As you say - not much we can do if Vera isn’t picking up the raw data.
But happy to help add any missing devices to pyvera if you’d like to.
@gregd yeah I still haven’t figured out the Vera piece. However if you want to add some other missing bits I would be grateful. One thing missing is the energy monitor data. I had to parse it out of the raw XML using @pembo’s scripts. Another seems to be the multi-sensors I just picked up (Monoprice - re-branded Vision ZP3111-5). They seem a bit odd though, with individual “devices” and a parent. I’ve dumped the raw XML here for review: https://pastebin.com/CwpvmtaL
What additional information/steps from me are needed to get some of this into pyvera? Thanks so much!!
I’ve added an issue here for the power meters. https://github.com/pavoni/pyvera/issues/47
I can add the device type - and a couple of useful attributes (watts and kwh) to pyvera.
Will then need to check if it works and updates properly - and integrate with HA.
Are you a developer?
Multi-sensors normally just work by adding the child devices - which are the devices you’re missing?
Sweet, thanks!
Not really, though I know enough Python to be dangerous.
Scratch the multi-sensor comment. They are showing up properly. Just took a couple of restarts of HA, not sure why.
@pembo working with @gregd to get this added. Can you help test here please: https://github.com/home-assistant/home-assistant/pull/7134
