Thanks for having replied
Why is it necessary to change the MQTT discovery prefix ? Does Viseron use a specific prefix for MQTT ?
What I do not understand is why I cannot see in Mosquitto Broker logs the IP address of Viseron (172.17.0.3)
The IP address of the MQTT broker is the same as my server (all containers are on the same sever) ?
I have tried to follow the MQTT discovery tutorial, but it unfortunately did not work for me (the test is stuck)
Viseron config.yaml
# See the README for the full list of configuration options.
cameras:
- name: Front Door
mqtt_name: viseron_front_door
host: !secret camera_ip
port: 554
username: !secret username
password: !secret password
path: //h264Preview_01_main
fps: 30
width: 2560
height: 1920
stream_format: rtsp
publish_image: true
motion_detection:
interval: 1
trigger_detector: false
# timeout: true
# max_timeout: 30
# width: 300
# height: 300
# area: 0.1
# frames: 3
object_detection:
interval: 1
labels:
- label: person
confidence: 0.8
- label: cat
confidence: 0.6
recorder:
lookback: 60
timeout: 120
retain: 365
folder: /recordings
thumbnail:
save_to_disk: true
send_to_mqtt: true
# MQTT is optional
mqtt:
broker: 192.168.10.2
port: 1883
username: XXX
password: XXX
logging:
level: debug
Viseron logs:
[2021-06-06 14:43:16] [root ] [INFO ] - -------------------------------------------,
[2021-06-06 14:43:16] [root ] [INFO ] - Initializing...,
[2021-06-06 14:43:16] [root ] [DEBUG ] - Starting cleanup scheduler,
[2021-06-06 14:43:16] [root ] [DEBUG ] - Running initial cleanup,
[2021-06-06 14:43:16] [lib.cleanup ] [DEBUG ] - Running cleanup,
[2021-06-06 14:43:16] [lib.cleanup ] [DEBUG ] - Items in /recordings/2021-06-04: 1,
[2021-06-06 14:43:16] [lib.cleanup ] [DEBUG ] - Items in /recordings/2021-06-05: 1,
[2021-06-06 14:43:16] [lib.cleanup ] [DEBUG ] - Items in /recordings/2021-05-31: 1,
[2021-06-06 14:43:16] [lib.cleanup ] [DEBUG ] - Items in /recordings/2021-06-06: 1,
[2021-06-06 14:43:16] [lib.mqtt ] [INFO ] - Initializing MQTT connection,
[2021-06-06 14:43:16] [lib.detector ] [DEBUG ] - Initializing object detector darknet,
[2021-06-06 14:43:16] [lib.detector ] [DEBUG ] - OpenCL activated,
[2021-06-06 14:43:16] [lib.detector ] [DEBUG ] - Object detector initialized,
[2021-06-06 14:43:16] [root ] [INFO ] - Initializing NVR threads,
[2021-06-06 14:43:16] [lib.nvr.front_door ] [DEBUG ] - Initializing NVR thread,
[2021-06-06 14:43:16] [lib.camera.front_door ] [DEBUG ] - Initializing camera Front Door,
[2021-06-06 14:43:16] [lib.camera.front_door ] [DEBUG ] - Getting stream information for rtsp://xxxx:[email protected]:554//h264Preview_01_main,
MQTT broker logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] mosquitto.sh: executing... ,
[13:12:56] INFO: SSL is not enabled,
[cont-init.d] mosquitto.sh: exited 0.,
[cont-init.d] nginx.sh: executing... ,
[cont-init.d] nginx.sh: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
[13:12:57] INFO: Starting NGINX for authentication handling...,
[13:12:57] INFO: Starting mosquitto MQTT broker...,
1622977977: mosquitto version 1.6.12 starting,
1622977977: |-- *** auth-plug: startup,
[13:12:57] INFO: Successfully send discovery information to Home Assistant.,
[13:12:57] INFO: Successfully send service information to the Supervisor.,
1622977977: Config loaded from /etc/mosquitto/mosquitto.conf.,
1622977977: Loading plugin: /usr/share/mosquitto/auth-plug.so,
1622977977: ├── Username/password checking enabled.,
1622977977: ├── TLS-PSK checking enabled.,
1622977977: └── Extended authentication not enabled.,
1622977977: Opening ipv4 listen socket on port 1883.,
1622977977: Opening ipv6 listen socket on port 1883.,
1622977977: Opening websockets listen socket on port 1884.,
1622977977: Warning: Mosquitto should not be run as root/administrator.,
1622977977: mosquitto version 1.6.12 running,
1622977977: New connection from 127.0.0.1 on port 1883.,
1622977977: Socket error on client <unknown>, disconnecting.,
1622977983: New connection from 172.30.33.2 on port 1883.,
1622977983: New client connected from 172.30.33.2 as mosq-KhN02P1FYxJ093adpz (p2, c1, k60, u'addons').,
1622977983: Client mosq-KhN02P1FYxJ093adpz disconnected.,
1622977984: New connection from 172.30.33.2 on port 1883.,
1622977984: New client connected from 172.30.33.2 as mosq-3vb54eT5JHbOAbMU9J (p2, c1, k60, u'addons').,
1622977984: Client mosq-3vb54eT5JHbOAbMU9J disconnected.,
1622977984: New bridge connected from 172.30.33.2 as zwave (p2, c1, k60, u'addons').,
1622977990: New connection from 172.30.32.1 on port 1883.,
{"result": "ok", "data": {}}1622977990: New client connected from 172.30.32.1 as 4kFVBcF1f9c2xzPbl6UESR (p2, c1, k60, u'Matthieu').,
1622978016: New connection from 172.30.33.3 on port 1883.,
1622978016: New client connected from 172.30.33.3 as mqttjs_9829a5e9 (p2, c1, k60, u'addons').,
1622979778: Saving in-memory database to /data/mosquitto.db.,
1622981579: Saving in-memory database to /data/mosquitto.db.,
1622983299: New connection from 172.30.33.1 on port 1883.,
1622983299: New client connected from 172.30.33.1 as mosq-cRVebsMRVAl91oTcja (p2, c1, k60).,
1622983299: Client mosq-cRVebsMRVAl91oTcja disconnected.,
1622983363: New connection from 172.30.32.1 on port 1883.,
1622983363: New client connected from 172.30.32.1 as mosq-pdG4WLHei7q3cxsamc (p2, c1, k60).,
