Im struggling with the wallpanel setup, and hoping that some of you can help me with it.
Wallpanel functions like it should, but i cannot customize it the way i want. I think that what i want is not the difficult, problem is that I just miss the knowledge to get it done
Situation; right now i have a wall mount tablet running fully kiosk. Inside fully kiosk i have a screensaver setup, which shows me this screen:
My wife and i like it a lot, just a simple digital clock. As soon as i walk up to the tablet, fully kiosk switches to the normal dashboard.
Problem is, fully kiosk always have to reload the screensaver, and the dashboard. That takes for example like 1 second, but that time the screen flashes bright white from the page being loaded.
Long story short; i would like to have the same screensaver, but made with wallpanel.
Maybe a stupid question…
But about hiding top bar
And then unable to edit the dashboard…
Is it possible to use an input_boolean button
To hide and unhide the topbar???
Like I have such for the screensaver?
Thnx.
i use wallpanel with a touchscreen on a win10 chrome kiosk, and when card interaction is true, i cant quit !! when i press the screen in a blank part, or press and move…
the only way to quit is ti emulate a key stroke.
hello, I am new to HA, I have an ipad pro 11 wall mounted, and i have wallpanel downloaded and trying to figure it out, my question is my panel is mounted in uniform with a wall full of pictures, i would like the panel to display my last name, for example in a nice text format, white letters with a black back ground or similar. but it only allows for url address, is there a way to get this done? thank you
I was playing around with the interactable cards, however I noticed the setting applies to all cards shown on the screensaver. I’m using it with a logo that overlays the images, however clicking on it with card_interaction: true means clicking on the logo does nothing. Only two small cards should be interactable, as they control lights. Would it be possible to set the card_interaction parameter for each individual card? I.e. defining it under wp_style in the card configuration.
If this is already possible in some way and I’m just missing the correct way of doing it, I’d like hearing so too!
Is anyone experiencing lag when returning from wallpanel screensaver back to lovelace? I takes 5-10s to get back for some reason. Tried with everything, almost empty dashboard, local images, different images, …
If using screensaver from Fully kiosk for instance, it works w/o lag. Seems to be the problem with WP. Any hints what to check next?
EDIT: even almost empty settings (only leaving idle time, so random pictures) gives same result. It’s a Fire tablet 10 pro.
I also have a fire 10 and do not see a slow down. Maybe some other integration causing a large CPU usage? maybe try disabling integrations one at a time and see if you can find anything. I will add i am not running latest HA core 2023.10.0 so if you are maybe thats issue?
Btw, what do you use to show dashboard? Although I checked every browser, fully kiosk, wallpanel, … and everywhere experiencing same delay when returning to dashboard.
Not sure what you mean? I use Fire 10 tablet, FK Browser and Wallpanel. I have a fairly complex dashboard too with a lot of devices and many pages to dashboard
