So I found a tidbit about the vmxnet adapters and mDNS issues, so I ended up moving away from the Docker based deployment on my virtual Synology hosted in vmware to deploying the OS version with Supervisor and haven’t had any “unavailable” errors in the log for the past 24 hours and the automation is working well too.
Next, I just have to figure out how to get the mobile app working remotely along with notifications. Thanks for your help in troubleshooting.
I’m a complete newb to HA and to electronics in general, but would appreciate any help you can give. I’ve got a Powermax Complete and followed the Wiki to buy a DOIT device and I think I’ve connected it up as per the instructions on the wiki but I can’t seem to get the DOIT device to show up on WiFi for me to connect to. I can see a teeny-tiny red light on the DOIT device sometimes when I press buttons on it, but nothing else. Can anybody give me any tips?
Have you configured the DOIT i.e. connected to its webserver and set the settings?
If not then leave the gnd and vcc connected and remove Tx and Rx. It should create it’s own SSID that you connect a tablet or mobile phone to. This gives you the Webserver inside the DOIT.
By doing this you can configure how it connects to your House Wifi i.e. set yout SSID and Wifi Password so it connects.
If it has connected to your house network, did you give it a static or dynamic IP address.
If static then you should be able to connect to it using that address. If dynamic then you’ll need to go on to your router and work out which device it is to get the IP address.
Let me know when you get this far
EDIT: I just noticed that the voltage on that aliexpress website states “Working voltage: 4.5V~6.0V”. The panel only provides 3.75v so that could be a problem…
Yesterday a smoke detector went off several times (no clue why, as the room was closed with no high humidity) and it triggered the siren (as expected).
That is when I noticed that I cannot disarm through Home Assistant “standard Alarm Panel” in this case, as the alarm was not armed (the button “Disarm” only appears when the alarm is armed).
What would be the best way for me to add a “Disarm” button to Home Assistant to be available at all times ? (or to modify the alarm-panel widget to always display this button)
Thanks in advance,
The short answer is that you can’t do this easily as I use the Home Assistant Alarm Panel Entity and Frontend card here. All of the ‘logic’ of arming and disarming is part of this entity and card, including the displaying of the various ‘Arm Home’ etc buttons. I could easily add a configuration setting to not use that entity and card, and allow the user to create their own. However this is a significant effort to do this for most users (including me). I’m not really a Frontend developer
The configuration setting would simply not create the entity and card. If you want to hack the current version of the code then change client.py lines 513 to 518 to prevent the creation of the alarm panel entity and card:
def setupAlarmPanel(self):
pass
However, there is also a simpler thing that you can do. If you go to the developer tools, services, you can call the service to disarm the panel
You can call this service at any time, including when the panel is disarmed.
You could create a seperate frontend card with a “Disarm” button to call this service that you can use at all times to send a disarm command to the panel.
@Isablend, how did you manage to connect to the RS232 interface in your Powermaster 33? I have the same model as you and having problems finding out how to connect it.
@mats75, to be honest I was never able to do it successfully as I had with my older system. I ended up going down the route of implementing a connection via a D1mini. It connects well, with the caveat that it does require periodic reboots of the powermaster (enter the installer mode, followed by reboot of HA).
I do still have a powerlink, which I had used to connect, but I don’t think that route has been developed and you can’t connect via it and the D1 at the same time, so I’ve stuck with the D1 for now.
I’m truly impressed by your extraordinary dedication and excellent work!
I have a PowerMax Pro with PowerLink (I believe it’s the latest version, the one that doesn’t use a fixed IP address). With this PowerLink, I can connect and arm/disarm the alarm system through a cloud server, a feature I’d like to maintain.
I recently came across your ESP32 solution and I’m very interested in learning more about it. I must admit that I don’t have much experience with Arduino, so I’m not sure if I’ll be able to follow your instructions directly. Nevertheless, I’m open to exploring a mutual collaboration where we can work together on this.
Hi, sorry for the delay in responding, I’ve been away from home so not able to do anything. With regards to the disconnects the majority are caused when the D1 is changed due to esphome updates etc and then the simple route is to restart the D1 and then HA and it all connects again fine. So its any change of status between the two devices that just need a re-connection.
WRT to the experimental setup you mention. I would be interested in understand what and how easy it is to setup. What has been your experience, ie. what advantage have you got from it, what use cases result. I’m unsure as currently I either interact with the alarm (turn on, turn off, check status etc) from HA. I do occasionally turn the alarm on using its own panel (but increasingly only occasionally), so I’m wondering what in practice you’ve found you get by having the powerlink access?
Supporting an ESP32 as a passthrough device so the integration works with a Powerlink (2 or 3) hardware module (with some limitations in the HA Integration) as per the previous post and
Looking at an Adafruit QT Py S3 with lots of PSRAM to run my python software (in CircuitPython) and connect to an MQTT server, this makes it independant of Home Assistant.
The problem is that life and work has got in the way so progress is slow going, I’m posting now so you know that I haven’t forgotten.
Hi to all. I’ve a Powermaster 10 with LAN module.
I’m able to connect to it using Visonic app.
I’m trying to connect it to home assistant from a lot of time but I’m not able to do that.
I have installed the integration but I’m not able to find any entities. HA told me that is not able to connect.
Have I to buy new hardware in order to do that?
Thank you for your help.
I assume when you say LAN module that you mean the Visonic Powerlink 2 or 3 Hardware Module as you also refer to the Visonic App.
This integration is not designed to be used at the same time as a Powerlink 2 or 3 Hardware Module, it is to be used instead of the Powerlink Hardware with a small hardware device to route through the serial data. That is why you cannot connect.
I suggest that you read the first post in this chain and the wiki here for more information.
However, as I suggested in my previous post I’m looking at supporting a pass through capability
Thank you Dave. So now cannot I use the original Visonic app if I want to connect alarm to HA? I have to change Visonic powerlink with a new rs232 device (ex wemos). In that case I connect central to Ha but not to Visonic server, is that right?
Riccardo
Yes that is correct. You cannot use the Visonic App and you do not need to pay for the connection to a Visonic server.
You need to buy a small hardware device (e.g. wemos) and wire it inside your alarm panel, that device either connects to your local home network (wifi or wired ethernet) or to a USB cable and then to the system that you run Home Assistant. This link on the wiki is all about the hardware and wiring. Just make sure that your specific panel model is on this list as supported.
You would use Home Assistant on your mobile phone, PC, Mac or tablet to control the alarm panel.
I have so many questions
When you say “through tx-rx and rx-tx” what do you mean?
According to your log file you have loopback
[handle_msgtype0F] LOOPBACK TEST SUCCESS, Counter is 1
This means that you have not connected anything to the panel connector. It looks like the Tx and Rx of your USR device are connected together.
Next question… I’m not sure what the “Remote Server Addr:” IP address means but you should be using the IP address on the “Local IP Config” settings ith port 30000. I would probably set “Remote Server Addr:” to be different to the local IP address. Also, I do not tick “Similar RFC2217”, so maybe try it.
The other settings look OK to me.
Going back to the “LOOPBACK TEST SUCCESS, Counter is 1”, does the counter increment and count up? If so then you have Rx and Tx on the USR device connected together.
