It does not make sense that it is HA.
It could be your hypervisor or your router/AP.
If the hypervisor and router/AP have overlap in the subnet, then it can happen or if the AP is segmenting the WiFi networks.
- How many devices do you have on the 2.4Ghz band?
- Are these all HA related devices?
If not: check if a non-HA related devices go offline as well. - Check the logs from your AP, specifically for the 2.4Ghz band.
As @WallyR wrote: it doesn’t make sense that HA is cause for this.
HA is connected by ethernet to your LAN and communicates via your AP to the wireless devices.
When people don’t have a clue, they $hit on everything. I’m running a VM with HAOS as well. Better performance, immediate recovery, high availability. Seriously not sure why that’s not clear. Running HA on baremetal is wasteful IMO. Sure simpler, but all those resource3s just going to waste.
To close this topic: it seems that the Deco firmware update did the trick.
Aw man I’d forgotten this one.
Nice. Smelled like the Deco. Glad it helped.
