Hello, I am having an issue where when the screensaver runs, the weather module is not loading.
I get the following error āEntity not available: weather.homeā I search my entity and I do not have that entity. How would I go about adding it or using the only weather entity I do have āweather.forcast_solospotā?
Hello, new user here with Wallpanel. Looks like everything I wanted but having a few issues and hoping to get some fix suggestions.
I just upgraded to the 4.8 version. However, when running in Debug mode the version still shows 4.7.1. Not sure if that is correct or something went wrong with the HCAS update.
Iām using Walpanel with Dwains Dashboard. I put the YAML code in the /config/custom_components/dwains_dashboard/lovelace/ui-lovelace.yaml
Dwains Dashboard has three tabs ( HOME, DEVICES, & MORE).
My issue is, the screen saver only correctly displays the images if it is started when the browser is idle on the āMOREā page on Dwains Dashboard. If the screen saver starts on the HOME or DEVICES Tab, it only displays the first two pictures and then cycles between the two. The interesting thing is, the debug text shows the images cycling correctly, just not displayed correctly. That is the āCurrent image:ā continues to display different photos (as expected) than the two repeating images being displayed.
I believe this is an issue with Dwains, as I previously had this working with the default Lovelace. However, I hoping I might get some insight here as well to fix the issue. thanks, John
Iām experiencing some problems with the screensaver. Iām using images from Google Photoās. When the screensaver activates, the image loads just fine on my laptop but not on my wallpanel. Iām using old Asus Zenbook with Android 5.0.2 as wallpanel. Could this be the problem?
Iām finding Wallpanel , when it comes to viewing the slide show is highly dependent on the browser and device. I still canāt figure out why the screensaver works on only some of the tabs on Dwains Dashboard. I have found that if I use the default image url, the pictures display and cycle correctly.
Only when Iām displaying local photos that I see the problem. The Home page and Device page will only display the first two pictures cued. The Debug text āCurrent imageā continues to indicate new random photo files are selected from the local directory every 15 seconds or so but the displayed image only cycles between the first two images. Strange. Is there any other debug file to view to get a clue as to what might be going on?
Canāt reproduce your issue.
I just released version 4.8.1 which logs the url when fetching the image from media-source.
Perhaps this can help to find the issue.
For those of you using Fully Kiosk in combination with WP, which features are you using from which app? FK send to have really good wake features with camera detection and motion detection Bo have had an issue with its screensaver function though.
Well, everything started working as it should (slide show started and cycled correctly regardless of what tab on was left idle for the designated 10 seconds). Then, unknown cause, it reverted back today only cycling correctly when started on the āMoreā tab.
where do I find the log that version 4.8.1 produces?
Feature request:
Store path and filename in sensor when exiting screenshow of local media.
Case:
You are watching the screenshow of local media and suddenly your attension is drawn to a certain picture that you want to have a closer look at.
You are not able to pause the screenshow, so you want to have a look at the picture elsewhere - but you didnāt get the name of the file.
Suggestion:
When exiting screenshow Wallpanel stores path and filename of last shown picture in a sensor
