Works good!!! Thank you so much!!!
Works fine!!! Thank you so much!!!
This looks very promising for getting Davis weather station into HA. But my understanding of all the components here is not good enough, so I am hoping someone here can point me in the right direction.
I have configured the WD end, and sent messages through to HA. In HA I have the Mosquitto MQTT broker addon installed and that is working for 2 other things (Actron Air conditioner integration and Solar Analytics addor for an MPP Solar inverter). If I use MQTT explorer and point to the HA broker, I can see pretty similar stuff as in the screenshot Brage has put above with the various weather readings from WD, so it appears to be all up there. So I suspect my issue is with HA configuration to get those sensors recognised in the various integrations, devices and enties in HA so I have visibility of them.
I have taken Edwinâs config above and taken my best guess at editing to account for :-
- my requirements given I am in Australia with different units of measurements (ie deg C, km/h, kPa etc), and
- the new message format to get ride of depreciated syntax.
So all of this I could be completely stuffing up, because I donât really have a good understand of this. But this is what I have come up with :-
mqtt:
- name: "Temperature"
icon: mdi:thermometer
state_topic: "temp"
unit_of_measurement: '°C'
value_template: '{{ value.split("{")[1].split("}")[0] | float }}'
- name: "Humidity"
icon: mdi:water-percent
state_topic: "hum"
unit_of_measurement: '%'
- name: "Barometer"
icon: mdi:trending-up
state_topic: "baro"
unit_of_measurement: 'hPa'
value_template: '{{ value.split("{")[1].split("in. }")[0] | float }}'
- name: "Wind Speed"
icon: mdi:weather-windy
state_topic: "wind"
unit_of_measurement: 'km/h'
value_template: '{{ value.split("{")[1].split(" km/h }")[0] | float }}'
I have done this and restarted HA which now restarts without errors. But I canât find any evidence of this in Integrations, devices or Entities (but I might be looking in the wrong place). Under the âcore-mosquitto MQTTâ âIntegrationsâ, I can see 2 devices and 85 entities, but this is the same as before and these 2 devices at the Actron AC, and the MPP Solar inverter.
So I am running out of ideas, and any assistance from someone here would be greatly appreciated to get this going.
Thanks heaps in advance.
Actually, my bad. After bumbling around in the dark, I figured out my issue. âEntitiesâ had been created, I was just not looking in the right place and because I had given the too generic ânamesâ above to the sensors, it was hidding amoungst the other entities with similar names. So I have renamed that âVP2_âŠâ and they are all there.
So thanks for this post for pointing me in the right direction.
I may be asking a dumb question but here it goes.
I have a lot of weather information extracted from airports METAR from NOAA web. I am desperately trying MQTT to transmit a raw text string to HA in order to display what is called âraw metarâ but I am not getting anything.
Is there a way to capture a string as a sensor in ha mqtt integration?
Thanks in advance.
Hello. I have a problem with the proper display of data in home assistant. In the mqtt.in file, the data is displayed correctly, and in the home assistant, the entity has an unknown status.
I have no idea what system you are using. Where is mqtt.in coming from?
He is using Weather Display. There is a feature where you can use MQTT to send the data somewhere else. I use it to send data to home assistant.
You configure a mqttin file WD generates a mqttout file which are the values of the entities youâve chosen.
First check in the WD directory and find mqttou. See if it makes sense.
Then on configuartion,yaml check the the mqtt section. My code is below.
mqtt:
state_topic: "temp"
unit_of_measurement: '°F'
- name: "Humidity"
state_topic: "hum"
- name: "Barometer"
state_topic: "baro"
unit_of_measurement: 'inHg'
value_template: '{{ value.split("{")[1].split(" }")[0] | float }}'
state_topic: "wind"
unit_of_measurement: 'mph'
- name: "Max Temp"
state_topic: "maxtemp"
- name: "Max Temp Time"
state_topic: "maxtemptime"
unit_of_measurement: ''
value_template: '{{ value.split("{")[1].split("}")[0].strip() }}'
icon: mdi:clock
- name: "Min Temp"
state_topic: "mintemp"
- name: "Min Temp Time"
state_topic: "mintemptime"
icon: mdi:clock
- name: "Dew Point"
icon: mdi:weather-fog
state_topic: "dewpoint"
- name: "Heat Index"
state_topic: "heatindex"
- name: "Wind Chill"
state_topic: "windchill"
- name: "Min Wind Chill"
state_topic: "minwindchill"
- name: "Min Wind Chill Time"
state_topic: "minwindchilltime"
icon: mdi:clock
- name: "Max Wind Chill"
state_topic: "maxwindchill"
- name: "Max Wind Chill Time"
state_topic: "maxwindchilltime"
icon: mdi:clock
- name: "Max Temp"
- name: "Min Temp"
state_topic: "lowtemp"
- name: "Wind Gust Speed"
state_topic: "gustspeed"
- name: "Wind Direction"
icon: mdi:subdirectory-arrow-right
state_topic: "winddirection"
unit_of_measurement: '°'
value_template: '{{ value.split("{")[1].split(" }")[0] | int }}'
- name: "Wind label"
state_topic: "windlabel"
icon: mdi:compass
- name: "Max Wind Gust"
state_topic: "maxgust"
- name: "Max Wind Gust Time"
state_topic: "maxwindgusttime"
icon: mdi:clock
- name: "Baro Change"
state_topic: "barochange"
unit_of_measurement: 'inHg/hr'
- name: "High Baro"
state_topic: "hibaro"
- name: "High Baro Time"
state_topic: "hibarotime"
icon: mdi:clock
- name: "Low Baro"
state_topic: "lowbaro"
- name: "Low Baro Time"
state_topic: "lowbarotime"
icon: mdi:clock
- name: "Yesterday's Max Baro"
state_topic: "yesmaxbaro"
- name: "Yesterday's Max Baro Time"
state_topic: "yesmaxbarotime"
icon: mdi:clock
- name: "Yesterday's Min Baro"
state_topic: "yesminbaro"
- name: "Yesterday's Min Baro Time"
state_topic: "yesminbarotime"
icon: mdi:clock
- name: "Yesterday's Max Humidity"
state_topic: "maxhumyest"
value_template: '{{ value.split("{")[1].split("}")[0] | int }}'
- name: "Today's Rainfall"
icon: mdi:weather-rainy
state_topic: "todayrain"
unit_of_measurement: 'in'
- name: "Monthly Rainfall"
state_topic: "monthrain"
- name: "Yearly Rainfall"
state_topic: "yearrain"
- name: "Hourly Rainfall"
state_topic: "hourrain"
- name: "Cloud Cover"
icon: mdi:cloud-outline
state_topic: "cloudcover"
- name: "Solar Energy"
state_topic: "solarenergy"
unit_of_measurement: 'W/m2'
icon: mdi:weather-sunny
- name: "VP Forecast"
icon: mdi:card-text-outline
state_topic: "vpforecast"
- name: "Cloud Height"
unit_of_measurement: 'ft'
state_topic: "cloudheight"
- name: "Indoor Temp"
state_topic: "indoortemp"
- name: "Indoor Humidity"
state_topic: "indoorhum"
- name: "Rain Rate"
state_topic: "rainrate"
unit_of_measurement: 'in/hr'
- name: "24 hour Ave Temp"
state_topic: "24houravetemp"
- name: "Temp change last hour"
state_topic: "tempchangehr"
- name: "Hum change last hour"
state_topic: "humchangehr"
- name: "Max Gust last hour"
state_topic: "maxgustlasthour"
- name: "Feels Like"
state_topic: "apparenttemp"
- name: "Yesterday's rainfall"
state_topic: "yesrainfall"
- name: "Rainfall last 7 days"
state_topic: "rainlast7days"
- name: "Yesterday's Max Temp"
state_topic: "maxtempyest"
- name: "Yesterday's Max Temp Time"
icon: mdi:clock
state_topic: "maxtempyestt"
- name: "Yesterday's Min Temp"
state_topic: "mintempyest"
- name: "Yesterday's Min Temp Time"
icon: mdi:clock
state_topic: "mintempyestt"
- name: "Storm Rain"
state_topic: "stormrain"
Hello againâŠ
It donŽt work anymore to pic out timestamps from the sensors from Weather Display�
Here is my sensor:
- name: "WD Moonset"
state_topic: "moonset"
icon: mdi:theme-light-dark
Hope for helpâŠ
Johan
I got âUnknownâ valueâŠ
Hopefully, somebody can help a complete Noob to Home assistant.
Using the examples above, I was able to assign NUMERICAL Weather Display data to various Home assistant sensors through MQTT ⊠unfortunately, for the life of me I have yet to figure out how to do the same with TEXTUAL data like âwind directionâ (ex. NNW) and âweather warningâ textual output from the Weather Display program.
Here is the output into MQTT âŠ
Anyone with helpful ideas ?
if you have a textual response in the mqtt topic and have the following set in the sensor
unit_of_measurement: ââ
remove the line.
It seems if unit_of_measurement is configured then a int/float is expected.
