Blue bin is in 6 days. Grey in 13 days. I also had the green bin but deleted it for now, it also showed 6 days but should be 20 days.
The indentation is correct in my config, just messed up when pasting it here.
You need to add the type to the sensor, otherwise it wonât know which one to choose. With the sources, you select which list of entries from the data (calendar) you want, and in the sensor you need to select which one you bind to this specific sensor.
Like this:
- platform: waste_collection_schedule
details_format: upcoming
value_template: 'in {{value.daysTo}} days'
type:
- Grey Bin
And Iâm not sure, but Iâve added the attribute add_days_to: true
as well, but that please check for yourself in the documentation.
It just adds as a new attribute:
add_days_to: true
type:
- Grey Bin
Thanks for the hint. I added type but got an error and changed it to types and this cleared the error.
But the state now showed as unknown. I then deleted the word bin from types, so just grey, blue, green, and it works now.
Thanks again
Anyone knows what is going on after the last Waste Collection Update (I did it today)?
Instead of receiving the inforation "BiomĂŒll/RestmĂŒll/âŠ) I get person names!
Information in the phone app still works fine!
I use this connection:
waste_collection_schedule:
sources:
- name: app_abfallplus_de
args:
app_id: de.ucom.abfallavr
Can confirm this behavior. Just freshly installed it and thought it was an error on my side.
source:
sources:
args:
app_id: de.k4systems.abfallappzak
I created an GitHub Issue for the problem:
@AKGitH and @OnSive Has either of you checked the real source? In this case the data that comes in from AbfallPlus?
The phone might not be updated, so could still use data from yesterday.
Itâs nice that you created an issue, but for now, you havenât provided any information, that could help. If itâs an error on the side of AbfallPlus, the issue and the time of the developer of this integration is simply waisted.
So please, before you jump to conclusions, like âitâs a bugâ, give us some information, so the source of the error can be checked and verified. So that we can at least add any kind of information to that issue.
If you provide us with some more information we could as well check, but without even knowing for what address/city/county this is, we are not really able to help.
@paddy0174 sorry for writing such a short report.
Iâve just installed the a ZAK Abfall App on a new phone and used following the location settings:
Fischen
Ortsteile (= districts)
alle StraĂen (= all streets)
basically the same as in my source which I generated using the app_abfallplus_de.py
wizard.
sources:
args:
city: Fischen
bezirk: Ortsteile
While the data in the app seems to be real and valid, the result of the framework returns the names and numbers.
This is the complete code:
sources:
args:
city: Spechbach
strasse: RĂŒbenbergweg
customize:
- type: GrĂŒne Tonne plus 4-RadbehĂ€lter wöchentlich
show: false
- type: SperrmĂŒll + Altholz
show: false
- type: Rest-/BiomĂŒll 4-RadbehĂ€lter wöchentlich
show: false
- type: GrĂŒnschnitt
show: false
- type: RestmĂŒll 2-/4-RadbehĂ€lter 14-tĂ€glich
alias: Graue_Tonne
- type: BiomĂŒll 2-/4-RadbehĂ€lter 14-tĂ€glich
alias: Braune_Tonne
- type: GrĂŒne Tonne plus 2-/4-RadbehĂ€lter 14-tĂ€glich
alias: Gruene_Tonne
icon: mdi:recycle
- type: Glasbox
alias: Glasbox
icon: mdi:recycle
HA shows still names, phone app today shows the right information (Phone was restarted and the âAbfall datasâ updated).
This showes HA:
I was hoping someone could help me out, on HA startup I get several errors for âUndefinedError: âNoneâ has no attribute âstateââ, one for each of my two schedules. I also donât see any calendar entries, but I do get sensors with the correct date information. Can someone point me in the right direction to resolve this?
Configuration:
day_switch_time: '6:00'
sources:
- name: static
args:
type: Trash
frequency: WEEKLY
start: '2024-01-03'
until: '2024-12-25'
excludes: # Add exception for the recurrence
- '2024-01-03' #New Years Day
- '2024-05-29' #Memorial Day
#Independence Day
- '2024-09-04' #Labor Day
#Thanksgiving
#Christmas Day
dates: # Manually add dates that are not part of the recurrence
- '2024-01-04'
- '2024-05-30'
- '2024-09-05'
- name: static
args:
type: Recycle
frequency: WEEKLY
start: '2024-01-01'
until: '2024-12-30'
- '2024-01-01' #New Yesrs Day
- '2024-05-27' #Memorial Day
#Independence Day
- '2024-09-02' #Labor Day
#Thanksgiving
- '2024-12-25' #Christmas Day
- '2024-01-02'
- '2024-05-28'
- '2024-09-03'
- '2024-12-26'
source_index: 0
value_template: '{{value.types|join(", ")}} {% if value.daysTo == 0 %}Today{% elif value.daysTo == 1 %}Tomorrow{% else %}in {{value.daysTo}} days{% endif %}'
source_index: 1
Errors in question:
2024-07-04 09:19:38.748 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ states.sensor.trash_pickup.
state }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 604, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2639, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
jinja2.exceptions.UndefinedError: 'None' has no attribute 'state'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 716, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 606, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'None' has no attribute 'state'
2024-07-04 09:19:38.753 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ states.sensor.recycling_pic
kup.state }}) renders=2>
Edit: I fixed the calendar issue, I believe it may have been due to a seperate logbook issue. I still receive the errors on HA startup, but everything is now functional.
Hello everyone,
is it just me or is the installation via GUI not working?
I am running a clean installation of the integration (no folder in custom_components and uninstalled in hacs, I restart homeassistant, install via hacs and restart).
When I then want to install the integration in the integrations page, it tells me that this integration has to be installed via the configuration.yaml.
I have checked the homeassistant logs and there are no errors so I think the installation went fine.
Does anybody have any experience with this?
Thank you!
thatâs because there is no gui. sensors have to be none manually
Since 10days and some HASS updates my schedules seem to have disappeared and all sensors show âunknownâ now. Also no calendar entries!?
I used local .ics files for a whole (tried to switch back as well btw) and since 4 weeks my providerâs API (ZAW Donau-Wald).
Any tipps on how to start troubleshooting the API/ICS calls and calendar events???
The Apps By Abfall+ source is currently broken. If you donât use ZAW Donau-Wald with the Apps By Abfall+ source please open a Issue in github.
The Apps By Abfall+ issue is discussed here: [Bug]: app_abfallplus_de returns names with numbers instead of the types · Issue #2197 · mampfes/hacs_waste_collection_schedule · GitHub. There is a fix that seem to work, but itâs not officially part of the repo. (only apply the patch if you know what youâre doing)
The GUI configuration method is not yet part of a release, itâs only available in the master/git version and will be available shortly in the next release.
The configuration looks fine (if you put the sensors in the sensor section). The issue seems not to be in the Waste Collection sensors, but some other template sensor you may set up somewhere else (based on error log).
Thank you! That was the push I needed. I had a mushroom card with a template. I was able to fix it:
Before:
cards:
primary: '{{ states.sensor.trash_pickup.state }}'
icon: mdi:trash-can
icon_color: >-
{{ 'red' if 'Trash Tomorrow' in states('sensor.trash_pickup') else
'red' if 'Trash Today' in states('sensor.trash_pickup') else 'blue' }}
icon: mdi:recycle
icon_color: >-
{{ 'red' if 'Recycle Tomorrow' in states('sensor.recycling_pickup')
else 'red' if 'Recycle Today' in states('sensor.recycling_pickup')
else 'blue' }}
After:
cards:
primary: '{{ states(''sensor.trash_pickup'') }}'
icon: mdi:trash-can
icon_color: >-
primary: '{{ states(''sensor.recycling_pickup'') }}'
icon: mdi:recycle
icon_color: >-
else 'blue' }}
We now support GUI configuration. This is the first version of the GUI, and we already planned future improvements. We could not test the GUI with all sources and edge cases, so if you run into any problems, feel free to report them in GitHub or here.
We are aware of a few limitation (Add config flow (UI) configuration option by dan-r · Pull Request #2068 · mampfes/hacs_waste_collection_schedule · GitHub)
and minor improvements (Add config flow (UI) configuration option by dan-r · Pull Request #2068 · mampfes/hacs_waste_collection_schedule · GitHub)
Full release notes: Release 2.0.0 · mampfes/hacs_waste_collection_schedule · GitHub
Thanks a lot for your work on this integration, youâre really doing a lot here!
Just before the topic comes up:
If youâre upgrading to version 2.0.x from 1.x.x, you can just apply the update! Besides the mentioned breaking changes, you can just update and thereâs no need to change configuration or anything like that.
