Thanks Rene - I have been very busy as you know but will have some time soon!
after following your guide and reading alot of post from here i get the following error
pi@raspberrypi:~/hadashboard $ dashing start
bundler: failed to load command: thin (/usr/local/bin/thin)
NoMethodError: undefined methodeach' for nil:NilClass /home/pi/hadashboard/jobs/news.rb:56:in
<top (required)>ā
/var/lib/gems/2.1.0/gems/backports-3.6.8/lib/backports/std_lib.rb:9:inrequire' /var/lib/gems/2.1.0/gems/backports-3.6.8/lib/backports/std_lib.rb:9:in
require_with_backportsā
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:171:inblock in require_glob' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:in
eachā
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:inrequire_glob' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:181:in
<top (required)>ā
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing.rb:3:inrequire' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing.rb:3:in
<top (required)>ā
config.ru:1:inrequire' config.ru:1:in
block in ā
/var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/builder.rb:55:ininstance_eval' /var/lib/gems/2.1.0/gems/rack-1.5.5/lib/rack/builder.rb:55:in
initializeā
config.ru:1:innew' config.ru:1:in
ā
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:ineval' /var/lib/gems/2.1.0/gems/thin-1.6.4/lib/rack/adapter/loader.rb:33:in
loadā
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:182:inload_rackup_config' /var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/controllers/controller.rb:72:in
startā
/var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/runner.rb:200:inrun_command' /var/lib/gems/2.1.0/gems/thin-1.6.4/lib/thin/runner.rb:156:in
run!ā
/var/lib/gems/2.1.0/gems/thin-1.6.4/bin/thin:6:in<top (required)>' /usr/local/bin/thin:23:in
loadā
/usr/local/bin/thin:23:in `<top (required)>ā
I have tried sudo apt-get install thin and node, but still this error.
Any idea to what i can do to get it working?
Per
Can you post a sanitized version of your settings.rb please?
as far as i can see there are no secrets in my settings.rb file but here:
require ādata_mapperā
Initialize the DataMapper to use a database, if available. Fall back to an
sqlite file, if no database has been set up.
DataMapper.setup(:default, ENV[āDATABASE_URLā] || āsqlite:persistent.dbā)
Set object model for settings
class Setting
include DataMapper::Resource
property :name, String, :key => true
property :value, Text
end
Finalize all models
DataMapper.finalize
Up-migrate the schema
DataMapper.auto_upgrade!
Have done no editing to that fil
UG, sorry, I meant ha_conf.rb ā¦
Sorry aimc
when you asked me for the ha_conf.rb file i discovered a error in the file name and thats why i couldnāt get it to work, but now i have the demo dashboard.
Excellent
lol. i guess i replied to much here
per replies to me and writes āafter following your guideā¦ā
lookout andrew, people start to think i did the work
ups, sorry for that
Should i be able to control my lights from HADashbaord before installing HAPush?
dashboard will work whitout hapush.
it only wont be updated automaticly.
ok, then im doing something wrong, cant get my lights or devicetracking to work
if you have put in some widgets and you can see them, then they should work.
if you dont see them in your dashboard you have made an error in your dashboardfile.
i can see them in my dashboard, but non of them will turn on or off or dim
do they give the same setting as hass when you chose reload?
found that all my lights had disapered in HA frontend, so rebooted mu RPI, and my lights returned and is working through the HA frontend.
But when trying to start HADashboard with: dashing start i get this error again:
SyntaxError: /home/pi/hadashboard/lib/ha_conf.rb:6: syntax error, unexpected ā\nā, expecting =>
eachā
/var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:170:inrequire_glob' /var/lib/gems/2.1.0/gems/dashing-1.3.7/lib/dashing/app.rb:180:in
<top (required)>ā
<top (required)>ā
block in ā
initializeā
ā
loadā
startā
run!ā
loadā
Found an error in my ha_conf file
But still no luck getting my dashboard working
Can you post a sanitized version of your ha_conf.rb?
I donāt mind - you can fix all the problems and do the support work for me too
no thanks, i am not half the programmer you are
it would take me weeks, alone to get to the bottom off it all (allthough youre programming is a lot closer to my logic then a big part off hass )
So Iām trying to get this working on my PI3, but Iām not sure about the initial docker installation. (Iām sorry, Iām so new to linux. Iāve used it before but only as an actually desktop. Using terminal code is really new to me)
Iām looking at the installation directions and I notice the first heading says Using Docker (Non Raspian). Iām assuming this is not what I would like, since I have a Pi3. So this means I need to get Docker installed.
Will following the directions on this page get that done Possible directions for docker
Since I installed Home Assistant in a virtualenv (although Iām not sure yet what that means, just followed manual directions found here for a Raspberry pi), do I need to activate the virtualenv before following the docker installation directions and the hadashboard directions?
Thanks!
Here it is:
$ha_url = āhttp://192.168.0.32:8123ā
$ha_apikey = ātestā
$news_feeds = {
āTrafficā => āhttp://trafiknyt.smartlog.dk/rss-2.0.xmlā,
āNewsā => āhttp://www.b.dk/seneste/rssā,
