Sorry, it’s possible that error was with an older version of your blueprint. Right now I get a different error when setting a manual time. My lights do successfully get set to 1% it seems, but then do not fade. The log shows:
2020-12-18 07:19:07 ERROR (MainThread) [homeassistant.components.automation.new_automation] Wake up lights: Repeat at step 5: Choose at step 2: choice 1: Choose at step 1: choice 1: Error executing script. Invalid data for call_service at pos 1: value must be at most 100 for dictionary value @ data['brightness_pct']
2020-12-18 07:19:07 ERROR (MainThread) [homeassistant.components.automation.new_automation] Wake up lights: Repeat at step 5: Choose at step 2: choice 1: Error executing script. Invalid data for choose at pos 1: value must be at most 100 for dictionary value @ data['brightness_pct']
2020-12-18 07:19:07 ERROR (MainThread) [homeassistant.components.automation.new_automation] Wake up lights: Repeat at step 5: Error executing script. Invalid data for choose at pos 2: value must be at most 100 for dictionary value @ data['brightness_pct']
2020-12-18 07:19:07 ERROR (MainThread) [homeassistant.components.automation.new_automation] Wake up lights: Error executing script. Invalid data for repeat at pos 5: value must be at most 100 for dictionary value @ data['brightness_pct']
2020-12-18 07:19:07 ERROR (MainThread) [homeassistant.components.automation.new_automation] While executing automation automation.new_automation
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/automation/__init__.py", line 404, in async_trigger
await self.action_script.async_run(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 1026, in async_run
await asyncio.shield(run.async_run())
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 242, in async_run
await self._async_step(log_exceptions=False)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 250, in _async_step
await getattr(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 570, in _async_repeat_step
await async_run_sequence(iteration)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 538, in async_run_sequence
await self._async_run_script(script)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 670, in _async_run_script
await self._async_run_long_action(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 419, in _async_run_long_action
long_task.result()
await getattr(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 596, in _async_choose_step
long_task.result()
await getattr(
long_task.result()
await getattr(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/script.py", line 457, in _async_call_service_step
await service_task
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py", line 1399, in async_call
processed_data = handler.schema(service_data)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/validators.py", line 340, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/validators.py", line 336, in _exec
v = func(v)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/validators.py", line 338, in _exec
v = func(path, v)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/srv/homeassistant/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: value must be at most 100 for dictionary value @ data['brightness_pct']
and the automation yaml is:
alias: Wake up lights
description: ''
use_blueprint:
path: sbyx/wake-up-light-alarm-with-sunrise-effect.yaml
input:
max_brightness: '100'
light_entity: light.yeelight_color_0x0000000007e72c35
manual_time: '23:28:00'
sunrise_duration: '10'
pre_sunrise_actions: []
