Wall Mount With iPad 2?
Hi you all,
which VNC server are you using ?
thanks
H
Read the comments.
They both show multiple ways how to deploy.
If you are not familiar with deploying docker images, use tileboard instead maybe. They at least have an addon:
Thanks ! I will have a look , nice day
Hi everyone. Been looking through several topics here on getting an old ipad 4th gen to work as a dedicated, wall mounted dashboard. Right now i’m running a docker firefox instance which i connect to from the ipad through VNC Viewer (somehow through the browser/safari i cannot get it to connect).
So far so good, this works pretty well. However, during my tests I seem to notice the ipad’s screen never goes off/into sleep while connected to the VNC. Has anyone got any pointers in how to get this to work so that the screen of the ipad does go off after some time? Perhaps i need to try different vnc apps? any help would be greatly appreciated!
Hi, I have made a addon which runs chromium with a vnc server as a HA addon, I’ve also bundled noVNC to allow easy access with the browser on the iPad2.
I just released it and would love if someone could try it out. HAVNC Add-on: Access your dashboards on older unsupported devices
I’ve worked around this with Guided Access. If you enable it the iPad won’t go to sleep automatically. And a nice bonus is that if you leave the power button enabled, you can put it to sleep and then wake it later and it will be back at the same app without having to swipe to unlock it. Convenient to be able to turn off the screen during the night and turn it back on when you wake up.
