The easiest way is to use the camera entity created in HA that ends with latest_thumbnail
See here in the README
Can you advise a solution, please?
After some period of time I get:
[2021-04-12 11:04:59] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 52, max area size: 0.01792
[2021-04-12 11:04:59] [lib.camera.frontyard ] [WARNING ] - object_detection input queue is full. Removing oldest entry
[2021-04-12 11:04:59] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 53, max area size: 0.01818
[2021-04-12 11:04:59] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 54, max area size: 0.01829
[2021-04-12 11:04:59] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 55, max area size: 0.01802
[2021-04-12 11:04:59] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 56, max area size: 0.01802
[2021-04-12 11:05:00] [lib.camera.frontyard ] [WARNING ] - object_detection input queue is full. Removing oldest entry
[2021-04-12 11:05:00] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 57, max area size: 0.01734
[2021-04-12 11:05:00] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 58, max area size: 0.01693
[2021-04-12 11:05:00] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 59, max area size: 0.01642
[2021-04-12 11:05:00] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 60, max area size: 0.01585
[2021-04-12 11:05:00] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 61, max area size: 0.01521
[2021-04-12 11:05:01] [lib.camera.frontyard ] [WARNING ] - object_detection input queue is full. Removing oldest entry
[2021-04-12 11:05:01] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 62, max area size: 0.01503
[2021-04-12 11:05:01] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 63, max area size: 0.01443
[2021-04-12 11:05:01] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 64, max area size: 0.01363
[2021-04-12 11:05:01] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 65, max area size: 0.01248
[2021-04-12 11:05:01] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 66, max area size: 0.01189
[2021-04-12 11:05:02] [lib.camera.frontyard ] [WARNING ] - object_detection input queue is full. Removing oldest entry
[2021-04-12 11:05:02] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 67, max area size: 0.01079
[2021-04-12 11:05:02] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 68, max area size: 0.00987
[2021-04-12 11:05:02] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 69, max area size: 0.00881
[2021-04-12 11:05:02] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 70, max area size: 0.00772
[2021-04-12 11:05:02] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 71, max area size: 0.00653
[2021-04-12 11:05:03] [lib.camera.frontyard ] [WARNING ] - object_detection input queue is full. Removing oldest entry
And object detection doesn’t do the job, files are not recording to disk, not sending by MQTT.
Can you try the latest beta? 1.8.0b5.
It uses a new method to send data which should solve the problem with full queues.
Could you please point to Cuda version for latest beta?
I see only roflcoopter/viseron-cuda:1.8.0b1
@roflcoopter Time and again problem appears. Please advise proper Cuda version with bugfixes. Thanks!
Yes sorry, the names have changed. Its now roflcoopter/amd64-cuda-viseron
@roflcoopter
I tried the latest beta. With an unchanged config from previous version, Object detection doesn’t work at all.
Motion is detected normally, objects are colored, but when motion is running no objects are labeled and detected. Strange…
[2021-04-15 09:47:11] [lib.nvr.frontyard ] [DEBUG ] - Starting object detector
[2021-04-15 09:47:11] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 4, max area size: 0.00994
[2021-04-15 09:47:12] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 5, max area size: 0.01191
[2021-04-15 09:47:12] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 6, max area size: 0.01284
[2021-04-15 09:47:12] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 7, max area size: 0.01359
[2021-04-15 09:47:12] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 8, max area size: 0.01455
[2021-04-15 09:47:12] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 9, max area size: 0.01717
[2021-04-15 09:47:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 10, max area size: 0.01713
[2021-04-15 09:47:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 11, max area size: 0.01719
[2021-04-15 09:47:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 12, max area size: 0.01844
[2021-04-15 09:47:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 13, max area size: 0.01891
[2021-04-15 09:47:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 14, max area size: 0.01933
[2021-04-15 09:47:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 15, max area size: 0.02007
[2021-04-15 09:47:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 16, max area size: 0.0202
[2021-04-15 09:47:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 17, max area size: 0.01856
[2021-04-15 09:47:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 18, max area size: 0.02064
[2021-04-15 09:47:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 19, max area size: 0.02191
[2021-04-15 09:47:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 20, max area size: 0.02228
[2021-04-15 09:47:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 21, max area size: 0.02143
[2021-04-15 09:47:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 22, max area size: 0.02124
[2021-04-15 09:47:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 23, max area size: 0.02048
[2021-04-15 09:47:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 24, max area size: 0.02017
[2021-04-15 09:47:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 25, max area size: 0.01955
[2021-04-15 09:47:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 26, max area size: 0.01887
[2021-04-15 09:47:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 27, max area size: 0.01939
[2021-04-15 09:47:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 28, max area size: 0.01972
[2021-04-15 09:47:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 29, max area size: 0.01952
[2021-04-15 09:47:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 30, max area size: 0.01849
[2021-04-15 09:47:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 31, max area size: 0.01717
[2021-04-15 09:47:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 32, max area size: 0.0166
[2021-04-15 09:47:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 33, max area size: 0.01521
[2021-04-15 09:47:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 34, max area size: 0.01345
[2021-04-15 09:47:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 35, max area size: 0.01173
[2021-04-15 09:47:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 36, max area size: 0.00962
[2021-04-15 09:47:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 37, max area size: 0.00852
[2021-04-15 09:47:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 38, max area size: 0.00864
[2021-04-15 09:47:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 39, max area size: 0.00779
[2021-04-15 09:47:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 40, max area size: 0.00936
[2021-04-15 09:47:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 41, max area size: 0.01084
[2021-04-15 09:47:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 42, max area size: 0.01193
[2021-04-15 09:47:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 43, max area size: 0.01324
[2021-04-15 09:47:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 44, max area size: 0.01281
[2021-04-15 09:47:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 45, max area size: 0.01258
[2021-04-15 09:47:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 46, max area size: 0.01302
[2021-04-15 09:47:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 47, max area size: 0.01291
[2021-04-15 09:47:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 48, max area size: 0.01454
[2021-04-15 09:47:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 49, max area size: 0.01518
[2021-04-15 09:47:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 50, max area size: 0.01656
[2021-04-15 09:47:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 51, max area size: 0.01798
[2021-04-15 09:47:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 52, max area size: 0.01818
[2021-04-15 09:47:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 53, max area size: 0.02017
[2021-04-15 09:47:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 54, max area size: 0.02039
[2021-04-15 09:47:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 55, max area size: 0.02086
[2021-04-15 09:47:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 56, max area size: 0.02152
[2021-04-15 09:47:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 57, max area size: 0.02309
[2021-04-15 09:47:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 58, max area size: 0.02321
[2021-04-15 09:47:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 59, max area size: 0.02427
[2021-04-15 09:47:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 60, max area size: 0.02593
[2021-04-15 09:47:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 61, max area size: 0.02682
[2021-04-15 09:47:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 62, max area size: 0.02701
[2021-04-15 09:47:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 63, max area size: 0.0266
[2021-04-15 09:47:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 64, max area size: 0.02497
[2021-04-15 09:47:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 65, max area size: 0.02406
[2021-04-15 09:47:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 66, max area size: 0.02369
[2021-04-15 09:47:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 67, max area size: 0.02176
[2021-04-15 09:47:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 68, max area size: 0.02061
[2021-04-15 09:47:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 69, max area size: 0.02023
[2021-04-15 09:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 70, max area size: 0.01874
[2021-04-15 09:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 71, max area size: 0.0172
[2021-04-15 09:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 72, max area size: 0.01566
[2021-04-15 09:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 73, max area size: 0.01461
[2021-04-15 09:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 74, max area size: 0.01309
[2021-04-15 09:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 75, max area size: 0.01188
[2021-04-15 09:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 76, max area size: 0.01062
[2021-04-15 09:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 77, max area size: 0.00942
[2021-04-15 09:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 78, max area size: 0.00734
[2021-04-15 09:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 79, max area size: 0.00592
[2021-04-15 09:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 80, max area size: 0.00403
[2021-04-15 09:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Motion stopped
[2021-04-15 09:47:27] [lib.nvr.frontyard ] [DEBUG ] - Not recording, pausing object detector
May i see your config?
Sure, here it is:
cameras:
- name: FrontYard
host: 192.168.0.4
port: 554
username: root
password: pass
path: /axis-media/media.amp?streamprofile=viseron
publish_image: true
fps: 10
motion_detection:
area: 0.003
interval: 0.25
threshold: 4
trigger_detector: true
timeout: true
max_timeout: 2
mask:
- x: 0
y: 42
- x: 392
y: 42
- x: 392
y: 0
- x: 0
y: 0
zones:
- name: front
- x: 0
y: 835
- x: 231
y: 379
- x: 569
y: 321
- x: 976
y: 291
- x: 1319
y: 298
- x: 1520
y: 318
- x: 1721
y: 386
- x: 1920
y: 620
- x: 1920
y: 1077
- x: 0
y: 1077
labels:
- label: person
confidence: 0.75
triggers_recording: true
object_detection:
interval: 0.25
labels:
- label: person
triggers_recording: false
object_detection:
interval: 0.25
labels:
- label: person
recorder:
lookback: 2
timeout: 3
retain: 3
folder: /recordings
thumbnail:
save_to_disk: true
send_to_mqtt: true
mqtt:
broker: 192.168.0.3
port: 1883
username: admin
password: pass
logging:
level: debug
Ahh i see, and you except to get log output for the objects?
There seems to be a bug with the set loglevel.
Do you get expected results if you try this?
cameras:
- name: FrontYard
host: 192.168.0.4
port: 554
username: root
password: pass
publish_image: true
fps: 10
motion_detection:
area: 0.003
interval: 0.25
threshold: 4
timeout: true
max_timeout: 2
mask:
- x: 0
y: 42
- x: 392
y: 42
- x: 392
y: 0
- x: 0
y: 0
zones:
- name: front
- x: 0
y: 835
- x: 231
y: 379
- x: 569
y: 321
- x: 976
y: 291
- x: 1319
y: 298
- x: 1520
y: 318
- x: 1721
y: 386
- x: 1920
y: 620
- x: 1920
y: 1077
- x: 0
y: 1077
labels:
- label: person
confidence: 0.75
object_detection:
interval: 0.25
labels:
- label: person
object_detection:
interval: 0.25
labels:
- label: person
# I added this part ------
logging:
level: debug
log_all_objects: true
recorder:
lookback: 2
timeout: 3
retain: 3
folder: /recordings
thumbnail:
save_to_disk: true
send_to_mqtt: true
mqtt:
broker: 192.168.0.3
port: 1883
username: admin
password: pass
logging:
level: debug
Nothing changed.
It looks like you changed object detection sensitivity in the new beta version. I even decreased Motion detection parameters making them more aggressive (like below), but objects are not detected like in the previous release version. They are getting coloured (motion detection covers objects entirely), but no object detection is registered in logs and in fact (interface, mqtt). Any other suggestion?
During this time frame there was a lot of motion/person movement, but Viseron was blind:
[2021-04-15 16:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 49, max area size: 0.01833
[2021-04-15 16:47:25] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 50, max area size: 0.01921
[2021-04-15 16:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 51, max area size: 0.0224
[2021-04-15 16:47:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 52, max area size: 0.02446
[2021-04-15 16:47:26] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 53, max area size: 0.02154
[2021-04-15 16:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 54, max area size: 0.02447
[2021-04-15 16:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 55, max area size: 0.02432
[2021-04-15 16:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 56, max area size: 0.02363
[2021-04-15 16:47:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 57, max area size: 0.02348
[2021-04-15 16:47:27] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 58, max area size: 0.02297
[2021-04-15 16:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 59, max area size: 0.01999
[2021-04-15 16:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 60, max area size: 0.01982
[2021-04-15 16:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 61, max area size: 0.01834
[2021-04-15 16:47:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 62, max area size: 0.01708
[2021-04-15 16:47:28] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:47:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 63, max area size: 0.01568
[2021-04-15 16:47:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 64, max area size: 0.01441
[2021-04-15 16:47:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 65, max area size: 0.01326
[2021-04-15 16:47:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 66, max area size: 0.01218
[2021-04-15 16:47:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 67, max area size: 0.01092
[2021-04-15 16:47:29] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:47:29] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 68, max area size: 0.00992
[2021-04-15 16:47:29] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 69, max area size: 0.00906
[2021-04-15 16:47:29] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 70, max area size: 0.00819
[2021-04-15 16:47:29] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 71, max area size: 0.00666
[2021-04-15 16:47:29] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 72, max area size: 0.00569
[2021-04-15 16:47:30] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:47:30] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 73, max area size: 0.00443
[2021-04-15 16:47:30] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 74, max area size: 0.00304
[2021-04-15 16:47:30] [lib.nvr.frontyard.motion] [DEBUG ] - Motion stopped
[2021-04-15 16:47:30] [lib.nvr.frontyard ] [DEBUG ] - Not recording, pausing object detector
[2021-04-15 16:48:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00296
[2021-04-15 16:48:13] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 2, max area size: 0.00378
[2021-04-15 16:48:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 3, max area size: 0.00402
[2021-04-15 16:48:14] [lib.nvr.frontyard.motion] [DEBUG ] - Motion detected
[2021-04-15 16:48:14] [lib.nvr.frontyard ] [DEBUG ] - Starting object detector
[2021-04-15 16:48:14] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 4, max area size: 0.00462
[2021-04-15 16:48:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 5, max area size: 0.0044
[2021-04-15 16:48:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 6, max area size: 0.0051
[2021-04-15 16:48:14] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 7, max area size: 0.00515
[2021-04-15 16:48:15] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 8, max area size: 0.00631
[2021-04-15 16:48:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 9, max area size: 0.00692
[2021-04-15 16:48:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 10, max area size: 0.00728
[2021-04-15 16:48:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 11, max area size: 0.00809
[2021-04-15 16:48:15] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 12, max area size: 0.00853
[2021-04-15 16:48:16] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 13, max area size: 0.00926
[2021-04-15 16:48:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 14, max area size: 0.01008
[2021-04-15 16:48:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 15, max area size: 0.01057
[2021-04-15 16:48:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 16, max area size: 0.01103
[2021-04-15 16:48:16] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 17, max area size: 0.01191
[2021-04-15 16:48:17] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 18, max area size: 0.00983
[2021-04-15 16:48:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 19, max area size: 0.01033
[2021-04-15 16:48:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 20, max area size: 0.01946
[2021-04-15 16:48:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 21, max area size: 0.02078
[2021-04-15 16:48:17] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 22, max area size: 0.02212
[2021-04-15 16:48:18] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 23, max area size: 0.01343
[2021-04-15 16:48:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 24, max area size: 0.01413
[2021-04-15 16:48:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 25, max area size: 0.01442
[2021-04-15 16:48:18] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 26, max area size: 0.0148
[2021-04-15 16:48:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 27, max area size: 0.01505
[2021-04-15 16:48:19] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 28, max area size: 0.01519
[2021-04-15 16:48:19] [lib.nvr.frontyard.object] [DEBUG ] - All objects: [], message repeated 2 times
[2021-04-15 16:48:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 29, max area size: 0.01532
[2021-04-15 16:48:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 30, max area size: 0.01569
[2021-04-15 16:48:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 31, max area size: 0.01553
[2021-04-15 16:48:19] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 32, max area size: 0.01538
[2021-04-15 16:48:20] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 33, max area size: 0.01537
[2021-04-15 16:48:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 34, max area size: 0.01558
[2021-04-15 16:48:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 35, max area size: 0.0163
[2021-04-15 16:48:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 36, max area size: 0.01694
[2021-04-15 16:48:20] [lib.nvr.sosed.motion ] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00376
[2021-04-15 16:48:20] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 37, max area size: 0.01833
[2021-04-15 16:48:20] [lib.nvr.sosed.motion ] [DEBUG ] - Consecutive frames with motion: 2, max area size: 0.00302
[2021-04-15 16:48:21] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 38, max area size: 0.01995
[2021-04-15 16:48:21] [lib.nvr.sosed.motion ] [DEBUG ] - Consecutive frames with motion: 3, max area size: 0.00328
[2021-04-15 16:48:21] [lib.nvr.sosed.motion ] [DEBUG ] - Motion detected
[2021-04-15 16:48:21] [lib.nvr.sosed ] [DEBUG ] - Starting object detector
[2021-04-15 16:48:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 39, max area size: 0.02076
[2021-04-15 16:48:21] [lib.nvr.sosed.motion ] [DEBUG ] - Consecutive frames with motion: 4, max area size: 0.00306
[2021-04-15 16:48:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 40, max area size: 0.02217
[2021-04-15 16:48:21] [lib.nvr.sosed.object ] [DEBUG ] - All objects: []
[2021-04-15 16:48:21] [lib.nvr.sosed.motion ] [DEBUG ] - Motion stopped
[2021-04-15 16:48:21] [lib.nvr.sosed ] [DEBUG ] - Not recording, pausing object detector
[2021-04-15 16:48:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 41, max area size: 0.02402
[2021-04-15 16:48:21] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 42, max area size: 0.02616
[2021-04-15 16:48:22] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 43, max area size: 0.02703
[2021-04-15 16:48:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 44, max area size: 0.02911
[2021-04-15 16:48:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 45, max area size: 0.03049
[2021-04-15 16:48:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 46, max area size: 0.03539
[2021-04-15 16:48:22] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 47, max area size: 0.0361
[2021-04-15 16:48:23] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 48, max area size: 0.03643
[2021-04-15 16:48:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 49, max area size: 0.03749
[2021-04-15 16:48:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 50, max area size: 0.03713
[2021-04-15 16:48:23] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 51, max area size: 0.03858
[2021-04-15 16:48:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 52, max area size: 0.03821
[2021-04-15 16:48:24] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 53, max area size: 0.03972
[2021-04-15 16:48:24] [lib.nvr.frontyard.object] [DEBUG ] - All objects: [], message repeated 2 times
[2021-04-15 16:48:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 54, max area size: 0.04087
[2021-04-15 16:48:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 55, max area size: 0.03984
[2021-04-15 16:48:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 56, max area size: 0.03063
[2021-04-15 16:48:24] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 57, max area size: 0.02968
[2021-04-15 16:48:25] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 58, max area size: 0.02888
[2021-04-15 16:48:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 59, max area size: 0.02909
[2021-04-15 16:48:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 60, max area size: 0.02767
[2021-04-15 16:48:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 61, max area size: 0.02671
[2021-04-15 16:48:25] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 62, max area size: 0.0247
[2021-04-15 16:48:25] [lib.nvr.sosed.motion ] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00401
[2021-04-15 16:48:26] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 63, max area size: 0.02173
[2021-04-15 16:48:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 64, max area size: 0.01902
[2021-04-15 16:48:26] [lib.nvr.sosed.motion ] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00353
[2021-04-15 16:48:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 65, max area size: 0.01787
[2021-04-15 16:48:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 66, max area size: 0.01462
[2021-04-15 16:48:26] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 67, max area size: 0.01298
[2021-04-15 16:48:27] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 68, max area size: 0.01186
[2021-04-15 16:48:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 69, max area size: 0.0102
[2021-04-15 16:48:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 70, max area size: 0.00403
[2021-04-15 16:48:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 71, max area size: 0.00395
[2021-04-15 16:48:27] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 72, max area size: 0.00386
[2021-04-15 16:48:28] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 73, max area size: 0.00351
[2021-04-15 16:48:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 74, max area size: 0.00296
[2021-04-15 16:48:28] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 75, max area size: 0.00238
[2021-04-15 16:48:28] [lib.nvr.frontyard.motion] [DEBUG ] - Motion stopped
[2021-04-15 16:48:28] [lib.nvr.frontyard ] [DEBUG ] - Not recording, pausing object detector
[2021-04-15 16:48:48] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00204
[2021-04-15 16:48:49] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 2, max area size: 0.00409
[2021-04-15 16:48:49] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 3, max area size: 0.00449
[2021-04-15 16:48:49] [lib.nvr.frontyard.motion] [DEBUG ] - Motion detected
[2021-04-15 16:48:49] [lib.nvr.frontyard ] [DEBUG ] - Starting object detector
[2021-04-15 16:48:49] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:49] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 4, max area size: 0.00557
[2021-04-15 16:48:49] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 5, max area size: 0.00633
[2021-04-15 16:48:49] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 6, max area size: 0.00751
[2021-04-15 16:48:50] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:50] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 7, max area size: 0.00733
[2021-04-15 16:48:50] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 8, max area size: 0.00748
[2021-04-15 16:48:50] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 9, max area size: 0.00637
[2021-04-15 16:48:50] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 10, max area size: 0.0071
[2021-04-15 16:48:50] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 11, max area size: 0.00778
[2021-04-15 16:48:51] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:51] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 12, max area size: 0.00728
[2021-04-15 16:48:51] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 13, max area size: 0.00775
[2021-04-15 16:48:51] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 14, max area size: 0.00913
[2021-04-15 16:48:51] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 15, max area size: 0.00909
[2021-04-15 16:48:51] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 16, max area size: 0.00773
[2021-04-15 16:48:52] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:52] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 17, max area size: 0.00898
[2021-04-15 16:48:52] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 18, max area size: 0.01025
[2021-04-15 16:48:52] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 19, max area size: 0.01004
[2021-04-15 16:48:52] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 20, max area size: 0.00943
[2021-04-15 16:48:52] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 21, max area size: 0.00981
[2021-04-15 16:48:53] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:53] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 22, max area size: 0.00593
[2021-04-15 16:48:53] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 23, max area size: 0.00609
[2021-04-15 16:48:53] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 24, max area size: 0.00579
[2021-04-15 16:48:53] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 25, max area size: 0.00568
[2021-04-15 16:48:54] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:54] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 26, max area size: 0.00508
[2021-04-15 16:48:54] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 27, max area size: 0.00479
[2021-04-15 16:48:54] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 28, max area size: 0.00691
[2021-04-15 16:48:54] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 29, max area size: 0.00611
[2021-04-15 16:48:54] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 30, max area size: 0.00549
[2021-04-15 16:48:54] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 31, max area size: 0.00425
[2021-04-15 16:48:55] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:55] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 32, max area size: 0.00337
[2021-04-15 16:48:55] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 33, max area size: 0.00392
[2021-04-15 16:48:55] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 34, max area size: 0.00537
[2021-04-15 16:48:55] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 35, max area size: 0.00452
[2021-04-15 16:48:55] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 36, max area size: 0.00529
[2021-04-15 16:48:56] [lib.nvr.frontyard.object] [DEBUG ] - All objects: []
[2021-04-15 16:48:56] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 37, max area size: 0.0043
[2021-04-15 16:48:56] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 38, max area size: 0.00397
[2021-04-15 16:48:56] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 39, max area size: 0.00427
[2021-04-15 16:48:56] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 40, max area size: 0.00243
[2021-04-15 16:48:56] [lib.nvr.frontyard.motion] [DEBUG ] - Motion stopped
[2021-04-15 16:48:56] [lib.nvr.frontyard ] [DEBUG ] - Not recording, pausing object detector
[2021-04-15 16:48:57] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00212
[2021-04-15 16:48:57] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00223
[2021-04-15 16:48:57] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 2, max area size: 0.00211
[2021-04-15 16:48:58] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00231
[2021-04-15 16:48:59] [lib.nvr.frontyard.motion] [DEBUG ] - Consecutive frames with motion: 1, max area size: 0.00219
What does your docker run command look like?
Edit: And can you show me the output of nvidia-smi?
I did not change any config since the last release version.
Here’s the date you requested:
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 1650 On | 00000000:01:00.0 Off | N/A |
| 60% 62C P2 N/A / 75W | 1458MiB / 3903MiB | 4% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1109 G /usr/lib/xorg/Xorg 9MiB |
| 0 N/A N/A 1264 G /usr/bin/gnome-shell 2MiB |
| 0 N/A N/A 325783 C python3 796MiB |
| 0 N/A N/A 325823 C ffmpeg 161MiB |
| 0 N/A N/A 325830 C ffmpeg 161MiB |
| 0 N/A N/A 325836 C ffmpeg 161MiB |
| 0 N/A N/A 325842 C ffmpeg 161MiB |
Docker run:
docker run -d --restart unless-stopped \
-v /usr/share/hassio/media/viseron:/recordings \
-v /usr/share/hassio/homeassistant/viseron:/config \
-v /etc/localtime:/etc/localtime:ro \
--name viseron \
--runtime=nvidia \
roflcoopter/amd64-cuda-viseron:1.8.0b5
Strange… I myself is using the cuda version which is working perfectly fine.
Can you paste the full log from startup?
Please see the full logs:
https://ctxt.io/2/AACgnYT8Ew
According to my observations in the latest beta Object detector works much worse (clearly detected objects in 1.7 release are normally labelled, while in Beta not even detected). If 1.7 detected 100%, then 1.8 object detection capability may be half of it…
By the way, I noticed one peculiarity in both versions - quite often when objects of interest are detected, they’re not labelled. What may be the reason?
Ahhh now i know whats up. 1.8.0 ships with the YOLOv4-tiny model, which is faster but much less accurate. To be honest i dont remember why i did this but for CUDA it makes no sense to use that one since we are using the GPU acceleration anyway.
For the container without a GPU it might make sense.
Can you exec into the container and run this command to download the YOLOv4 model and then simply restart the container.
wget https://github.com/AlexeyAB/darknet/releases/download/darknet_yolo_v3_optimal/yolov4.weights -O /detectors/models/darknet/yolo.weights --progress=bar:force:noscroll && \
wget https://github.com/AlexeyAB/darknet/releases/download/darknet_yolo_v3_optimal/yolov4.cfg -O /detectors/models/darknet/yolo.cfg --progress=bar:force:noscroll
What do you mean by not labelled?
OK! I executed this command and will inform you after a while about the progress with object detection.
I mean that when an object is detected it has a rectangle with “%” of confidence on the snapshot. In my case sometimes there is no red rectangle and label with “confidence %” and “person” text. I wonder why is it so?
You mean in the camera entity in Home Assistant named camera.***_latest_thumbnail
Yes, I mean labels on latest_thumbnail
Okay, this is not something i have experienced but i will look into it
