Wake-up light alarm with sunrise effect
I was now able to do it with two changes in the blueprint:
line 97:
seconds: '{{float(states(sunrise_duration)) * 60}}'
line 36:
sunrise_duration:
      description: The sunrise will start the configured number of minutes before
        the timestamp.
      default: none
      selector:
        entity: {}
Together with the changes described here and some additional config is it possible to use the nice Lovelace alarm card from here:
You can easily change the time, mode (Off, Workdays, Weekend, Every Day) and the Duration from the UI.
Steps:
  1. Change the Blueprint according like described here
  2. Install the lightalarm-card like described here
  3. Add the following to you configuration.yaml:
  - platform: time_date
    display_options:
      - 'date'
      - 'date_time_iso'
    sensors:
      lightalarm_1_startdate:
        device_class: timestamp
        value_template: >
          {% if now() == now() %}
          {% endif %}
          {{ today_at(strptime(states("input_datetime.lightalarm_1_time"), "%H:%M:%S").strftime("%H:%M")).isoformat() }}
    sensors:
      lightalarm_1_condition:
        value_template: >
          {% if is_state('input_select.lightalarm_1_mode', 'Workdays') and now().weekday() in (0,1,2,3,4) %}
            on
          {% elif is_state('input_select.lightalarm_1_mode', 'Weekend') and now().weekday() in (5,6) %}
            on
          {% elif is_state('input_select.lightalarm_1_mode', 'Every Day') %}
            on
          {% else %}
            off
          {% endif %}
input_datetime:
  lightalarm_1_time:
    name: Alarm 1 Time
    has_date: false
    has_time: true
input_number:
  lightalarm_1_duration:
    name: Alarm 1 Duration
    unit_of_measurement: min
    min: 1
    max: 60
    step: 1
input_select:
  lightalarm_1_mode:
    name: Alarm 1 Mode
    icon: mdi:alarm-plus
    options:
      - 'Off'
      - 'Workdays'
      - 'Weekend'
      - 'Every Day'
  1. Add the lightalarm-card to your UI and use your created inputs:
  2. Configure the automation:
Hope I haven’t forget anything, let me know if something doesn’t work.
@Sbyx Could you please add a field, for an entity or trigger, that would instantly move the automation to its end phase, if used at any point after the automation has started running?
This would be very useful for people using the phone’s alarm as a trigger.
If you wake up after the automation has started, but before the phone’s alarm has started ringing, you could use this to turn the lights up to full brightness by dismissing the upcoming alarm notification on the phone.
Also, please add more “Additional entities to check before sunrise is triggered” fields.
It would be very useful to be able to check multiple things before triggering, like for example a presence sensor (to make sure you didn’t leave in the middle of the night for some emergency) and a lux sensor (to not trigger the automation, if you were just taking an afternoon nap and the room is otherwise flooded with daylight).
I am not sure if this will help you, but here is what I just got working. input_datetime.alarm is an input datetime with just time, as I didn’t want to have to set the date every day.
      alarm_time_with_date:
        friendly_name: "Alarm Time with Date"
        value_template: "{{states('sensor.date')~' '~states('input_datetime.alarm')}}"
Hey guys, I hope I didn’t miss this issue in a previous comment (Ctrl-F didn’t help me find anything), but I’m having trouble setting this up with the Next_Alarm sensor.
The script will start running but run into this:
TypeError: forgiving_as_timestamp() takes 1 positional argument but 2 were given
This is my automation config:
variables:
  light_entity: light.alle
  sensor: sensor.sm_g960f_next_alarm
  sunrise_duration: 5
  start_brightness: 154
  end_brightness: 254
  range_brightness: '{{float(end_brightness)-float(start_brightness)}}'
  manual_time: '23:54:00'
  seconds: '{{float(sunrise_duration) * 60}}'
  min_mired: 0
  start_mired: '{{state_attr(light_entity, ''max_mireds'')}}'
  end_mired: '{{[state_attr(light_entity, ''min_mireds'')|int(0), min_mired|int(0)]|max}}'
  tick_time: '{{float(seconds) / float(range_brightness)}}'
  check_entity: none
  - platform: time_pattern
    minutes: '*'
condition: []
  - wait_template: '{{sensor == ''none'' or as_timestamp(states(sensor), None) != None}}'
  - wait_template: >-
      {{0 < as_timestamp(states(sensor) if sensor != 'none' else
      states('sensor.date') ~ ' ' ~ manual_time) -
      as_timestamp(states('sensor.date_time_iso')) <= float(seconds) and
      states(check_entity) in ['unknown', 'on', 'home']}}
  - choose: []
    default: []
  - condition: template
    value_template: '{{sensor == ''none'' or as_timestamp(states(sensor), None) != None}}'
    value_template: >-
      states('sensor.date') ~ ' ' ~ manual_time) - as_timestamp(now()) <=
      float(seconds) and states(check_entity) in ['unknown', 'on', 'home']}}
  - choose:
      - conditions:
          - '{{state_attr(light_entity, ''min_mireds'') != None}}'
        sequence:
          - service: light.turn_on
              brightness: '{{start_brightness}}'
              color_temp: '{{start_mired}}'
            entity_id: light.alle
    default:
  - repeat:
      while:
        - '{{sensor == ''none'' or as_timestamp(states(sensor), None) != None}}'
          float(seconds)}}
      sequence:
        - delay: '{{tick_time}}'
        - choose:
            - conditions:
                  {{0 < state_attr(light_entity, 'brightness') | int(0) <
                  end_brightness | int}}
                  {{sensor == 'none' or as_timestamp(states(sensor), None) !=
                  None}}
                  as_timestamp(now()) <= float(seconds)}}
              sequence:
                - choose:
                    - conditions:
                      sequence:
                            brightness: >-
                              {{(float(end_brightness) -
                              (float(range_brightness) *
                              (as_timestamp(states(sensor) if sensor != 'none'
                              else states('sensor.date') ~ ' ' ~ manual_time) -
                              as_timestamp(now())) / float(seconds))) | int(0)}}
                            color_temp: >-
                              {{(float(end_mired) + (float(start_mired) -
                              float(end_mired)) * ((as_timestamp(states(sensor)
                              if sensor != 'none' else states('sensor.date') ~ '
                              ' ~ manual_time) - as_timestamp(now())) /
                  default:
                        brightness: >-
                          {{(float(end_brightness) - (float(range_brightness) *
                          (as_timestamp(states(sensor) if sensor != 'none' else
  - choose: []
    default: []
mode: single
max_exceeded: silent
alias: Wake-up light alarm with sunrise effect
description: ''
And this is my blueprint config:
description: ''
use_blueprint:
  path: sbyx/wake-up-light-alarm-with-sunrise-effect.yaml
  input:
    pre_sunrise_actions: []
    sunrise_duration: 5
    min_mired: 0
    timestamp_sensor: sensor.sm_g960f_next_alarm
as well as my configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
I feel like I’m missing something obvious here or did some stupid mistake. Can someone help me out on this?
I’m having some issues with getting this automation to work, and I can’t really find any answers in this thread.
To me it looks like issues with the time checks, where some use sensor.date_time_iso and some use now() which seem to return…different results.
See here:
Could these differences be why nothing is running?
It looks like the missing TZ info on sensor.date_time_iso is what’s causing issues. If I manually add +01:00 to the sensor time, it’s correct.
Hey All, so I have everything set up and all other integrations work (mostly as intended). For whatever reason, no matter what I set the start value at on a few different brands of lights the lowest I can get one of them is 54% brightness. The light that I want to use starts at 100% no matter what.
Does anyone have any ideas on what might be causing the high start value?
Soo. One a bit more complicated problem. I have this Automation and I transferred it to a Automation w/o all the blueprint stuff. Now the time stuff is working, like starting 10 Minutes before the alarm and also the pre and post sunrise effect action are getting fired. Now just the brightness is the problem. It starts at 1 brightness then nothing happens(Like not getting brighter) for ~8:45 minutes and then it turns off. Also the trace is not longer available after that. Not sure what’s really happening with that.
#                _                        _   _
#     /\        | |                      | | (_)
#    /  \  _   _| |_ ___  _ __ ___   __ _| |_ _  ___  _ __  ___
#   / /\ \| | | | __/ _ \| '_ ` _ \ / _` | __| |/ _ \| '_ \/ __|
#  / ____ \ |_| | || (_) | | | | | | (_| | |_| | (_) | | | \__ \
# /_/    \_\__,_|\__\___/|_| |_| |_|\__,_|\__|_|\___/|_| |_|___/
automation:
# Alarm clock - Light with sunrise
  - alias: Alarm Clock - Light with sunrise
    variables:
      light_entity: group.schlafzimmer
      sensor: sensor.sm_g998b_next_alarm
      sunrise_duration: 10
      start_brightness: 1
      end_brightness: 254
      manual_time: 07:00:00
      min_mired: 0
      check_entity: device_tracker.sm_g998b
      minutes: '*'
    condition: []
    - wait_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
        ~ '' '' ~ manual_time) - as_timestamp(states(''sensor.date_time_iso'')) <= float(seconds)
        and states(check_entity) in [''unknown'', ''on'', ''home'']}}'
    - choose: []
      default:
        - service: script.toggle
            entity_id: script.pre_sunrise_actions
      value_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
        ~ '' '' ~ manual_time) - as_timestamp(now()) <= float(seconds) and states(check_entity)
    - choose:
      - conditions:
        sequence:
          entity_id: group.schlafzimmer
      default:
    - repeat:
        while:
        - '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
          ~ '' '' ~ manual_time) - as_timestamp(now()) <= float(seconds)}}'
        sequence:
        - choose:
          - conditions:
            - '{{0 < state_attr(light_entity, ''brightness'') | int(0) < end_brightness |
              int}}'
            sequence:
            - choose:
              - conditions:
                sequence:
                    brightness: '{{(float(end_brightness) - (float(range_brightness) *
                      (as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
                      ~ '' '' ~ manual_time) - as_timestamp(now())) / float(seconds)))
                      | int(0)}}'
                    color_temp: '{{(float(end_mired) + (float(start_mired) - float(end_mired))
                      * ((as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
                      | int(0)}}'
              default:
                  brightness: '{{(float(end_brightness) - (float(range_brightness) * (as_timestamp(states(sensor)
                    if sensor != ''none'' else states(''sensor.date'') ~ '' '' ~ manual_time)
                    - as_timestamp(now())) / float(seconds))) | int(0)}}'
    - choose: []
      default:
            entity_id: script.post_sunrise_actions
    mode: single
#  ____                  _           _
# / ___|    ___   _ __  (_)  _ __   | |_   ___
# \___ \   / __| | '__| | | | '_ \  | __| / __|
#  ___) | | (__  | |    | | | |_) | | |_  \__ \
# |____/   \___| |_|    |_| | .__/   \__| |___/
#                           |_|
script:
    sequence:
      - service: switch.turn_on
          entity_id:
          - switch.touch1_flur
          - switch.touch2_schlafzimmer
          - switch.touch4_kuche
          - switch.touch5_wohnzimmer
          - switch.touch6_badezimmer
      - delay: 00:00:10
      - service: light.turn_off
          entity_id:
          - light.badezimmer_lampe_1
          - light.badezimmer_lampe_2
          - light.flur_lampe_1
          - light.flur_lampe_2
          - light.kuche_lampe_1
          - light.kuche_lampe_2
          - light.wohnzimmer_lampe_1
          - light.wohnzimmer_lampe_2
        entity_id:
          - input_boolean.alarm_clock_running
  post_sunrise_actions:
    sequence:
      - service: media_player.play_media
          media_content_id: startmyday
          media_content_type: routine
          entity_id: media_player.echo_dot_schlafzimmer
      - delay: 00:02:10
      - service: media_player.volume_set
          entity_id: media_player.uberall
          volume_level: 0.25
          media_content_id: Radio Hamburg in überall
          media_content_type: TUNEIN
          entity_id: media_player.echo_dot_wohnzimmer
      - service: input_boolean.turn_off
        entity_id:
Hi there, hope there’s someone knowledgeable that can help me with this. I’m a day 1 newbie and although borderline illiterate with code, most of the time I can about figure out how to botch together what I need.
I can’t get the automation to activate. When checking the Trace Timeline I’m getting the following message. Does anyone know how to resolve this?
Triggered by the time pattern at 28 December 2021, 18:45:00
Wait for a template to render true
Stopped because an error was encountered at 28 December 2021, 18:45:00 (runtime: 0.03 seconds)
In 'template' condition: TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'
This is the accompanying message from the error log:
Logger: homeassistant.components.automation.wake_up_light_alarm_with_sunrise_effect
Source: components/automation/__init__.py:512
Integration: Automation (documentation, issues)
First occurred: 18:12:00 (47 occurrences)
Last logged: 18:56:00
Error while executing automation automation.wake_up_light_alarm_with_sunrise_effect: In 'template' condition: TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'
Thanks in advance guys!
I have the same issue. Is there any solution for it?
Looks like automations created with this blueprint are throwing some errors:
2021-12-29 15:40:00 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'as_timestamp' got invalid input 'unavailable' when rendering template '{{0 < as_timestamp(states(sensor) if sensor != 'none' else states('sensor.date') ~ ' ' ~ manual_time) - as_timestamp(states('sensor.date_time_iso')) <= float(seconds) and states(check_entity) in ['unknown', 'on', 'home']}}' but no default was specified. Currently 'as_timestamp' will return 'None', however this template will fail to render in Home Assistant core 2022.1
You can try to change all “none”'s in the template to “None”. That’s work for me, but after this change I get the same error as @vitek and @vajdum
Edit: At first use of this blueprint I get this TypeError, but after playing around and type again “none” everything works fine. Maybe you have to type it in, even when the fild contains “none” already?!
The Error “Stopped because only a single execution is allowed at …” seems to be okay, you have to look at the first trace were the automation is “still running” (HA prevent to restart a new run in single-mode, see Automation Modes).
New to HA and wanted to say thanks for this blueprint, it provided a great base for the functionality I wanted.
I’ve added support to add a speaker that slowly increases the volume in combination with the light. This is tested with a Sonos speaker (IKEA Symfonisk). I’m using IKEA Trådfri bulbs so I also had to do some minor changes to how brightness is set. I’ve also added the possibility to lock the color temperature to the set value (incase you want to only increase brightness) and fixed some minor issues with the timestamps.
The issue with the timestamps came from that sensor.time_date_time_iso doesn’t include the timezone information while now() does. So when converted to timestamps, they give different times.
{{states('sensor.date_time_iso')}} = 2022-01-08T20:05:00
{{now()}} = 2022-01-08 20:05:00.004820+01:00
When converted, these should give the same time but
{{as_timestamp(states('sensor.date_time_iso'))}} = 1641672300.0
{{as_timestamp(now())}} = 1641668700.004835
This problem also applies when setting the time manually as
also lacks information about the timezone.
Below is my full code with the added functionality and fixes incase it’s useful for someone.
EDIT: I fell victim for the “never post anything until fully tested”. Fixed the code below.
blueprint:
  name: Wake-up light and music alarm with sunrise effect and increasing volume
  description: 'A wake-up light and music alarm with a brightness and color temperature sunrise effect and increasing volume.
    Note: Requires date_time_iso sensor in configuration, not manually executable!'
  domain: automation
  input:
    light_entity:
      name: Wake-up light entity
      description: The light to control. Turning it off during the sunrise will keep
        it off. Color temperature range is auto-detected.
      selector:
        entity:
          domain: light
    speaker_entity:
      name: Wake-up speaker entity
      description: The speaker to control. Turning it off during the wake-up will keep
        it off.
      selector:
        entity:
          domain: media_player
    music_source:
      description: What the speaker should play
      selector:
        select:
          options:
            - Radio Nova
            - Radio SuomiPop
    timestamp_sensor:
      name: Alarm timestamp sensor
      description: 'Sensor with timestamp of next alarm with device_class: timestamp
        (set to ''none'' for manual alarm time)'
      default: none
      selector:
        entity:
    manual_time:
      name: Manual alarm time
      description: Time to trigger alarm every day if timestamp sensor is not set.
        Settings at or shortly after midnight will not work as expected!
      default: '7:00:00'
      selector:
        time: {}
    check_entity:
      name: Additional entity to check before wake-up is triggered
      description: If set, checks if entity is 'on' or 'home' before triggering. Use
        e.g. a (workday) sensor, device_tracker or person entity.
      default: none
      selector:
        entity: {}
    wakeup_duration:
      description: The wake-up will start the configured number of minutes before
        the timestamp.
      default: 25
      selector:
        number:
          min: 5.0
          max: 60.0
          step: 5.0
          mode: slider
    start_brightness:
      name: Minimum brightness in percentage
      description: The brightness to start with. Some lights ignore very low values
        and may turn on with full brightness instead!
      default: 1
      selector:
        number:
          min: 1.0
          max: 100.0
          step: 1.0
          mode: slider
    end_brightness:
      name: Maximum brightness in percentage
      description: The brightness will be transitioned from the minimum to the configured
        value.
      default: 100
      selector:
        number:
          min: 5.0
          max: 100.0
          step: 1.0
          mode: slider
    min_mired:
      name: Minimum color temperature
      description: 'The minimum color temperature to use. (0: lowest supported)'
      default: 0
      selector:
        number:
          min: 0.0
          max: 500.0
          step: 5.0
          mode: slider
          unit_of_measurement: mired
    lock_mired:
      name: Lock color temperature
      description: Lock the color temperature to the selected minimum temperature
      default: false
      selector:
        boolean:
    start_volume:
      description: The volume to start with
      default: 1
      selector:
        number:
          min: 1.0
          max: 100.0
          step: 1.0
          mode: slider
    end_volume:
      description: The volume will be transitioned from the minimum to the configured
        value.
      default: 20
      selector:
        number:
          min: 5.0
          max: 100.0
          step: 1.0
          mode: slider
    pre_wakeup_actions:
      description: Optional actions to run before wake-up starts.
      default: []
      selector:
        action: {}
    post_wakeup_actions:
      description: Optional actions to run after wake-up ends (around the alarm time).
      default: []
      selector:
        action: {}
variables:
  light_entity: !input 'light_entity'
  speaker_entity: !input 'speaker_entity'
  music_source: !input 'music_source'
  sensor: !input 'timestamp_sensor'
  wakeup_duration: !input 'wakeup_duration'
  start_brightness: !input 'start_brightness'
  end_brightness: !input 'end_brightness'
  range_brightness: '{{float(end_brightness) - float(start_brightness)}}'
  min_mired: !input 'min_mired'
  lock_mired: !input 'lock_mired'
  end_mired: '{{[state_attr(light_entity, ''min_mireds'') | int(0), min_mired | int(0)] | max}}'
  range_mired: '{{float(start_mired) - float(end_mired)}}'
  start_volume: !input 'start_volume'
  end_volume: !input 'end_volume'
  range_volume: '{{float(end_volume) - float(start_volume)}}'
  manual_time: !input 'manual_time'
  seconds: '{{float(wakeup_duration) * 60}}'
  check_entity: !input 'check_entity'
  minutes: '*'
- wait_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
  - as_timestamp(now()) <= float(seconds) and states(check_entity) in [''unknown'', ''on'', ''home'']}}'
- choose: []
  default: !input 'pre_wakeup_actions'
  value_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
- choose:
  - conditions:
    sequence:
        brightness_pct: '{{start_brightness}}'
        color_temp: '{{end_mired + 1 if lock_mired else start_mired}}'
      entity_id: !input 'light_entity'
  default:
    volume_level: '{{float(start_volume / 100)}}'
    entity_id: !input 'speaker_entity'
- service: media_player.select_source
- repeat:
    while:
    - '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
    sequence:
    - choose:
      - conditions:
        - '{{0 < state_attr(light_entity, ''brightness'') | int(0) < float(end_brightness) / 100 * 255 | int(0)}}'
        sequence:
        - choose:
          - conditions:
            sequence:
                brightness_pct: '{{float(end_brightness) - ([0, float(range_brightness) * (as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
                  - as_timestamp(now())) / seconds, float(end_brightness)]|sort)[1] | round(0)}}'
                color_temp: '{{end_mired if lock_mired else
                  float(end_mired) + ([0, float(range_mired) * (as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
                  - as_timestamp(now())) / seconds, float(start_mired)]|sort)[1] | round(0)}}'
          default:
    - choose:
      - conditions:
        - '{{0 < state_attr(speaker_entity, ''volume_level'') * 100 | round(0) < float(end_volume) - ([0, float(range_volume) * (as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
          - as_timestamp(now())) / seconds, float(end_volume)]|sort)[1] | round(0) <= float(end_volume)}}'
        sequence:
            volume_level: '{{(float(end_volume) - ([0, float(range_volume) * (as_timestamp(states(sensor) if sensor != ''none'' else (states(''sensor.date'') ~ '' '' ~ manual_time) | as_datetime() | as_local())
              - as_timestamp(now())) / seconds, float(end_volume)]|sort)[1]) / 100 | round(2)}}'
- choose: []
  default: !input 'post_wakeup_actions'
mode: single
Hello, did you manage to fix the issue? I have the exact same problem. If i try to trigger the action manually it stops with the following error.
In 'template' condition: TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
variables:
  light_entity: light.0x842e14fffe0ea4b1
  sensor: none
  sunrise_duration: 25
  start_brightness: 1
  end_brightness: 254
  manual_time: '18:50:00'
  min_mired: 0
  check_entity: none
    minutes: '*'
condition: []
  - wait_template: >-
  - choose: []
    default:
      - service: switch.turn_off
          entity_id: switch.circadian_lighting_circadian_lighting
    value_template: >-
  - choose:
      - conditions:
        sequence:
            entity_id: light.0x842e14fffe0ea4b1
    default:
  - repeat:
      while:
          float(seconds)}}
      sequence:
        - choose:
            - conditions:
                  None}}
              sequence:
                - choose:
                    - conditions:
                      sequence:
                            brightness: >-
                            color_temp: >-
                  default:
                        brightness: >-
  - choose: []
    default:
      - service: mqtt.publish
          qos: '2'
          topic: shellies/shellyswitch25-BCDDC277A609/roller/0/command/pos
          payload: '100'
mode: single
description: ''
and this is my blueprint config
description: ''
use_blueprint:
  input:
          qos: '2'
          payload: '100'
Same error for me. The automation doesn’t work :frowning:
In case it helps anyone else, I hacked (it’s gross) my version of this blueprint to accomodate what I assume are issues related to this breaking change as mentioned in the release notes of 2021.12: Add datetime object as valid StateType by frenck · Pull Request #52671 · home-assistant/core · GitHub
I deleted the timestamp device class from my sensor, so now it just reads:
sensors:
I then modified my local version of /config/blueprints/automation/Sbyx/wake-up-light-alarm-with-sunrise-effect.yaml and changed line 21 to just specify the domain as a sensor instead of device_class as timestamp. I will probably pay for these sins later.
    timestamp_sensor:
      default: none
      selector:
        entity:
          domain: sensor
This allowed me to then select my sensor.alarm_time_with_date as my alarm timestamp sensor. It seems to be working based on one test, but I’ll go to bed now and see how it goes in a few hours. :slight_smile:
this worked for me as well!
However, is this breaking change not addressed in the updated version by @sbyx from nov '21?
hey,
I love this blueprint and it’s really awesome,
but I do want to ask a small question…
regarding for creating a timestamp and using it, i"m a bit of a noob, so i apologize in advance
i scanned the thread and found 2 mentions for how to create a time stamp, i used that, and i can see in the blueprint the newly created time stamp,
but what I fail to do, is to assign a time for that sensor… i searched google for examples, but I did not understand those examples that i found…
help would be appreciated :slight_smile:
Hi there,
First I would like to thank you for your contribution. It’s a really nice blueprint you made.
But I just created an automation from your blueprint and encountered an error. Let me give you some details:
  • Running home assistant on Docker
  • Version: Home Assistant 2021.12.10
  • Automation setup: just trigger based on time. No additional conditions set up.
  • Error Message: Stopped because an error was encountered at 30 January 2022, 09:04:00 (runtime: 0.01 seconds) In 'template' condition: TypeError: unsupported operand type(s) for -: 'NoneType' and 'NoneType'
Hope this helps you troubleshoot the problem.
Cheers,
Amer
Hi, nice blueprint.
Small suggestion:
replace states(''sensor.date'') with now().date() and as_timestamp(states(''sensor.date_time_iso'')) with as_timestamp(now()).
Then it is no longer required to use the time_date integration for the sensors, which makes it easier to integrate this blueprint.
