If you just have to split events which are separated with an and, try " and "
If your events are separated with commas and and
, you could try a regular expression with groups and alternatives, like "(\\,| and )"
i reinstalled it about 5 five times, everytime in a different way to make sure its working, but i dont get it working again. I looked in the folder path on the pi and checked it with your files vom githubâŠevery file is there, no file is missingâŠ
please help me to get it working again
EDIT:
IT IS WORKING AGAIN!
I made todayâs core update and with some magic its working.
Must have something to do with the backup und the restore on the new SSD
I did setup the waste collection integration and the releated sensors.
However I am having trouble that the individual sesors do not show any data.
Here is my basic setup:
url to ics calendar: https://calendar.google.com/calendar/ical/5r9dlnvmkaa6kp6ub3q5svm1f8%40group.calendar.google.com/public/basic.ics
Configuration file:
waste_collection_schedule:
sources:
- name: ics
args:
url: https://calendar.google.com/calendar/ical/5r9dlnvmkaa6kp6ub3q5svm1f8%40group.calendar.google.com/public/basic.ics
customize:
- type: Papier in VG Leiningerland
alias: Paper
icon: mdi:package-variant-closed
- type: Bio in VG Leiningerland
alias: Bio
icon: mdi:leaf
- type: Gelber Sack in VG Leiningerland
alias: Recycle
icon: mdi:recycle
- type: RestmĂŒll in VG Leiningerland
alias: Trash
icon: mdi:delete
fetch_time: "22:02"
day_switch_time: "11:00"
Setup of sensors:
Waste collection
- platform: waste_collection_schedule
source_index: 0
details_format: upcoming
value_template: '{% if value.daysTo == 0 %}Today{% elif value.daysTo == 1 %}Tomorrow{% else %}in {{value.daysTo}} days{% endif %}'
types:
- Paper
I can see the sensors, but they do not include values for upcoming bin collections.
Can someone guide me in the right direction where I can find the issue?
Very much appreciate any feedback and comments from your side.
I have change my configuration from a local ICS file to the service provider Abfallwirtschaft Zollernalbkreis thatÂŽs general works.
But my sensors for the collection date will not work. In the config,yaml
sources:
- name: abfall_zollernalbkreis_de
args:
city: "86"
types:
- "restmuell"
- "gelbersack"
- "papiertonne"
- "biomuell"
- "gruenabfall"
- "schadstoffsammlung"
- "altpapiersammlung"
- "schrottsammlung"
- "weihnachtsbaeume"
- "elektrosammlung"
This is on on tne not working sensors are in the sensors.yaml
details_format: "upcoming"
value_template: "{% if value.daysTo == 0 %}heute{% elif value.daysTo == 1 %}morgen{% else %}in {{value.daysTo}} Tagen{% endif %}"
types:
- papiertonne
The status is unkown
That one seems to work.
value_template: '{{value.types|join(", ")}}'
date_template: '{{value.date.strftime("%d.%m.%Y")}}'
Before i switched from the local ICS File to the Service Provider all sensors are working.
Any tipps?
First I would add a sensor without any type specification. You should now see all data and also the exact names that required for the aliases. Then check the type field in the customize section.
If you look at the sensor which is working: Is the displayed waste type exactly papiertonne
? If no, correct this.
Hello Steffen,
thanks for your reply I tried your advice, but unfortunately still without success:
Waste colleection integration:
sources:
- name: ics
args:
# customize:
# - type: "Papier in VG Leiningerland"
# alias: Paper
# icon: mdi:package-variant-closed
# - type: "Bio in VG Leiningerland"
# alias: Bio
# icon: mdi:leaf
# - type: Gelber Sack in VG Leiningerland
# alias: Recycle
# icon: mdi:recycle
# - type: RestmĂŒll in VG Leiningerland
# alias: Trash
# icon: mdi:delete
fetch_time: "22:02"
I have also adjusted the sensor:
source_index: 0
However my sensor doesnât show any upcoming events.
Any other hints!?
Thanks for your help,
Holger
I have a problem to include some waste types. Itâs probably caused by my ics.
Here is my configuration.yaml:
sources:
- name: ics
args:
file: "www/Abfallkalender.ics"
customize:
- type: 'Abfuhr: BioabfallgefĂ€Ă\, vierzehntĂ€gig'
alias: BioTonne
icon: mdi:trash-can
- type: 'Abfuhr: Gelbe Tonne'
alias: GelbeTonne
icon: mdi:recycle
fetch_time: "04:00"
day_switch_time: "10:00"
And here my sensors.yaml
value_template: '{{ value.daysTo }}'
types:
- GelbeTonne
types:
- BioTonne
Sensor AbfallGelbeTonne works, but AbfallBiotonne shows no values.
I think itâs because the format of my ics. Here is how the Summary looks:
SUMMARY:Abfuhr: Gelbe Tonne
SUMMARY:Abfuhr: BioabfallgefĂ€Ă\, vierzehntĂ€gig
How should I set my type for BioTonne? I also tried ââ without success.
Thanks for your help.
Hi there
Data collection works perfectly but I canât quite figure out the correct approach to get the card design Iâd like.
Configuration:
sources:
- name: name_of_my_local_service
args:
address: "obfuscated"
customize:
- type: Garbage
alias: Red
- type: Recycle
alias: Yellow
- type: Organic
alias: Green
calendar_title: "Bins"
day_switch_time: "12:00"
separator: " & "
Sensor:
add_days_to: true
value_template: "{% if value.daysTo == 0 %}Today{% elif value.daysTo == 1 %}Tomorrow{% else %}in {{value.daysTo}} days{% endif %}"
types:
- Red
- Yellow
- Green
sensor.bins
has the State: in 2 days
and these Attributes:
2022-11-22: Red & Green
2022-11-29: Yellow
daysTo: 2
attribution: Last update: 11/20/22 06:41:43
icon: mdi:numeric-2-box-multiple
friendly_name: Bins
When I add an entity card and choose sensor.bins as the entity, as expected the value is âin 2 daysâ
How do I configure the card to display:
Red & Green in 2 days
Can I do this by adjusting the value template, or am I better of with multiple sensors to place in an entities card?
Thanks!
I am also having issues configuring my sensors, as just âAltpapierâ shows correctly. The other Sensors say âUnknownâ. The Source seems to be correct as it is shown in the calendar correctly.
I copied the last part of my configuration here, maybe I am missing something, but I canât figure it out.
#Abfallkalender sensoren
types:
- Altpapier
types:
- Biomuell
types:
- Gelber Sack
types:
- Restmuell
# Abfallkalender 2022
sources:
- name: static
calendar_title: Altpapier
args:
type: Altpapier
frequency: WEEKLY
interval: 2
start: '2022-11-10'
until: '2022-12-09'
- name: static
calendar_title: Biomuell
args:
type: Biomuell
frequency: WEEKLY
interval: 1
start: '2022-11-14'
until: '2022-12-27'
- name: static
calendar_title: Gelber Sack
args:
type: Gelber Sack
frequency: WEEKLY
interval: 2
start: '2022-11-14'
until: '2022-12-27'
- name: static
calendar_title: Restmuell
args:
type: Restmuell
frequency: WEEKLY
interval: 2
start: '2022-11-21'
until: '2022-12-27'
Thanks!
Hi Guys,
at first many thanks for the integration! I Installed and configured it and it`s working well except for one waste type âGelbe/r Sack/Tonne, Biotonneâ from awb_es_de provider.
The integrations shows the waste type within the upcoming collection dates:
But not within the sensor i added for the waste type:
Integration config:
sources:
- name: awb_es_de
args:
city: !secret atHome_city
street: !secret atHome_street
customize:
- type: Papiertonne
alias: papier
- type: RestmĂŒll 2-wöchentlich
alias: rest-2w
- type: RestmĂŒll 4-wöchentlich, RestmĂŒll 2-wöchentlich
alias: rest-24w
- type: Gelbe/r Sack/Tonne, Biotonne
alias: gelbersack
fetch_time: "00:05"
Waste sensor for âGelbe/r Sack/Tonne, Biotonneâ
types:
- gelbersack
It seems that the / within the Title is the Problem and the integration don`t parse the text correctly. I tried usingâŠ
- type: "Gelbe/r Sack/Tonne, Biotonne"
alias: gelbersack
and
- type: 'Gelbe/r Sack/Tonne, Biotonne'
alias: gelbersack
and also
- type: Gelbe//r Sack//Tonne, Biotonne
alias: gelbersack
but no one worked. Is it a bug or just an mistake within my configuration?
Versuch doch mal hier
- type: 'Gelbe/r Sack/Tonne'
alias: gelbersack
- type: 'Biotonne'
alias: biotonne
Ich wĂŒrde behaupten du hast 2 MĂŒllarten gemsicht
Hey AndyBa,
Danke fĂŒr den Hinweis. TatsĂ€chlich waren das zwei unterschiedliche MĂŒllarten. Dachte, da die immer am selben Tag abgeholt werden, werden die wie eine MĂŒllart behandelt.
Jetzt funktionierts!
Hey guys!
This is my first post here! And my second day with HA!
So please have understanding!
Issue:
Logfile tells me:
âsource not found: Muellâ
⊠and there are also no entries in the calender as well
⊠and the Entities have the status âunknownâ.
So my first thought was, that there is a problem with the .ics file.
I imported it in outlook, and exported it again.
I also used the test.ics file of the installation folder.
I reinstalled the integration⊠nothing had an effect
In the configuration.yaml I named it Muell, thats correct. But whereÂŽs the problem?
I always renamed the entries (summary) in the .ics file
So, sorry I canÂŽt find my mistake!
configuration.yaml
sources:
- name: Muell
args:
file: "www/muell2022.ics"
version: 1
customize:
- type: gelbe Tonne
alias: gelbeTonne
- type: blaue Tonne
alias: blaueTonne
- type: schwarze Tonne
alias: schwarzeTonne
- type: braune Tonne
alias: brauneTonne
fetch_time: "04:00"
Sensors.yaml
#Abfuhrkalender
count: 4
value_template: '{% if value.daysTo == 0 %}Heute{% elif value.daysTo == 1 %}Morgen{% else %}in {{value.daysTo}} Tagen{% endif %}'
types:
- schwarzeTonne
count: 4
types:
- brauneTonne
count: 4
types:
- blaueTonne
count: 4
types:
- gelbeTonne
thanks for your help, thanks for your response!
JoeâŠ
OK I solved it!
âMuellâ has to be renamed into âicsâ ⊠then it works!
Hi Flo_93,
I also have issues with the integration of the umweltprofis schedule. Could you already solve it?
Check if the waste types (the ones under types
) exactly match the values that are shown in calendar.
Hallo,
ich wollte Fragen ob es möglich ist diesen Abfallentsorger im Programm zu âinstallierenâ
https://www.zacelle.de/muellabfuhr/abfuhrtermine/
Ich habe es per ics. Kalender integriert. Aber vielleicht ist ja auch eine Integration möglich ?!!?
Viele GrĂŒĂe
Nicole
I just came across this a couple days ago and got it setup and love it. I was wondering if there was a way to split waste types when the names are combined in the ICS file.
Our communityâs events list:
âCompostables and recyclingâ
âCompostables and garbageâ
âRecyclingâ
âGarbageâ
âCompostablesâ
Instead of having 5 different sensors, Iâd like to just have the 3 individual types. Is there a way for me to do that when the event name is sometimes combined?
