Probably not, it’s all the same code. If someone changed the attribute behavior, you’ll see it in both UI / yaml sensors.
Darn. Okay. Hopefully it gets fixed at some point then.
Thanks!
knowing what I know about this api, i’d recommend changing to any other travel platform. The waze api is bad, very bad.
I ended up moving over to the “Here” integration. Thanks!
