Volvo2Mqtt: Connect your AAOS Volvo 🚙
Yes, they introduced a one-time password (OTP) with version 1.9.0. The author describes how to use it here: GitHub - Dielee/volvo2mqtt: Home Assistant addon for connecting AAOS Volvos
I can’t get it to work though, will post an additional comment for my problem.
Did anyone get the OTP thing to work? When I get the code via email and change the status of the text.volvo_otp entity, nothing happens. The add-on did its 15 retries and that’s it. When I restart it, it creates a new OTP, so I am always “running behind”. What am I doing wrong?
I updated the plugin, filled in the verification code in the “Volvo OTP” entity and it worked immediately.
When I was beta-testing this last month at first I didn’t get the verification code on time because my mail client marked the Volvo email as spam. It’s just a matter of filling in the “Volvo OTP” code in time. I immediately received an email with the verification code when starting the add-on.
@Dielee is there a possibility to extend the time between the 15 retries to make sure people can copy the verification code from the email?
How do i trigger new code?
I reloaded Addon and MQTT but both didn trigger new code. I did found Volvo OTP and try to enter old code via “developer tool”.
I do get a new code whenever I restart the Volvo2Mqtt add-on.
However, I update the “Volvo OTP” by navigating to all entities (Settings > Devices & services > Entities) and selecting the “Volvo OTP” entity.
Setting state via Developer tools didn’t work for me either.
after stop and start the volvo add-on, i received new code and updated it quickly as you described and it seems to be working. Thx for the quick help, appriciated.
Ah, that did it! Thanks!
Just installed this for my 2019 V60 T8. Only tank lid entity is not working. Great add-on!
Hi All,
I defined the value of the OTP from the Developer Tools
otp-value
But I have this error
May 27 13:27:44 volvo2mqtt [106] - INFO: Waiting for otp code… Please check your mailbox and post your otp code to the following mqtt topic “volvoAAOS2mqtt/otp_code”. Retry 14/15
File “/volvoAAOS2mqtt/main.py”, line 15, in
authorize()
File “/volvoAAOS2mqtt/volvo.py”, line 71, in authorize
response = send_otp(auth_session, response)
File “/volvoAAOS2mqtt/volvo.py”, line 155, in send_otp
raise Exception (“No OTP found, exting…”)
Exception: No OTP found, exting…
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
/volvoAAOS2mqtt/mqtt.py:56: SyntaxWarning: invalid escape sequence ‘\d’
“pattern”: “\d{6}”,
Have you a fix ?
Try just going to Settings, Entities, and searching for OTP and editing it there. Editing it in States might be causing issues.
I am also unable to configure the OTP code (through entities) :sleepy:
Why you are unable ? Whats your problem ?
Hi Dielee,
I was unable to make it work with version 1.9.0 : after configuring the OTP on the volvo_otp entity and restarting the add-on, I was getting a new OTP passwork through e-mail.
I just saw that a version 1.9.1 of the add-on was available and it seems to be fine now.
Neverthless I am getting an syntax warning in the logs, but this doesn’t prevent the add-on to work correctly.
“pattern”: “\d{6}”,
Ok, nice. Thanks for your input.
Which HA Version are you on ?
Latest
OTP bug fixed with the v1.9.1 and Entity value (Thanks a lot)
But this warning is still here
“pattern”: “\d{6}”,
That’s just a syntax warning, think this can be fixed by prefixing the regular epression with a raw string (r) @Dielee
"pattern": r"\d{6}",
Yes, thanks. Fixed this already. Pushing later this day a new version.
Heya all. I got myself a MY2023 XC40 in the UK, set up the Volvo account, and bumped into configuration set up problems with answers spread out in this thread. To even get config to save:
I needed a password without a special character.
I needed a short API of a dozen numbers unlike the massive token.
I have MQTT running doing other services, so I think that’s fine.
Q1. The config saves with “GB” or with “en_GB” as the locale - which one is correct?
Q2. The log spits out some errors when it runs, and then successfully stops>
May 27 15:41:45 volvo2mqtt [106] - INFO: Starting volvo2mqtt version v1.9.0
File “/volvoAAOS2mqtt/main.py”, line 14, in
connect()
File “/volvoAAOS2mqtt/mqtt.py”, line 38, in connect
client.connect(settings[“mqtt”][“broker”], port)
File “/usr/lib/python3.12/site-packages/paho/mqtt/client.py”, line 914, in connect
return self.reconnect()
File “/usr/lib/python3.12/site-packages/paho/mqtt/client.py”, line 1044, in reconnect
sock = self._create_socket_connection()
File “/usr/lib/python3.12/site-packages/paho/mqtt/client.py”, line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File “/usr/lib/python3.12/socket.py”, line 828, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File “/usr/lib/python3.12/socket.py”, line 963, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -5] Name has no usable address
I’m not receiving an e-mail after upgrading to 1.9.1. I’ve checked my spambox as well. No e-mail from Volvo.
