I dont want to jinx myself, and I honestly dont know why it worked, but I downgraded Fully Kiosk from v1.48 to v1.46 and it is working as expected for almost 24 hours now.
Mind you, this is on two of my 6 tablets. The other four are working just fine on v1.48.
I am seeing similar behavior where my typical dashboard is 3 columns wide using built-in vertical and horizontal cards. It has been this way for a month or so. I made a single change by adding a card and suddenly everything is in a single column. See my screenshot. I zoomed out in chrome to show the full perspective. I tried an incognito window. This happens on both my laptop and Amazon Fire tablet with Fully Kiosk in full screen mode using desktop view.
In edit mode to show the vertical stack groupings.
I just found it. I had an extra horizontal stack in my first vertical stack that must have been leftover from something I removed in the stack. I deleted that in the yaml and boom, back to multiple columns. Seems different than the other reports but worth nothing for others.
My table Amazon Fire HD 10, Kiosk Browser, sometimes it loads all vertical stacks in the middle.
Also on the laptop now when Iām toggling through my different menus everything is stacked on top of each other in the middle and then expands out. Weird
Late to the party here, but wanted to share my solution to others who are still struggling.
On my dashboard I have multiple vertical and horizontal stacks. If you combine all of your cards you want on top of each other in one vertical stack, and then combine all of your vertical stacks in to one big horizontal stack, filling the whole dashboard.
You now basically have only one big card on your dashboard that can not be moved around after reload etc. This makes editing cards more complicated afterwards but it solved my problem.
This method requires the layout-card and setting layout width to something like 1000.
