Hello
First time poster need assistance
I have issues with the touch on the waveshare ESP32-S3 7inch touch display
I have loaded the Update esphome-19-LVGL-demo.yaml file into the display and the correct items are displayed
Time is showing the correct time if i press the clock face no message box
The test dial is showing 90 pressing any of the buttons from 10 to 100 the test dial does not move
I have attached a picture of the display
Yaml i loaded
# updated to 2025.7.2
# Substitution Variables
substitutions:
device_internal_name: esphome19
device_wifi_name: esphome-19
device_friendly_name: ESPHome 19
device_ip_address: 192.168.0.189
device_sampling_time: 30s
# Globals
globals: ##to set default reboot behavior
- id: wifi_connection
type: bool
restore_value: no
initial_value: "false"
# Board Configuration
esphome:
friendly_name: ${device_friendly_name}
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.arduino.memory_type: qio_opi
board_build.flash_mode: dio
board_upload.maximum_ram_size: 524288
psram:
mode: octal
speed: 120MHz
esp32:
board: esp32s3box
variant: esp32s3
flash_size: 8MB
cpu_frequency : 240MHz
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESPTOOLPY_FLASHSIZE_8MB: "y"
CONFIG_FREERTOS_HZ: "1000"
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240: y
CONFIG_ESPTOOLPY_FLASHMODE_QIO: y
CONFIG_ESPTOOLPY_FLASHFREQ_120M: y
CONFIG_SPIRAM_MODE_OCT: y
CONFIG_IDF_EXPERIMENTAL_FEATURES: y
CONFIG_SPIRAM_SPEED_120M: y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: y
#CONFIG_COMPILER_OPTIMIZATION_SIZE: y
CONFIG_COMPILER_OPTIMIZATION_PERF: y
#CONFIG_COMPILER_OPTIMIZATION_DEBUG: y
advanced:
enable_idf_experimental_features: True
# Enable logging
logger:
logs:
component: ERROR
# Enable Home Assistant API
api:
# reboot_timeout: 0s
# encryption:
# key: !secret api_encryption_key
# OTA
ota:
platform: esphome
password: "40e3f66f6934698b70a9220c3e9f7c8a"
# WiFi
wifi:
# networks:
ssid: "Optus_8DE49C"
password: "tauntpheer5PtEy"
manual_ip:
static_ip: 192.168.0.189
gateway: 192.168.0.1
subnet: 255.255.255.0
dns1: 192.168.0.1
ap:
ssid: "waveshare-7inch-display-1"
password: "6ufMS4f6yW0I"
captive_portal:
# Web Server
#web_server:
# port: 80
# version: 2
# include_internal: true
# auth:
# username: !secret web_server_user
# password: !secret web_server_password
# local: true
# IO Extender
ch422g:
- id: ch422g_hub
# Switch
switch:
- platform: restart
- platform: safe_mode
name: Use Safe Mode
- platform: gpio
pin:
ch422g: ch422g_hub
number: 2
mode:
output: true
inverted: false
restore_mode: ALWAYS_ON
# Interval
interval:
- interval: 10s
then:
- if:
condition:
wifi.connected:
then:
- lambda: |-
id(wifi_connection) = true;
else:
- lambda: |-
id(wifi_connection) = false;
time:
- platform: homeassistant
on_time:
- seconds: "*"
then:
- script.execute: clock_update
# Sensors
# WiFi
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: ${device_sampling_time}
# Uptime
- platform: uptime
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(${device_internal_name}_uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# - platform: homeassistant
# id: battery_charging
# entity_id: sensor.1be6e4_Battery_Power
# internal: true
# id: grid_output
# entity_id: sensor.grid_output
# internal: true
# id: grid_input
# entity_id: sensor.grid_input
# internal: true
# id: solar_gen
# entity_id: sensor.1be6e4_ac_output_total_power
# internal: true
# id: home_use
# entity_id: sensor.1be6e4_total_consumption_power
# internal: true
# id: battery_soc
# entity_id: sensor.1be6e4_remaining_battery_capacity
# internal: true
# Text Sensors
text_sensor:
# ESP32 internal sensors
- platform: wifi_info
ip_address:
ssid:
mac_address:
name: Mac Wifi Address
# Custom Text sensors
name: Uptime Human Readable
icon: mdi:clock-start
#image:
# - file: "image.png"
# id: my_image
# # resize: 320x480
# type: RGB565
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_pink
red: 100%
green: 10%
blue: 40%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 0%
green: 0%
blue: 100%
- id: my_gray
red: 50%
green: 50%
blue: 50%
- id: my_white
red: 100%
green: 100%
blue: 100%
- id: my_black
red: 0%
green: 0%
blue: 0%
font:
- file: "fonts/arial.ttf"
- file: "gfonts://Roboto"
bpp: 4
script:
- id: clock_update
then:
- lvgl.indicator.update:
value: !lambda |-
return id(esptime).now().second;
value: !lambda |-
return id(esptime).now().minute;
value: !lambda |-
auto now = id(esptime).now();
return std::fmod(now.hour, 12) * 60 + now.minute;
############################################ START OF VLGL
lvgl:
log_level: none #INFO
color_depth: 16
bg_color: my_gray
text_font: arial_12
width: 320
height: 480
align: center
style_definitions:
- id: date_style
align: center
text_color: 0x000000
bg_opa: cover
radius: 4
pad_all: 2
theme:
button:
scroll_on_focus: true
#group: general
border_width: 2
text_font: arial_24
outline_pad: 6
pressed:
border_color: my_yellow
checked:
border_color: my_blue
focused:
border_color: my_gray
label:
text_font: arial_24
msgboxes:
- id: message_box
close_button: true
title: Message box
body:
text: "This is a sample message box."
bg_color: my_black
buttons:
- id: msgbox_apply
text: "Apply"
- id: msgbox_close
text: "\uF00D"
on_click:
then:
- lvgl.widget.hide: message_box
widgets:
- obj:
height: 320
width: 480
align: center
pad_all: 0
bg_opa: 0%
widgets:
- button: ########################## bottom buttons
x: 40
y: 260
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "10"
on_click:
then:
value: 10
- lvgl.widget.redraw:
- button:
x: 120
y: 260
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "20"
on_click:
then:
value: 20
- button:
x: 200
y: 260
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "30"
on_click:
then:
value: 30
- button:
x: 280
y: 260
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "40"
on_click:
then:
value: 40
- button:
x: 360
y: 260
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "50"
on_click:
then:
value: 50
- button: ########################## top buttons
x: 40
y: 10
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "60"
on_click:
then:
value: 60
- button:
x: 120
y: 10
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "70"
on_click:
then:
value: 70
- button:
x: 200
y: 10
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "80"
on_click:
then:
value: 80
- button:
x: 280
y: 10
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "90"
on_click:
then:
value: 90
- button:
x: 360
y: 10
#align: center
width: 50
height: 50
#checkable: true
widgets:
- label:
align: center
text: "100"
on_click:
then:
value: 100
# Example meter:
- meter:
#align: center
x: 230
y: 60
width: 200
height: 200
widgets:
- label:
y: 30
align: center
text: "Test"
scales:
range_from: 0
range_to: 100
angle_range: 240
rotation: 150
ticks:
count: 51
length: 3
major:
stride: 5
length: 13
label_gap: 13
indicators:
- line:
width: 2
color: 0xFF0000
r_mod: -4
value: 88
- tick_style:
start_value: -10
end_value: 40
color_start: 0x0000bd #FF0000
color_end: 0xbd0000 #0000FF
# Example action:
on_click:
then:
value: 0
- obj: ######################################### Elegant Clock - https://community.home-assistant.io/t/esphome-elegant-lvgl-clock/772365
height: 200
width: 200
x: 20
y: 60
pad_all: 4
bg_opa: 0%
border_width: 0
widgets:
- meter:
height: 100%
width: 100%
align: center
bg_color: my_white
scales:
# Minor ticks
- ticks:
width: 2
count: 61
length: 10
color: my_black
range_from: 0
range_to: 60
angle_range: 360
rotation: 270
# Minuite hand
indicators:
- line:
width: 3
color: my_black
r_mod: -1
# Major ticks
- angle_range: 330
rotation: 300
range_from: 1
range_to: 12
ticks:
width: 3
count: 12
length: 20
color: my_black
# Hour hand
- angle_range: 360
rotation: 270
range_from: 0
range_to: 720
indicators:
- line:
width: 4
color: my_black
r_mod: -40
# Second hand
- angle_range: 360
rotation: 270
range_from: 0
range_to: 60
indicators:
- line:
width: 2
color: my_red
r_mod: -10
on_click:
- lvgl.widget.show: message_box
########################################################### END OF VLGL
i2c:
sda: GPIO08
scl: GPIO09
scan: True
# Define display
display:
- platform: rpi_dpi_rgb
update_interval: never
auto_clear_enabled: false
color_order: RGB
pclk_frequency: 16MHZ
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
ignore_strapping_warning: true
vsync_pin:
number: 3
pclk_pin: 7
pclk_inverted: true
reset_pin:
ch422g: ch422g_hub
number: 3
# enable_pin:
# ch422g: ch422g_hub
# number: 2
hsync_back_porch: 8
hsync_front_porch: 8
hsync_pulse_width: 4
vsync_back_porch: 16
vsync_front_porch: 16
vsync_pulse_width: 4
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
touchscreen:
platform: gt911
display: my_display
i2c_id: bus_a
interrupt_pin: GPIO4
reset_pin:
ch422g: ch422g_hub
number: 1
mode: OUTPUT
on_touch:
- lambda: |-
ESP_LOGI("Touch", "Touch detected at x=%d, y=%d", touch.x, touch.y);
on_update:
- lambda: |-
for (auto touch: touches) {
if (touch.state <= 2) {
ESP_LOGI("Touch points:", "id=%d x=%d, y=%d x.raw=%d, y.raw=%d", touch.id, touch.x, touch.y, touch.x_raw, touch.y_raw);
on_release:
then:
- if:
condition: lvgl.is_paused
then:
- lvgl.resume:
Logs from ESPHome when i touch the display
[08:54:20][I][Touch:803]: Touch detected at x=0, y=0
[08:54:20][I][Touch points::808]: id=0 x=0, y=0 x.raw=216, y.raw=356
[08:54:21][I][Touch:803]: Touch detected at x=0, y=0
[08:54:21][I][Touch points::808]: id=0 x=0, y=0 x.raw=227, y.raw=364
[08:54:21][I][Touch points::808]: id=0 x=0, y=0 x.raw=217, y.raw=366
[08:54:22][I][Touch:803]: Touch detected at x=0, y=0
[08:54:22][I][Touch points::808]: id=0 x=0, y=0 x.raw=221, y.raw=360
[08:54:22][I][Touch points::808]: id=0 x=0, y=0 x.raw=221, y.raw=368
[08:54:23][I][Touch points::808]: id=0 x=0, y=0 x.raw=221, y.raw=363
[08:54:23][I][Touch:803]: Touch detected at x=0, y=0
[08:54:23][I][Touch points::808]: id=0 x=0, y=0 x.raw=219, y.raw=372
[08:54:23][I][Touch points::808]: id=0 x=0, y=0 x.raw=223, y.raw=364
