Yes, it would be much better described as āis privateā. However your analogy to IPv4 isnāt really appropriate for IPv6. They are different protocols with wildly different addressing themes and some concepts cannot be directly transferred from IPv4 to IPv6.
Having said that, if OI were to use a public IPv4 subnet in my home LAN (say 81.82.83.0/24) and I assigned Ha the address 81.82.83.10/24 and my client which talks to HA has an address of 81.82.83/121/24 then yes, I would expect HA to consider that the client is ālocalā (i.e. in the same subnet).
The ultimate point is that it seems that the āis localā option for webhooks is intended to restrict access to only clients that are ālocalā (i.e. in the same subnet as HA) but it doesnāt currently do that correctly for IPv6 (as I have described in detail above).
Factually, āwebhook triggers can only be accessed from devices on the same network as Home Assistantā is not true. It only checks whether the originating IP is private or not.
Whats going on is the dev who wrote that code misunderstand local context.
Id call it a bug.
It would likely break in my setup too if I tried to go ipv6 native My dhcp issues ULA. Granted MOST people donāt setup valid Ip6 addressing but if you do you should not be penalized.
I see what they say in the code. How they handle it is fundamentally wrong.
+1 on this bug. The principle of address assignment and selection of IPv6 is completely different from IPv4 and the same logic canāt be simply applied to both protocols.
Let me share with you my example:
my network provider (as most of ISPs in Japan) is IPv6 native.
my home gateway receives a global IPv6 prefix from the ISP router (e.g. 2001:xxx:xxx:xxx::/60) - consider this as if the ISP assigned me a number of entire public IPv4 subnets (e.g. 1.2.0.0/24 ~ 1.2.15.0/24)
my home gateway freely uses one or more of those global subnets for its own networks (e.g. 2001:xxxx:xxxx:xxx0::/60) - often that would be just 1, but power users could have separate subnets, e.g. for guest network (e.g. 2001:xxxx:xxxx:xxx1::/60, IoT network (2001:xxxx:xxxx:xxx2::/60, etc.
within those global subnets, my home gateway freely assigns the exact addresses, without intervention of the ISP router.
with that, there is no need for private IPv6 addresses, and thatās actually one of the points of IPv6 - IPv4 private addresses are mostly a workaround for the limited number of available addresses
Now moving on to how Home Assistant fits into this:
I have a server that sits on the network and hosts HA
it uses DHCP and/or IPv6 RA to obtain network addresses
for IPv6 itās allocated only a global address as described above (e.g. 2001:xxxx:xxxx:xxx0::123/128)
the server has a hostname (letās say hass.local) attached too and the home gateway keeps the association betweem the hostname and its IP addresses
whenever any other machine on the network queries the home gateway DNS server for hass.local it gets a response with both the private IPv4 address (because IPv4 networks canāt afford to assign a public address to every host in the world) and the global (but locally managed and from the subnet owned by the local network) IPv6 address (2001:xxxx:xxxx:xxx0::123/128)
since the network environment here is IPv6 native, the software prefers IPv6 addresses and so the Home Assistant Android app ends up connecting via the global IPv6 address of the server, therefore also introducing itself with an address from the same IPv6 subnet (e.g. 2001:xxxx:xxxx:xxx0::34/128))
the server fails to consider that a local access, even though the device connects from the same network.
Also note that typically for IPv6 environments, the security aspect is not implied by the addressing system (i.e. public vs private). IPv6 systems (as does my home gateway) typically have firewalls set to deny any incoming connections from uplink ports, regardless of what addresses they come from.
