I have the following in my log:
Logger: py.warnings
Source: /usr/local/lib/python3.11/warnings.py:109
First occurred: 02:01:26 (30 occurrences)
Last logged: 14:17:50
/usr/local/lib/python3.11/site-packages/bs4/builder/__init__.py:545: XMLParsedAsHTMLWarning: It looks like you're parsing an XML document using an HTML parser. If this really is an HTML document (maybe it's XHTML?), you can ignore or filter this warning. If it's XML, you should know that using an XML parser will be more reliable. To parse this document as XML, make sure you have the lxml package installed, and pass the keyword argument `features="xml"` into the BeautifulSoup constructor. warnings.warn(
It’s only a warning but I’m always trying to clean up my log. I believe it comes from the scrape sensor that I use to get info from my printer. This is configured as here:
scrape:
- resource: http://192.168.0.169/DevMgmt/ProductUsageDyn.xml
scan_interval: 60
- name: "HP OfficeJet Pro 9020 Series Pages Printed"
unique_id: hp_officejet_pro_9020_series_pages_printed
icon: mdi:file-document
select: 'dd\:TotalImpressions[PEID="5082"]'
value_template: >-
{% if value == "" %}
0
{{ value }}
unit_of_measurement: pages
Is there a way to stop this or should I stop worrying?
