Valetudo - Xiaomi Vacuum Dustcloud alternative, Live Maps
Okay just got my S5. 311EUR, great deal :slight_smile:
After my floor is clean again now, I will go and root that thing and put Valuto on it later today. I just donā€™t like the idea that when the chinese Invasion starts, the already know how my house looks from the inside hahaha :smiley:
Mine seems to be a transvestite or transgender or gender fluid or some of this modern stuff as hiers name is Robby Rock but when heshe talks to me it is clearly a womens voice :smiley:
So thank you for your thread, will report back when I have success or encounter problems!
Not sure if somebody postet this already, but after rooting you can also use
to easily install valetudo (and control the bot).
And to save some people some time I needed for investigation: RoboRock Control Center asks for your ssh keyfile, that is one of the files created during rooting. If the procedure from the link here was followed it can be found under ~./ssh/id_rsa (not the one with .pub ending)
Did someone try valetudo-mapper from rand256? The original companion app icantbelieveitsnotvaletudo wonā€™t work with newer versions of this valetudo fork.
It seems Iā€™m too stupid to get it to work in portainer :pensive:
My S5 reset for the first time yesterday morning. Iā€™ll give the rand fork a try and will report back.
Is it possible to remote shutdown?
You can use ssh and console command to the robot with ssh keys or just add a cro job if you plan to shutdown the robot regularlyā€¦but why u want to shit down the robot ?
To save energy. Today I started some tests to see what is the consumption in standy by ā€¦ lets see
Thinking of trying Valetudo but wandering if it is possible to install custom voice packs to s50 with this?
This seems possible. Noticed when I installed Valetudo. Anyone could recommend where yo get English male voice pack for s50?
I read on valetudo github 1910 is not safe, do they mean official 1910 mihome?
Yes. The official 1910 firmware from the mihome app. For s50.
Regarding the voice packs. I found from Valetudo Github (https://github.com/Hypfer/Valetudo/issues/165) that there is this ā€œserviceā€ http://moeder.pythonanywhere.com/rockrobo where you can download voice packes and even translate them yourself with predefined voices.
I have finally installed Valetudo, and setup MQTT, and my gen 1 Xiaomi Vacuum added itself to Home Assistant. However when checking the Vacuum card it does not look great.
Why is it not showing the sensor data correctly?
Hi all,
my Valetudo completely disappeared. That happened once already but root and SSH were still in place and I could simply reinstall through robot control center.
This time Valetudo is gone, SSH access is gone and I am unable to flash my custom firmware through flasher.py
(.venv) pi@berry:~ $ python3 flasher.py -f output/v11_001886.fullos.pkg
Flasher for Xiaomi Vacuum
Address is not set. Trying to discover.
Connecting to device 192.168.83.43...
Sending handshake to get token
Got error when receiving: timed out
error while checking device: No response from the device
Before it disappeared I changed nothing, did no updates, I did not even vaccum the last days :see_no_evil:
Anybody else with issues? I found in the dustcloud github, which I used for the root directions, that there is another guy reporting the same.
Are chinese people logging in to my device to ā€œfixā€ it or what it going on :smiley:
I tried Valetudo, but I went back to stock firmware by resetting the device. This made the device install firmware 3062.
With this firmware it works as it should (I have Xiaomi Home set to Mainland China). But when I update to 3452 and 4004 I get a notification saying ā€œPlease select local serverā€. This never happened before? And I am not able to reach the vacuumā€™s settings, neither does the map work on 3452 or 4004.
Why is this? It is not a European model I am using, it is a China version, used on the Chinese mainland server.
I am located in Europe.
Version 4004 worked before trying Valetudo, and I used Mainland china server. I donā€™t want to switch server as I got other chinese Xiaomi devices which requires the Chinese server.
Is it something Valetudo has broken?
How stable are you finding Valetudo? I picked up an S5 on Black Friday and love it! Then I found out about Valetudo but also read about the random resetting. Mine is also running 1886?
Will be interested to hear about your experience
Well just had a reset two days ago, made it 9 weeks. Running the vacuum 5-6 times a weeks. Just reflashed again which was simple so I guess it isnā€™t a huge deal but should would be nice if someone figured it out.
I take it when this happens you loose your saved map with no go areas, virtual barriers etc?
Also with Valetudo are you able to save maps for different floors?
Yeah everything is gone after the reset.
There is a fork of the main project that supports multiple floors but I havenā€™t looked at it. I think there is an MR open for it.
ThTs normal ā€¦ you can extract those sensor attributesā€¦Iā€™m away from home for holidays but pm me and Iā€™ll revert to you once. Iā€™m Home
What is Hypfer/ ICantBelieveItsNotValetudo ? I have installed Valetudo on vaccum.
Do i need to install Hypfer/ ICantBelieveItsNotValetudo again? what is it used for? and where to install? Sorry for the stupid qestions, I am noob without your help.
