Hi Per,
Sorry for the late reply.
The latest changes makes the services work, both enable
and disable
However, the error handling is still not that great.
If you try to connect using an invalid/non existing device_serial
you still get an unkown error
. the same goes if you use an invalid user or password for verisure. Seems the returned response from Verisure is not handled correctly:
2019-11-09 22:26:59 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=verisure, service=enable_autolock, service_data=device_serial=3ANF BKTT>
2019-11-09 22:26:59 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139740416218768] Expecting value: line 1 column 1 (char 0)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1233, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1258, in _execute_service
await handler.func(service_call)
File "/config/custom_components/verisure/__init__.py", line 128, in enable_autolock
await hass.async_add_executor_job(HUB.enable_autolock, device_id)
File "/config/custom_components/verisure/__init__.py", line 214, in enable_autolock
self.session.set_lock_config(device_id, auto_lock_enabled=True)
File "/usr/local/lib/python3.7/site-packages/verisure/session.py", line 394, in set_lock_config
_validate_response(response)
File "/usr/local/lib/python3.7/site-packages/verisure/session.py", line 16, in _validate_response
raise ResponseError(response.status_code, response.text)
File "/usr/local/lib/python3.7/site-packages/verisure/session.py", line 43, in __init__
self.text = json.loads(text)
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2019-11-09 22:26:59 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.139740416218768] Sending {'id': 18, 'type': 'result', 'success': False, 'error': {'code': 'unknown_error', 'message': 'Expecting value: line 1 column 1 (char 0)'}}
