","type":"server-state-changed","z":"a4f9ef2c.1a6f4","name":"start","server":"820ae6a6.7f40a8","version":3,"exposeToHomeAssistant":true,"haConfig":[{"property":"name","value":"NR Roberta"},{"property":"icon","value":"mdi:sitemap"}],"entityidfilter":"input_boolean.zone_cleaning","entityidfiltertype":"substring","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":220,"wires":[["84023769.8e1188"]]},{"id":"84023769.8e1188","type":"switch","z":"a4f9ef2c.1a6f4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"false","repair":false,"outputs":1,"x":290,"y":220,"wires":[["ee8dc3c2.54522","dedc93eb.38ac2"]]},{"id":"ee8dc3c2.54522","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"living room on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.living_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":560,"y":120,"wires":[["56a06a79.08b6e4"],["1c306001.20ec5"]]},{"id":"56a06a79.08b6e4","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"living room cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[25117,23074,28567,25874],[24407,25910,29507,29760],[23538,25224,24288,31024]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":780,"y":120,"wires":[[]]},{"id":"c7b592ff.6918f","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"bedroom off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.bedroom_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1250,"y":240,"wires":[[]]},{"id":"5f0e419c.d8d5","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"bedroom cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[19008,29733,23258,32333]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":770,"y":300,"wires":[[]]},{"id":"47910bbf.0d9814","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"bedroom on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.bedroom_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":550,"y":300,"wires":[["5f0e419c.d8d5"],["ca7517d3.33cc28"]]},{"id":"82479d36.2f6ef","type":"trigger-state","z":"a4f9ef2c.1a6f4","name":"paused?","server":"820ae6a6.7f40a8","version":0,"entityid":"vacuum.xiaomi_vacuum_cleaner","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"pq55xe30min","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"paused"}],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":120,"y":140,"wires":[["d804583b.cd5498"],[]]},{"id":"d804583b.cd5498","type":"change","z":"a4f9ef2c.1a6f4","name":"send on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":140,"wires":[["84023769.8e1188"]]},{"id":"7028d255.664bbc","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"girls room cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[19008,23148,23308,26148]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":770,"y":420,"wires":[[]]},{"id":"6610b5d.954964c","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"girls room off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.girls_room_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1250,"y":360,"wires":[[]]},{"id":"cbde677b.632c38","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"girls room on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.girls_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":560,"y":420,"wires":[["7028d255.664bbc"],["2c810d47.ce08a2"]]},{"id":"b06664fc.0275f8","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"living room off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.living_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1020,"y":120,"wires":[[],["c0bdb260.caac4","d80cfd79.3f3ef"]]},{"id":"ac9fc5ae.a357e8","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"bedroom off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.bedroom_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1010,"y":300,"wires":[[],["6064f6d0.4437a8","82a0745.6f3c888"]]},{"id":"eec98a66.7e7e58","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"zone off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.zone_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1240,"y":540,"wires":[[]]},{"id":"cdc3aca5.08143","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"middle room cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[18882,26586,23282,29286]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":780,"y":360,"wires":[[]]},{"id":"ca7517d3.33cc28","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"middle room on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.middle_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":570,"y":360,"wires":[["cdc3aca5.08143"],["cbde677b.632c38"]]},{"id":"6064f6d0.4437a8","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"middle room off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.middle_room_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1260,"y":300,"wires":[[]]},{"id":"82a0745.6f3c888","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"middle room off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.middle_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1030,"y":360,"wires":[[],["6610b5d.954964c","3a09d9b3.29a026"]]},{"id":"90f193f1.edbb2","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"bathroom cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[24688,29880,27838,32480]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":770,"y":240,"wires":[[]]},{"id":"c98f30a2.e0418","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"bathroom on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.bathroom_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":560,"y":240,"wires":[["90f193f1.edbb2"],["47910bbf.0d9814"]]},{"id":"74dacfc0.1dbb2","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"bathroom off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.bathroom_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1020,"y":240,"wires":[[],["c7b592ff.6918f","ac9fc5ae.a357e8"]]},{"id":"c8bd50b0.feb83","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"entrance off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.entrance_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1010,"y":540,"wires":[[],["eec98a66.7e7e58"]]},{"id":"dedc93eb.38ac2","type":"stoptimer","z":"a4f9ef2c.1a6f4","duration":"1","units":"Second","payloadtype":"num","payloadval":"0","name":"","x":560,"y":60,"wires":[["6e4ba339.f6ff5c"],[]]},{"id":"2c25ec22.fac1f4","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"living room off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.living_room_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1260,"y":60,"wires":[[]]},{"id":"6e4ba339.f6ff5c","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"living room?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.living_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1010,"y":60,"wires":[["2c25ec22.fac1f4"],["b06664fc.0275f8"]]},{"id":"adc241df.aa9d9","type":"trigger-state","z":"a4f9ef2c.1a6f4","name":"cleaning?","server":"820ae6a6.7f40a8","version":0,"entityid":"vacuum.xiaomi_vacuum_cleaner","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"3p107e8yejh","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"returning"},{"id":"vk9pzh79rgp","targetType":"entity_id","targetValue":"input_boolean.zone_cleaning","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on"}],"outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":120,"y":300,"wires":[["5c8a033e.aa765c"],[]]},{"id":"5c8a033e.aa765c","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"roberta stop","server":"820ae6a6.7f40a8","version":3,"service_domain":"vacuum","service":"send_command","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"command\":\"app_pause\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":310,"y":300,"wires":[[]]},{"id":"481c4173.60da","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"timed zone off","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.timed_zone_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":320,"y":540,"wires":[[]]},{"id":"3346be50.6ea5f2","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"Return to base","server":"820ae6a6.7f40a8","version":3,"service_domain":"vacuum","service":"return_to_base","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":320,"y":400,"wires":[[]]},{"id":"fbb1ff01.dac93","type":"trigger-state","z":"a4f9ef2c.1a6f4","name":"end?","server":"820ae6a6.7f40a8","version":0,"entityid":"input_boolean.zone_cleaning","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"j909mrrt2bo","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off"},{"id":"rftm0mofzqn","targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on"}],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":110,"y":400,"wires":[["3346be50.6ea5f2"],[]]},{"id":"100aa88b.0a9aa7","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"toilet cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[23645,31187,24495,32437]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":760,"y":180,"wires":[[]]},{"id":"1c306001.20ec5","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"toilet on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.toilet_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":540,"y":180,"wires":[["100aa88b.0a9aa7"],["c98f30a2.e0418"]]},{"id":"c0bdb260.caac4","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"toilet off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.toilet_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1000,"y":180,"wires":[[],["74dacfc0.1dbb2","25bc721b.7af9de"]]},{"id":"2c810d47.ce08a2","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"storage on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.storage_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":550,"y":480,"wires":[["40eba4a8.0b5f2c"],["371fea9.3b8ea16"]]},{"id":"40eba4a8.0b5f2c","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"storage cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[28580,29741,29480,32491]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":760,"y":480,"wires":[[]]},{"id":"b8bc6073.ed79d","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"entrance cleaning","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"xiaomi_miio","service":"vacuum_clean_zone","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"{\"repeats\":\"1\",\"zone\":[[23603,22935,24753,25035]]}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":770,"y":540,"wires":[[]]},{"id":"371fea9.3b8ea16","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"entrance on?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.entrance_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":550,"y":540,"wires":[["b8bc6073.ed79d"],[]]},{"id":"5996ef08.cf064","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"storage off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.storage_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1010,"y":480,"wires":[[],["c8bd50b0.feb83","eea651e2.a2dcc"]]},{"id":"3a09d9b3.29a026","type":"api-current-state","z":"a4f9ef2c.1a6f4","name":"girls room off?","server":"820ae6a6.7f40a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.girls_room_cleaning","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1020,"y":420,"wires":[[],["5996ef08.cf064","3a52ed90.89e582"]]},{"id":"d80cfd79.3f3ef","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"toilet off","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.toilet_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1240,"y":120,"wires":[[]]},{"id":"25bc721b.7af9de","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"bathroom off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.bathroom_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1250,"y":180,"wires":[[]]},{"id":"3a52ed90.89e582","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"storage off","server":"820ae6a6.7f40a8","version":3,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.storage_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1250,"y":420,"wires":[[]]},{"id":"eea651e2.a2dcc","type":"api-call-service","z":"a4f9ef2c.1a6f4","name":"entrance off off","server":"820ae6a6.7f40a8","version":3,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.entrance_cleaning","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1260,"y":480,"wires":[[]]},{"id":"820ae6a6.7f40a8","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
