hi
i setup so far 4 wall mount dashboard… perfectly working everyone love it … but i more request i don’t know doable or not . if yes then this is the best platform
integrate camera in the dashboard either in the new tab like how we setup for rooms or in the front…
IP CAM and nest drop cam
I think that is a great idea, but I don’t have any cameras … yet. I am happy to integrate someone elses work in this area but I can’t test what I don’t have!
I am planning cameras soon, and when I have them I will be looking to add functionality so be patient
I am interested in doing this but it will be a lot of work, and I don’t think I will get around to it until I have my own cameras. As I said … patience!
How did Jbags set up the weather radar in the example shown earlier in the thread? Wouldn’t that be similar to a cam? Kind of like how we integrated WX radar in HA by using the generic camera setup?
Take a peak at it and if you need a camera to actually test this, PM me. You’ve been a great help to me in the past and I would be willing to purchase a camera for you if you would be willing to work on this integration.
Thanks for the offer, it is very kind of you but its more about time than money!
I am leaving on a 7 day business trip on Sunday so won’t be able to even think about this until I return. I do however want to get something working so perhaps if I figure out a camera to buy it will be there for me when I return and I can start some work.
That link looks like a good start but I have something a little more elaborate in mind:
Small tile to show the latest image (obviously can be whatever size you want using x and y size)
When movement is detected the tile highlights somehow
Pressing the tile gives you a full screen view of the image
Maybe it updates in real time until you close it
Possibly the full screen view comes up automatically on movement (maybe an option)
Not sure how easy or doable all of that is but it would be the way I want to go - I don’t have a clue if it is possible until I get a camera hooked up and see what HA gives me. Also I suspect that different cameras may work differently so I may end up implementing something for my camera that doesn’t work for others …
OK, I understand. Just wanted to make the offer it would help. Safe travels! Let me know if you need any suggestions for cameras; I have a number of them in my system.
Right now I’m trying to get the Dashboard/HAPush to init on start up, then going back to our other project to try to give you more feedback.
Edit: When you get the opportunity, take a look at your init files. There are some bad name references in there - the dashing file is referred to as ‘dashboard’ and in the hapush init file, there’s a leftover reference to dashboard as well.
I made some few changes to my layout.
Added travel time to work for Felicia and me, “Home to Freemovr” and “Home to Svalls Hospital”.
I added the Google Maps Travel Time plugin in Homeassistant and imported it to my dashboard with Hasensor.
And I added the ability to change the temperature unit in haweather so that you can change it like hameter with “data-unit”.
When i update to the new version, i get error like this: http://hastebin.com/lunedipupa.vhdl
The files are where they should be. Does anyone know what to do? I’ve tried re-install everything.
It ran excellent before update. Then i get that “error” when “dashing start” is executed.
I made update. I also make a fresh install on another Rpi, just to se if the same problem occurred.
