Yep.
I’ve never seen it used here, but try splitline()[n]
instead of split(" ")[n]
Yep.
this : ‘{{ states.sensor.niko.state.splitline()[1] | int == 100 }}’
gives:
Error rendering template: UndefinedError: ‘str object’ has no attribute ‘splitline’
Help is at hand. Wait for it…
this should work
{% set light = '16' %}
{% set lights = '16 100 22 0 23 0 25 0 55 0 33 0 34 0 40 0 42 0 43 0 44 0 49 0 50 100 51 0 52 0 54 100 56 0 61 0' %}
{%- macro getlight(name, instring) %}
{%- set values = instring.splitlines() %}
{%- for i in range(0, values | length, 2) %}
{%- if name == values[i] %}
{{ values[i+1] }}
{%- endif %}
{%- endfor %}
{%- endmacro %}
{%- set brightness = getlight(light, lights).strip() %}
{%- if brightness != '' %}
{{ 'on' if brightness == '100' else 'off' }}
{%- else %}
undefined
{%- endif %}
Just replace lights with wherever you’re getting the list. And change the number ‘16’ to whatever id light you want.
omg
well , seems this also worked, ‘{{ states.sensor.niko.state.splitlines()[1] | int == 100 }}’
you forgot the ‘s’ of splitlines
gonna try your code also later @petro
thnx so much guys
Trouble is the list is not separated by spaces but carriage returns or newlines.
Say what? who did that.
my netcat command did
carriage returns are \n
or \r\n
depending on the language
ok, splitlines ,is working
thnx!!!
really appreciate it
splitlines() does both cases I think, which is why I went for it.
I don’t know to be honest. It may try all the possible combinations.
I updated the code I wrote to handle the carriage returns.
Ok, thbx Petro
If there was a contest to produce an awkward reporting protocol, this device would win it.
What kind of lighting device is it?
Niko home control
