This is a really advanced setup, I highly encourage you to wait for a new release of a map card that will have this feature built-in
Thanks @3_14 really looking forward for the next release, and thank you very much again for this work, it is amazing!!
@3_14 is there a plan to include the option to clean non-square rooms (extracted from xiaomi app) instead of zones? my rooms are not square so I still need to use the xiaomi app to clean the different rooms, but adding the rooms to this card would be a complete xiaomi-app-killer for me as I would never need to use it again.
I guess one of the biggest challenges is the non-square rooms cannot be defined with just 4 points, do we even know how xiaomi stores the info?
Yes, cleaning by room will be supported
Hi, im trying to install it through HACS, however it keep spinning and never gets installed
I do see the files are there in
\config\www\community\lovelace-xiaomi-vacuum-map-card
Thoughts?
Anything in logs?
While its spinning during the HACS installation. i saw this in the logs
I did try the manual install as well according to the doc
i have the error “Custom element doesn’t exist: xiaomi-vacuum-map-card.” as well
its under /www/custom_lovelace/xiaomi_vacuum_map_card
Yes i do see the module under my dashboard resource as well
update: it works now, for some reason i cant make it work with HACS but with the manual install its working.
use SERVICE XIAOMI_MIIO.VACUUM_CLEAN_SEGMENT in automation. I can not get a replay of cleaning segments. what to do? thanks in advance to those who helped
They do not need to be on map, no problem here
No, it’s not possible, but you can change fill color for this area to transparent, you will end up with something like this:
You can also trim the map to make it look like this:
So since my last reboot of HA i’m having this 2FA issue again. The card shows:
(It’s hard to read, but it says “Two Factor auth required (see logs)”
In the logs it shows:
If I use the link in the logs (only valid for about 1 minute) I get prompted for 2FA. However, after filling that in and the site showing “ok” the card and the logs still show the error. Reloading the integration results in the same error on the card and in the logs, also generating a new 2FA link.
The previous time I had this issue, it was solved by installing another Xiaomi integration through HACS, that used the same token. However, that doesn’t work this time.
I have rebooted several times, did the 2FA link several times. It just doesn’t work.
Any ideas?
Oh sorry. I thought because someone else mentioned this issue in here, I could too. But I will check out the issues!
Thanks!
@3_14 Hello, Piotr! Could you clarify about Roborock S5/S50 - is it gen1 or a newer one?
My doubts are regarding “saving map” feature: it is turned ON in Mi Home but I have to perform a zone cleaning otherwise a map is shifted every time with respect to my floorplan.
