Water usage sensor
I managed to fix this. It’s because the same pin is defined twice for two sensors. Only the latter sensor definition will work. platform: copy is the solution, but a template sensor should also work. See two sensors with same input not work with latest firmware · Issue #3364 · esphome/issues · GitHub.
I also cleaned up the code a bit, I can now see both usage in litres and meter reading in cubic meters:
  - platform: pulse_counter
    pin: GPIO14
    name: "Water Flow Rate"
    update_interval : 60s
    accuracy_decimals: 1
    unit_of_measurement: "l/min"
    icon: "mdi:water"
  - platform: pulse_meter
    pin: GPIO14
    internal: true
    total:
      icon: "mdi:water"
      name: "Water Usage Total"
      unit_of_measurement: "litres"
      accuracy_decimals: 0
      device_class: water
      state_class: total_increasing
  - platform: copy
    source_id: water_usage_total
    name: "Water Meter Total"
    icon: "mdi:water"
    unit_of_measurement: "m³"
    accuracy_decimals: 3
    device_class: water
    filters:
      - multiply: 0.001
