Wall switches for new install
Why???
I work a places with 6 floors and stretched out over a large area yet still only need one router.
Because I have I big house and I have mobile connection because it’s faster than a cable one. Two routers are for local network, one is cisco dual wan router and two of them are lte routers. I have two lte routers because my net is slow and it has a weak signal. Two lte routers gives me more robust and stable connection.
Ok, the 2 routers that handle a WAN connection I understand, but the internal routers are harder.
VLANs or L3 switches seems more appropriate here.
I think he is simply mixing up routers with access points.
I use internal routers in wifi mesh mode and cisco as a gateway for lan. Yeah maybe vlan on internal network will be better but those routers doesn’t support vlan.
No I don’t.
I think that one of members here said, that he has in the range of 100 devices on wifi without problems (can’t remember who, though…)
But, if you have 50+ devices then network equipment it’s even more important. You say you have 5 routers… which ones? As i said, it’s all about price. Routers in the range of 10-20€ can’t handle 50+ devices, ones in the price range 100+€ can. LTE router…well, it’s a very good question how quality is wifi part… combo devices are never as good as devices, made for one and only specific purpose.
And, in case of multiple routers it’s very good idea to put them in some sort of mesh system. I have 3 routers, too, connected in asus AiMesh system (beside menioned main one i have two rt-ac86u).
All i wanna say is that wifi devices are exactly as good as zigbee ones, if whole system is correctly defined and programmed.
5 routers for a family household? Means 5 wan connections, 5 (probably nat-ed) public ip addresses and so on? Wow thats religious!
I use two xiaomi routers working in wifi mesh mode for local wifi. And still some parts of the house have a weak signal or there is no at all signal. Wifi is a bad. During the day speed usually drops to 5 mbit or even less. This is because in Croatia isp companies are not interested in making better infrastructure. They do that only were there is a lot of customers. 5g exist here on some spots in town cente, my isp doesn’t have ipv6 and so on and on
No I have 2 wan routers so two wan connections. But my wifi is really slow and that’s the reason I’m having this setup.
If it works it works, but I would probably have pulled a cable from the router to each end of the house and have set the routers up in each end of the cables as APs only with same settings except the channels.
The channels should then be set to 1, 6 and 11 for 2.4GHz and likewise spread out for 5GHz (I can’t remember the frequency spread in that band atm) if the routers have that available.
I cant pull a cable. I use powerline adapters to connect local network to cisco router. You cant to that because walls are made from reinforcement cement and thick bricks.
But I will check a channels when I get back home.
Why 2 WAN connections?
Maybe i’mm missing something, but my suggestion:
  • I would have one single router which receives intranet , say your LTE router. This device would be only LTE internet receiver, nothing more. No wifi, no local network, nothing, only internet. I’d put it where LTE signal is best.
  • Then i’d connect this output from LTE device to my local router (main router, ONLY device with ā€œrouterā€ function in the house)
  • i would configure all other routers as access points, connected to main router via Mesh mode, if possible
  • if Mesh is not possible, i’d set all wifi on all devices to same channel, all SSID’s to same name/password (even 2.4GHz/5GHz if you have it). This way switching through AP’s will be seamless/automatic. Don’t set each device to a different wifi channel.
Also: powerline adapters are frequently cause of problems. Just an example: i tested such adapter (gigabit, not a cheap one) and it worked perfectly until i turned on chinese LED lamp - then immediately totally lost connection…
Hm… wifi signal has nothing to do with LTE signal, unless you mean that during the day your wifi is so congested (multiple apartments…?). If so, there’s not much you can unless play with channels and find one which is ā€œmost clearā€. Also note that if you have so congested wifi you’ll also have similar congested zigbee. Only advantage in zigbee can be narrower channels, so maybe it’s kinda easier to find ā€œfreeā€ gap.
I know how it is on concrete wall apartment (my friend has similar problem) - signal from living room doesn’t work anymore through closed living room doors and closed bedroom doors across corridor… It’s just…so many routers just calls for problems. Look at this as if there were multiple bosses in one jet plane… you’re bound to crash…
I have two lte routers because my isp infrastructure is bad. During the day when people are using the net internet speed drops a lot. Usually to 5 mbit or less. I experience problems with my networking from home while my nephew turn on the YouTube. My vpn connection went down immediately. Two routers help me maintain stability of internet connection. When I was talking about wifi I thought on lte internet connection.
Routers are placed on attic and connected to cisco router. The only way I can connect my cisco router with my local house router is to use powerline adapter I can’t run a cable to attic because walls are made from reinforcement concrete.
I live in a house not in a apartment.
I have wifi mesh network on my local xiaomi routers.
There isn’t much to do about lte connection because isp infrastructure is rubbish.
And it’s all the same what ever isp you use. You can choose between bad and worse
Ok, we agree about LTE connection - if it’s bad there’s nothing much you can do.
Wifi is another matter. There’s plenty it can be done here. Having routers only on attic is one of worst spots, i’m sure you agree.
Cables can be placed in many ways… i guess you really won’t ā€œbreakā€ concrete walls and put cables in, but one of options is ā€œabove wallsā€ - i don’t know how to say it… like THIS. Usually places can be found where furniture is amost to the ceiling, so such cables practically won’t be even visible.
Of course, there’s ā€œi can’tā€ and there’s ā€œi’m not allowed toā€ā€¦ two different things. If second one is true you’re stuck… Sometimes drastic measures have to be made in order something to work as desired… sad, but true.
One of option is also a number of extenders connected around the house, inter-connected via wifi. Extenders are available as ā€œplug-inā€ models, so you only need a free power outlet. Such system works quite ok if extenders are mounted at places where wifi signal to next extender is still ā€œdecentā€, so that they see each other with decent wifi signal strength. Note that sensors etc… from HA have nothing to do with bad LTE internet, only with badly placed internal home network. They communicate only locally with HA.
But, if your powerline adapter work ok, just make sure you don’t buy any cheap chinese crap to interfere with it…
Well attic is the highest spot. When I had only one lte router i tried to move it around the house but there isn’t any significant change. Router placement it’s not a problem. Lack of wifi towers covering this part of Zagreb is. Why isp want place more towers ?Well because for them this is expensive investment and there aren’t any buildings just houses. As i remember some woman from some isp check it out for me and the nearest wifi tower is 2 km from my location. Nearest!!
I know I can run this plastic channel but I want do it. It looks like a crap and still I will have to drill through the walls and I don’t want to do that.
I have a gigabyte powerline adapters and for now they are working fine. Forgot a brand but it doesn’t matter. I use two pair of them. One pair to connect tv to local router and another pair to connect local router to a gateway.
I tried extender and this doesn’t work for me. It’s better to use wifi mesh. I might need one more router to put it in a mesh mode but will not do it for now. It can wait.
As for devices goes there is no chance that I will be buying wifi devices any more. Zigbee ones works great for me. I have 10 smart plugs that I use as router for zigbee and this is working very well.
Oh… so if i understand correct, you use PUBLIC wifi spots?
:smiley:
No man, I have prepaid internet. But my internet connection on great day and ever greater timing doesn’t exceed 30 mbit.
In average is 15 mbit.
It’s ridiculous.
But, please, be consequent in naming stuff, you are talking about.
You already named your ISP connection WiFi, LTE, and whatever.
If you want adequate help, you really need to be precise with this.
As I made up from your story, I GUESS, as you are not consequent, that you have two 4G LTE modems running on one account?
So do you also use two SIM cards for this?
Actually the best for us to understand your situation will be, when you make a basic schematics of your network with all the routers and accespoints in it.
Oke you are right. I’m just on my vacation laying on the beach and speaking to people.
I really do not need any help. I don’t know how this came up. It began about wall switches and ending in wifi, routers and lte connections.
Of course I have two sim cards one for each router. How else could I run two lte routers.
