Value Template for command line sensor
44
in the first curl command try removing the " from around the entire command like it is in the second curl command.
error
That’s because you left the " at the end. Remove that and try it again.
maybe i think thats a tricky problem …
try it by removing the P from the command
“… | grep -o …”
what means this ?
I have no idea why its not working for you.
The only thing i can think is that there is some difference between hassos and Debian in the way grep works. As I said the command I provided works for me in Debian.
I don’t think I can be of any more help.
with this value template :
value_template: “{{ value.split(‘’)[1].split(‘D_A_1_1>’)[1] }}”
i get from this response :
HTTP/1.1 200 OK Content-Type: text/html; charset=UTF-8 Accept-Ranges: bytes Connection: close ok <D_A_1_1>0.00</D_A_1_1>
as answer
0.00</
i am on a good way. How can i the < and / with the template remove ?
This should work but I’m not at my desk now to check it.
“{{ value.split(’ `’)[1].split(‘D_A_1_1>’)[1][:-2] }}”
"{{ value | regex_findall_index('<D_A_1_1>(.*)</D_A_1_1>') }}"
Screenshot%20from%202019-04-01%2014-17-25
