Wake-up light alarm with sunrise effect
This integration will extract your alarm data from any Google Home device: https://github.com/leikoilja/ha-google-home#hacs-installation
by using sensor.nest_hub_next_alarm as timestamp it will work.
I’ve just installed this and I’m finding if I turn the light off during the automation it just turns back on again the next time it changes brightness. Been trying to see why this is happening but new to HA and having difficulty.
Also I think a nice feature would be to not run the automation if the light is already on.
Would it be possible to limit the maximum color temperature at the end of the “sunrise” letting it appear a bit warmer? Integrated as a slider, same as “min_mired” for the starting color temperature?
Hi, I am running into errors and I’m not sure what I have done wrong. Any help would be greatly appreciated.
Here is the error from the log:
Logger: homeassistant.components.automation.wake_up_light_alarm_with_sunrise_effect_erik
Source: components/automation/__init__.py:416
Integration: Automation ([documentation](https://www.home-assistant.io/integrations/automation), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+automation%22))
First occurred: 8:34:00 AM (20 occurrences)
Last logged: 8:53:00 AM
Error while executing automation automation.wake_up_light_alarm_with_sunrise_effect_erik: In 'template' condition: TypeError: unsupported operand type(s) for -: 'float' and 'NoneType'
Source: helpers/script.py:1156
Wake-up light alarm with sunrise effect - Erik: Error executing script. Error for wait_template at pos 2: In 'template' condition: TypeError: unsupported operand type(s) for -: 'float' and 'NoneType'
Here is the extract of my automation:
- id: '1616874084139'
  alias: Wake-up light alarm with sunrise effect - Erik
  description: ''
  use_blueprint:
    path: sbyx/wake-up-light-alarm-with-sunrise-effect.yaml
    input:
      manual_time: '8:35:00'
      end_brightness: 50
      pre_sunrise_actions: []
      light_entity: light.office_lamp
      sunrise_duration: 5
Here is the time sensor:
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
Is it possible to somehow pass the mired value to a light bulb - in my case Ikea Bulb- that only supports color_xy ?
Could you share all the sensor and automations you’re using? I’ve been struggling trying to get this working for months
Is there a way to disable the manual time?
I am using these sensors:
Time sensor: (make sure you are including the “date_time_iso” sensor, because the Google Home integration reports the alarm in the ISO format)
    display_options:
      - 'date_time'
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
Alarm sensor: (provided by this integration GitHub - leikoilja/ha-google-home: Home Assistant Google Home custom component)
should like this:
Then the automation is as follow: (notice I added something to turn on my radio after the alarm and the morning routines of the nest hub)
description: Nest hub wekker
use_blueprint:
  input:
    manual_time: '7:00:00'
    light_entity: light.slaapkamer
    timestamp_sensor: sensor.nest_hub_alarms
    sunrise_duration: 20
    start_brightness: 1
    min_mired: 155
    post_sunrise_actions:
      - delay:
          hours: 0
          minutes: 2
          seconds: 30
          milliseconds: 0
      - service: media_player.volume_set
          entity_id: media_player.slaapkamer_speaker
          volume_level: 0.17
      - service: media_player.select_source
          source: Qmusic
    end_brightness: 222
For some reason the last 2 days the wake up light doesn’t work anymore. I get the following message in the log:
2021-04-21 06:30:01 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: {{0 < as_timestamp(states(sensor) if sensor != 'none' else states('sensor.date') ~ ' ' ~ manual_time) - as_timestamp(states('sensor.date_time_iso')) <= float(seconds) and states(check_entity) in ['unknown', 'on', 'home']}}
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 376, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1327, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
    reraise(*rewrite_traceback_stack(source=source))
  File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
What is there going wrong?
Hi, I get the same error as Deadpool. Did someone figure this out yet?
Update: I forgot to enable the date_time sensor as specified in the top post.
I adapted the blueprint a bit to work with RGB lights (with only color mode hs_color). Perhaps you would like to incorporate that option? Basically it will fade the saturation from 100% to a set value in some color you can set.
blueprint:
  name: Wake-up light alarm RGB
  description: 'A wake-up light alarm with a brightness and color sat sunrise
    effect. Note: Requires date_time_iso sensor in configuration, not manually executable!'
  domain: automation
  input:
    light_entity:
      name: Wake-up light entity
      description: The light to control. Turning it off during the sunrise will keep
        it off. Color temperature range is auto-detected.
      selector:
        entity:
          domain: light
    timestamp_sensor:
      name: Alarm timestamp sensor
      description: 'Sensor with timestamp of next alarm with device_class: timestamp
        (set to ''none'' for manual alarm time)'
      default: none
      selector:
        entity:
    manual_time:
      name: Manual alarm time
      description: Time to trigger alarm every day if timestamp sensor is not set.
        Settings at or shortly after midnight will not work as expected!
      default: '7:00:00'
      selector:
        time: {}
    check_entity:
      name: Additional entity to check before sunrise is triggered
      description: If set, checks if entity is 'on' or 'home' before triggering. Use
        e.g. a (workday) sensor, device_tracker or person entity.
      default: none
      selector:
        entity: {}
    sunrise_duration:
      description: The sunrise will start the configured number of minutes before
        the timestamp.
      default: 25
      selector:
        number:
          min: 5.0
          max: 60.0
          step: 5.0
          unit_of_measurement: min
          mode: slider
    start_brightness:
      name: Minimum brightness
      description: The brightness to start with. Some lights ignore very low values
        and may turn on with full brightness instead!
      default: 1
      selector:
        number:
          min: 1.0
          max: 255.0
          step: 1.0
          mode: slider
    end_brightness:
      name: Maximum brightness
      description: The brightness will be transitioned from the minimum to the configured
        value.
      default: 254
      selector:
        number:
          min: 5.0
          max: 255.0
          step: 1.0
          mode: slider
    hue:
      name: Color to use
      description: The color for RGB light
        value.
      default: 60
      selector:
        number:
          min: 0
          max: 360
          step: 1.0
          mode: slider
    sat:
      name: Color Saturation
      description: The saturation will be  transitioned from the maximum to the configured
        value.
      default: 100
      selector:
        number:
          min: 0
          max: 100
          step: 1.0
          mode: slider
      description: Optional actions to run before sunrise starts.
      default: []
      selector:
        action: {}
      description: Optional actions to run after sunrise ends (around the alarm time).
      default: []
      selector:
        action: {}
  source_url: https://gist.github.com/sbyx/96c43b13b90ae1c35b872313ba1d2d2d#file-wake-up-light-alarm-with-sunrise-effect-yaml
variables:
  light_entity: !input 'light_entity'
  sensor: !input 'timestamp_sensor'
  sunrise_duration: !input 'sunrise_duration'
  start_brightness: !input 'start_brightness'
  end_brightness: !input 'end_brightness'
  range_brightness: '{{float(end_brightness)-float(start_brightness)}}'
  manual_time: !input 'manual_time'
  seconds: '{{float(sunrise_duration) * 60}}'
  hue: !input 'hue'
  sat: !input 'sat'
  tick_time: '{{float(seconds) / float(range_brightness)}}'
  check_entity: !input 'check_entity'
- platform: time_pattern
  minutes: '*'
condition: []
- wait_template: '{{sensor == ''none'' or as_timestamp(states(sensor)) != None}}'
- wait_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
    ~ '' '' ~ manual_time) - as_timestamp(states(''sensor.date_time_iso'')) <= float(seconds)
    and states(check_entity) in [''unknown'', ''on'', ''home'']}}'
- choose: []
  default: !input 'pre_sunrise_actions'
- condition: template
  value_template: '{{sensor == ''none'' or as_timestamp(states(sensor)) != None}}'
  value_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
    ~ '' '' ~ manual_time) - as_timestamp(now()) <= float(seconds) and states(check_entity)
- choose:
  - conditions:
    - '{{state_attr(light_entity, ''brightness'') != None}}'
    sequence:
    - service: light.turn_on
        brightness: '{{start_brightness}}'
        hs_color:
         - '{{ hue | int}}'
         - '{{ 100 | int}}'
      entity_id: !input 'light_entity'
  default:
- repeat:
    while:
    - '{{sensor == ''none'' or as_timestamp(states(sensor)) != None}}'
    - '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
      ~ '' '' ~ manual_time) - as_timestamp(now()) <= float(seconds)}}'
    sequence:
    - delay: '{{tick_time}}'
    - choose:
      - conditions:
        - '{{0 < state_attr(light_entity, ''brightness'') | int < end_brightness |
          int}}'
        sequence:
        - choose:
          - conditions:
            sequence:
                brightness: '{{(float(end_brightness) - (float(range_brightness) *
                  (as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
                  ~ '' '' ~ manual_time) - as_timestamp(now())) / float(seconds)))
                  | int}}'
                hs_color:
                - '{{hue | int}}'
                - '{{((float(100) - (float(100) - sat)) + ((float(100) - sat) *
                  | int}}'
          default:
              brightness: '{{(float(end_brightness) - (float(range_brightness) * (as_timestamp(states(sensor)
                if sensor != ''none'' else states(''sensor.date'') ~ '' '' ~ manual_time)
                - as_timestamp(now())) / float(seconds))) | int}}'
- choose: []
  default: !input 'post_sunrise_actions'
mode: single
max_exceeded: silent
Regards.
masteriiz
Hi I had the same issue so made something for lights that are only RGB. Somewhere down in this topic.
I’ve added this to my HA and it seems to work perfectly, however I have an improvement to request/suggest.
Since OP seems to no longer be maintaining this, could someone knowledgeable please add an option to automatically set the brightness to the max configured value, if the alarm on the phone is dismissed after the automation started, but before the alarm itself has triggered?
Hey! could you share some more information please, the link does not work and on icloudI did not find the information I needed
Error while executing automation automation.wake_up_light_alarm_with_sunrise_effect: In 'template' condition: TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
Hi, I was getting the “TypeError” error while using a manual alarm time. What fixed it for me was directly editing the automations.yaml file directly (I am using hassos and the Visual Studio Code addon to edit in the browser)
I think my issue was my automations.yaml had bad whitespacing (vscode fixed it for me) and the time picker for “Manual alarm time” chose the wrong hour for am/pm.
in my example, this is an exerpt of my automations.yaml
- id: "1622310155441"
  description: ""
  use_blueprint:
    input:
      light_entity: light.martians_floor_lamp
      manual_time: "5:15:00"
      check_entity: calendar.work_work_schedule
      sunrise_duration: 15
      timestamp_sensor: none
I manually edited the time to 0515am, and “timestamp_sensor: none”.
the schedule for my alarm is a caldav integration to my apple id (using an app-specific password).
with the caldav integration, when I use the “custom_calendars” option, it lets me use a calendar as a binary sensor.
here’s an excerpt of my configuration.yaml
calendar:
  - platform: caldav
    url: https://caldav.icloud.com
    username: "appleid"
    password: "---"
    custom_calendars:
      - name: "work schedule"
        calendar: "work"
        search: "work"
my use case is I am a nurse with 12 hour shifts, who’s work schedule changes often. I made a calendar with my schedule and I am hoping with your blueprint I can have a “smart alarm” to use with my hue bulbs. Thank you Sbyx!
Hi All, I was struggling to get the blueprint working, struggling with the purpose with various lines of code, and it wasn’t exactly what I wanted. So, I’ve made some changes - refer to the bottom of this post. Note that you will need at least one input_datetime and one input_boolean for this to work.
Please be gentle - I’m just throwning this code out there because there seemed to be a few who were having issues. The code hasn’t been cleaned of commented out lines and I’ve not stress tested it. I don’t know if manual times work or if what fields are optional (noting the optional text) etc. And I’m running on the ragged edge of my coding skills!
My config:
input_datetime.yaml
alarm_monday:
  has_date: false
  has_time: true
  icon: mdi:alarm
alarm_tuesday:
  has_date: false
  has_time: true
  icon: mdi:alarm
alarm_wednesday:
  has_date: false
  has_time: true
  icon: mdi:alarm
alarm_thursday:
  has_date: false
  has_time: true
  icon: mdi:alarm
alarm_friday:
  has_date: false
  has_time: true
  icon: mdi:alarm
alarm_saturday:
  has_date: false
  has_time: true
  icon: mdi:alarm
alarm_sunday:
  has_date: false
  has_time: true
  icon: mdi:alarm
input_boolean.yaml
alarm_monday:
  icon: mdi:alarm
alarm_tuesday:
  icon: mdi:alarm
alarm_wednesday:
  icon: mdi:alarm
alarm_thursday:
  icon: mdi:alarm
alarm_friday:
  icon: mdi:alarm
alarm_saturday:
  icon: mdi:alarm
alarm_sunday:
  icon: mdi:alarm
automation.yaml
- id: '###'
  description: ''
  use_blueprint:
    path: homeassistant/wake-up-light-alarm-with-sunrise-effect_modified-2.yaml
    input:
      light_entity: light.lights_bedroom
      timestamp_sensor_monday: input_datetime.alarm_monday
      timestamp_sensor_tuesday: input_datetime.alarm_tuesday
      timestamp_sensor_wednesday: input_datetime.alarm_wednesday
      timestamp_sensor_thursday: input_datetime.alarm_thursday
      timestamp_sensor_friday: input_datetime.alarm_friday
      timestamp_sensor_saturday: input_datetime.alarm_saturday
      timestamp_sensor_sunday: input_datetime.alarm_sunday
      sunday_alarm: input_boolean.alarm_sunday
      monday_alarm: input_boolean.alarm_monday
      tuesday_alarm: input_boolean.alarm_tuesday
      wednesday_alarm: input_boolean.alarm_wednesday
      thursday_alarm: input_boolean.alarm_thursday
      friday_alarm: input_boolean.alarm_friday
      saturday_alarm: input_boolean.alarm_saturday
      check_entity: person.me
      - service: switch.turn_on
          entity_id: switch.bedroom_electric_blanket_outlet
      - service: switch.turn_off
          entity_id: switch.adaptive_lighting_adaptive_bedroom
      - delay:
          hours: 0
          minutes: 10
          seconds: 0
          milliseconds: 0
      sunrise_duration: 25
      max_mired: 450
blueprint:
  name: Wake-up light alarm with sunrise effect
  description: 'A wake-up light alarm with a brightness and color temperature sunrise
    Changes to original source_url:
    - added maximum mired
    - changed the light entity selector domain to be a input_datetime
    - added one input_datetime for each day of the week
    - added input_booleans for each day of the week. Able to turn on and off the alarm.
    Original source_url: https://gist.github.com/sbyx/96c43b13b90ae1c35b872313ba1d2d2d'
  domain: automation
  input:
    light_entity:
      selector:
        entity:
          domain: light
      name: Monday alarm timestamp sensor
      default: none
      selector:
        entity:
          domain: input_datetime
      name: Tuesday alarm timestamp sensor
      default: none
      selector:
        entity:
      name: Wednesday alarm timestamp sensor
      default: none
      selector:
        entity:
      name: Thursday alarm timestamp sensor
      default: none
      selector:
        entity:
      name: Friday alarm timestamp sensor
      default: none
      selector:
        entity:
      name: Saturday alarm timestamp sensor
      default: none
      selector:
        entity:
      name: Sunday alarm timestamp sensor
      default: none
      selector:
        entity:
    monday_alarm:
      name: Set alarm for Monday (Optional)
      description: Choose on for to turn alarm on for Monday
      default: 'off'
      selector:
        entity:
          domain: input_boolean
    tuesday_alarm:
      name: Set alarm for Tuesday (Optional)
      description: Choose on for to turn alarm on for Tuesday
      default: 'off'
      selector:
        entity:
    wednesday_alarm:
      name: Set alarm for Wednesday (Optional)
      description: Choose on for to turn alarm on for Wednesday
      default: 'off'
      selector:
        entity:
    thursday_alarm:
      name: Set alarm for Thursday (Optional)
      description: Choose on for to turn alarm on for Thursday
      default: 'off'
      selector:
        entity:
    friday_alarm:
      name: Set alarm for Friday (Optional)
      description: Choose on for to turn alarm on for Friday
      default: 'off'
      selector:
        entity:
    saturday_alarm:
      name: Set alarm for Saturday (Optional)
      description: Choose on for to turn alarm on for Saturday
      default: 'off'
      selector:
        entity:
    sunday_alarm:
      name: Set alarm for Sunday (Optional)
      description: Choose on for to turn alarm on for Sunday
      default: 'off'
      selector:
        entity:
    check_entity:
      default: none
      selector:
        entity: {}
    sunrise_duration:
        the timestamp.
      default: 25
      selector:
        number:
          min: 5.0
          max: 60.0
          step: 5.0
          mode: slider
    start_brightness:
      default: 1
      selector:
        number:
          min: 1.0
          max: 255.0
          step: 1.0
          mode: slider
    end_brightness:
        value.
      default: 254
      selector:
        number:
          min: 5.0
          max: 255.0
          step: 1.0
          mode: slider
    max_mired:
      name: Maximum color temperature
      description: 'The maximum color temperature to use. Start temperature - higher mired = warmer'
      default: 450
      selector:
        number:
          min: 5.0
          max: 500.0
          step: 5.0
          mode: slider
          unit_of_measurement: mired
    min_mired:
      name: Minimum color temperature
      description: 'The minimum color temperature to use. End temperature - lower mired = cooler'
      default: 0
      selector:
        number:
          min: 0.0
          max: 500.0
          step: 5.0
          mode: slider
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
  # original source_url: https://gist.github.com/sbyx/96c43b13b90ae1c35b872313ba1d2d2d
variables:
  sensor_monday: !input 'timestamp_sensor_monday'
  sensor_tuesday: !input 'timestamp_sensor_tuesday'
  sensor_wednesday: !input 'timestamp_sensor_wednesday'
  sensor_thursday: !input 'timestamp_sensor_thursday'
  sensor_friday: !input 'timestamp_sensor_friday'
  sensor_saturday: !input 'timestamp_sensor_saturday'
  sensor_sunday: !input 'timestamp_sensor_sunday'
  sunday_alarm: !input 'sunday_alarm'
  monday_alarm: !input 'monday_alarm'
  tuesday_alarm: !input 'tuesday_alarm'
  wednesday_alarm: !input 'wednesday_alarm'
  thursday_alarm: !input 'thursday_alarm'
  friday_alarm: !input 'friday_alarm'
  saturday_alarm: !input 'saturday_alarm'
  sensor: "{% if (as_timestamp(now()) | timestamp_custom('%a') == 'Sun') and states(sunday_alarm) == 'on' %}\n\
  \ {{ sensor_sunday }}\n\
  \ {% elif (as_timestamp(now()) | timestamp_custom('%a') == 'Mon') and states(monday_alarm) == 'on' %}\n\
  \ {{ sensor_monday }}\n\
  \ {% elif (as_timestamp(now()) | timestamp_custom('%a') == 'Tue') and states(tuesday_alarm) == 'on' %}\n\
  \ {{ sensor_tuesday }}\n\
  \ {% elif (as_timestamp(now()) | timestamp_custom('%a') == 'Wed') and states(wednesday_alarm) == 'on' %}\n\
  \ {{ sensor_wednesday }}\n\
  \ {% elif (as_timestamp(now()) | timestamp_custom('%a') == 'Thu') and states(thursday_alarm) == 'on' %}\n\
  \ {{ sensor_thursday }}\n\
  \ {% elif (as_timestamp(now()) | timestamp_custom('%a') == 'Fri') and states(friday_alarm) == 'on' %}\n\
  \ {{ sensor_friday }}\n\
  \ {% elif (as_timestamp(now()) | timestamp_custom('%a') == 'Sat') and states(saturday_alarm) == 'on' %}\n\
  \ {{ sensor_saturday }}\n\
  \ {% else %}\n\
  \ {{ 'no_alarm' }}\n\
  \ {% endif %}"
  # manual_time: !input 'manual_time'
  min_mired: !input 'min_mired'
  max_mired: !input 'max_mired'
  start_mired: '{{[state_attr(light_entity, ''max_mireds'')|int, max_mired|int]|min}}'
  end_mired: '{{[state_attr(light_entity, ''min_mireds'')|int, min_mired|int]|max}}'
  # test: '{{ as_timestamp(states(sensor)) }}'
  # test2: '{{ states(sensor) }}'
  # test3: '{{ state_attr(sensor,''timestamp'') }}'
  # test4: '{{ sensor }}'
  # teset5: '{{ (state_attr(sensor,''timestamp'') + as_timestamp(states(''sensor.date''))) - as_timestamp(states(''sensor.date_time_iso'')) }}'
  minutes: '*'
condition:
  value_template: '{{ sensor != ''no_alarm'' }}'
# - wait_template: '{{sensor == ''none'' or as_timestamp(states(sensor)) != None}}'
- wait_template: '{{0 < as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor)) - as_timestamp(now()) <= float(seconds)
- choose: []
# - condition: template
#   value_template: '{{sensor == ''none'' or as_timestamp(states(sensor)) != None}}'
#   value_template: '{{0 < as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor)) - as_timestamp(now()) <= float(seconds)
#     and states(check_entity) in [''unknown'', ''on'', ''home'']}}'
- choose:
  - conditions:
    - '{{state_attr(light_entity, ''min_mireds'') != None}}'
    sequence:
        color_temp: '{{start_mired}}'
  default:
- repeat:
    while:
    # - '{{sensor == ''none'' or as_timestamp(states(sensor)) != None}}'
    - '{{0 < as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor)) - as_timestamp(now()) <= float(seconds)}}'
    sequence:
    - choose:
      - conditions:
        - '{{0 < state_attr(light_entity, ''brightness'') | int < end_brightness | int}}'
        # - '{{0 < as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor)) - as_timestamp(now()) <= float(seconds)}}'
        sequence:
        - choose:
          - conditions:
            sequence:
                  (as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor)) - as_timestamp(now())) / float(seconds)))
                  | int}}'
                color_temp: '{{(float(end_mired) + (float(start_mired) - float(end_mired))
                  * ((as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor)) - as_timestamp(now())) / float(seconds)))
                  | int}}'
          default:
              brightness: '{{(float(end_brightness) - (float(range_brightness) * (as_timestamp(states(''sensor.date'') ~ '' '' ~ states(sensor))
- choose: []
mode: single
@erik.pretorius: I have exactly the same issue. Is there any solution for the error “Error executing script. Error for wait_template at pos 2: In ‘template’ condition: TypeError: unsupported operand type(s) for -: ‘float’ and ‘NoneType’” available?
Hi, no nothing yet.
Hi @erik.pretorius, thanks for your feedback.
Anyone else who could help?
I got a similar, but not the same error immediately after importing the Blueprint and creating an automation. I just assigned a Hue-Lamp connected via ConbeeII.
Error executing script. Error for wait_template at pos 2: In ‘template’ condition: TypeError: unsupported operand type(s) for -: ‘NoneType’ and ‘NoneType
have you bee nable to solve your issue?
