Wake On Lan - For those running home assistant in docker
I tried the named pipe solution and got some permission issues like others.
Solved this by changing user nobody by root and the same for nogroup.
It’s working great now and this allow me to switch on my NAS from anywhere through remote and secured access to Home Assistant.
This might give my family access to pictures archives at any time, without the need to keep the NAS constantly ON.
Thanks a lot Peter.
Great thought! The service definition was throwing errors in my setup for some reason, but creating a script such as the below and calling that one as ExecStart did the trick for me:
#!/bin/bash
pipe=/virtual/other/homeassistant/config/wolpipe
remac=“^([a-fA-F0-9]{2}:){5}[a-fA-F0-9]{2}$” # regex for mac address
while true
do
if read line <$pipe; then
if [[ “$line” =~ $re ]]; then
wakeonlan -i 192.168.2.99 $line # where 192.168.2.99 is the dummy target IP of my wol forwarder between subnets
fi
fi
done
Hi Gary.
I too got the permission error, when trying to test it (the echo command):
I had to changed the chmod value to 666 - e.i.:
sudo chmod 666 /path/to/homeassistant/config/wolpipe
This is a great solution, thanks a lot for sharing! I will only add that for me it was failing at first with
Permission denied at /usr/bin/wakeonlan
error, which I guess was because I created the pipe inside a root-owned directory. So I just re-created it at /opt/wolpipe (and added mapping for it on container creation with -v), and then it went fine, I didn’t even need to chown it to a different user.
One other thing to add here is that for nobody user I was getting this warning:
Special user nobody configured, this is not safe!
so I replaced User=nodoby with DynamicUser=yes in the /etc/systemd/system/docker-wol.service, and now it’s all perfectly splendid (unless there are other security-related problems with exposing named pipes, which I don’t yet know about).
I just wanted to hop on here and say that the named pipe was a fantastic idea, and it’s working great in a k8s pod! In my case, I still use WOL, and then create an automation to echo the mac address to the named pipe when the WOL switch turn_on service event is called. This way I still have the WOL switch on the dashboard, and have insight into whether the system is on or off!
So I’ve managed to combine all the methods explained in this thread but (thank you all for sharing)…
However it’s unclear how I can user the WOL intergration and when triggering a machine/mac have it execute the named pipe script and pass the mac as an variable.
Could you share some more information in regards to achieving this? Would be greatly appreciated.
