Hi. I have the Sugar Valley Wifi Module installed, i understand that putting the following code in configuration.yaml would the PH go? Ifeel my clumsiness. Thk
What are you planning to add?
Maybe to control the electrolisys level and to control the auxiliar switchs. I have a lot of thinks in the https://vistapool.es of this service, I dont know what you have in your frontend.
Maybe a photos can help. There are the auxiliar switchs:
djerik I entered in the https://www.da-gen.com and its exactly the same webpage that https://www.vistapool.es, and you can use the same username // password. Thats funny, because we don’t have a vistapool API but theres an API for da-gen and its the same back-end. I don’t understand this companies.
You have to buy a HF5111S (or similar) and connect the Oxilife via Modbus and TCP to your HomeAssistant installation. I have described everything in my post.
Small repetition for those who are not reading the whole thread.
Somewhere here are mentioned basic ways how to control Vistapool, Oxilife or similar. For ‘no cloud’ control you can use any MODBUS-TCP converter (wifi or LAN) or OEM wifi/LAN module to be dependent on cloud (manufacturer).
Hello Tobias,
I have just found your Da-Gen implementation for HA and tested it successfully with my Bayrol Salt Relax Pro. It’s interesting that you can also log in to da-gen.com with the credentials of the vistopool.es site and that the API apparently still works.
After I had almost given up and started to deal with the MODBUS topic, I am very happy to have found this. Now I can read out pH, Rx and temperature. Very cool!
Are you still working on further development? My idea is actually to use the extra PV electricity to heat the pool via the heat pump. It works quite well so far, but the heat pump can only work if the filter pump is also running, so it would be perfect if it were somehow possible to switch on the filter pump via HA.
Unfortunately I’m not a programmer, but I’ve been working in IT for 30 years, so I’m not completely clueless. If I can help in any way, I’d be happy to
