Weather underground (Wunderground) weather sensor
Hello @broesie,
Yes the problem is not with the HA version but it with the WU service.
Based on the connection timeout error it seems that you are hitting the problem/outage reported on WU forums.
Ok, thnx for the update… so I guess, for now I can’t do anything to the errors… I hope wunderground will solve those errors fast…
Now I got errors like this, and is flooding my log file…
17-02-11 01:21:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
    result = next(coro)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 387, in _update_entity_states
    yield from update_coro
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 208, in async_update_ha_state
    state = self.state
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor/wunderground.py", line 164, in state
    return int(self.rest.data[self._condition][:-1])
ValueError: invalid literal for int() with base 10: ''
Do you see any information displayed at HA frontend for WU?
Yes, in my frontend, I see all the wunderground sensors with values,… However the log file is fled full of wunderground errors… So it’s not easy to find other errors… I hope that Hass will come out with a version where you can filter, or exclude errors so you can resolve some things easier…
Any updates? It’s almost 2 weeks further and still no improvement? Still seeing multiple errors in the logs…
Have you contacted WU? The problem is more on their end than on HA’s. My logs have been pretty clean with the exception of an occasional issue with alerts.
Wunderground is flooding my logfile, all wunderground errors (except 1 error of chromecast), its very difficult to find other errors in the logfile…:
17-02-13 23:10:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 213, in async_update_ha_state
    state = self.state
17-02-13 23:10:58 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:11:29 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:12:00 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:12:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:13:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:13:33 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:14:04 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:14:35 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-13 23:15:06 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
    state = self.state
17-02-14 00:38:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
    result = coro.throw(exc)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 209, in async_update_ha_state
    yield from self.hass.loop.run_in_executor(None, self.update)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor/wunderground.py", line 213, in update
    self.rest.update()
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/util/__init__.py", line 296, in wrapper
    result = method(*args, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor/wunderground.py", line 248, in update
    self.data = result["current_observation"]
KeyError: 'current_observation'
17-02-14 00:38:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    self.rest.update()
17-02-14 02:04:04 WARNING (Thread-13) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-02-14 02:04:19 ERROR (Thread-13) [pychromecast.socket_client] Failed to connect, retrying in 5.000000s
  File "/home/hass/.homeassistant/deps/pychromecast/socket_client.py", line 246, in initialize_connection
    self.socket.connect((self.host, self.port))
  File "/usr/lib/python3.4/ssl.py", line 840, in connect
    self._real_connect(addr, False)
  File "/usr/lib/python3.4/ssl.py", line 831, in _real_connect
    self.do_handshake()
  File "/usr/lib/python3.4/ssl.py", line 804, in do_handshake
    self._sslobj.do_handshake()
ConnectionResetError: [Errno 104] Connection reset by peer
17-02-14 16:19:44 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    self.rest.update()
17-02-14 16:20:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    self.rest.update()
Well, you could set the logger options to filter them out and set your error level to something higher, like fatal
but you may also want to check your connections at the Pi. Maybe run some curl commands to access the API and see if the errors are coming through because of something in your Pi’s setup. I was having connection errors with multiple components and it turned out that a lot of it was in the DNS setup on my Pi.
Since upgrade to 0.38.2 I had only one error with WU last night.
Wait a little longer and you will see more errors will popup… I’m also running 0.38.2…
I’m running 0.38.2 since it been published.
I know reviving an old thread.
Is there a way to slow the poll rate down for the requests to the server? I would like to increase it to every 15 minutes. If I am reading correctly, it asks every 10 minutes.
